Question about Garden
Craftsman self propelled mower and sputters while running, think its missing a spring or 2 on the throttle, won't start all the time I have to keep pulling the plug and cleaning it to get it started again
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,069 Answers
Clean the carburetor jet
Posted on Jul 15, 2013
  • 6 Answers
SOURCE: Lawn mower will not start and run
Sounds like a clogged carb or a cracked primer bulb. I would install a carb rebuild kit and new primer bulb if your mower uses one.
Posted on May 31, 2009
  • 4 Answers
SOURCE: craftsman 6.75hp self propelled mower starts and turns off
I think that this is a 4stroke engine and runs on neat petrol.Have you been putting oil in with the petrol like a 2 stroke engine needs because this would account for the smoking.If not the check that you havn't overfilled the gearbox oil.
Posted on Jun 12, 2009
vincob
  • 718 Answers
SOURCE: my craftsman self propelled lawn mower no longer
if it is a belt driven drive check the belt for tension or break. or check the cable that engages the drive wheels.
Posted on Sep 04, 2009
goldenglove1
  • 144 Answers
SOURCE: 22 In Craftsman Self propelled.Starts
Oh my, that is so annoying. There is probably dirt in the carb. or the gas tank. What I think happens is, the dirt gets sucked up into the fuel line and clogs the carb, then when the mower sits for a while the dirt goes back into the tank for another couple minutes. I have absolutely no tolerance for this when it happens.
Posted on Aug 05, 2010
SOURCE: I have a Toro 20" self propelled, electric start
I am strictly Briggs&Stratton. They are hard to start when the fuel tank is half empty. Clean the plug and air filter.
Posted on Jun 15, 2011
Troy bit self propelled mower just started running full blast constantly why
Throttle cable stuck ,or carby ,spray cable with WD40 and work the leaver back and forth,check carby to make sure a return spring hasn't come off,is the motor a Brigs and Stratton. Make sure the leaver at carby it moving whilst you are working the cable leaver,good luck.
Jul 19, 2014 | Troy Bilt 5.5hp Self Propelled Mower
How does the govener and carb linkage work on a Troy-Bilt 2005 800 Series (839) self propelled mower
Have you changed springs? Likely the correct components are there unless you have changed it. Does it run properly and at correct rpm when not in tall grass? Check for proper throttle adjustment first. also check for obstructions (packed grass for instance) under the deck that could be impeding the blade. Lastly, if you have the discharge blocked with a mulch plug, remove the plug. let the tall grass discharge. then run over it again and mulch it.
May 29, 2014 | Troy Bilt 5.5hp Self Propelled Mower
I have a Craftsman, 6.75hp, SP, model #917.377580 lawn mower. Was running good but, won't start any more. Don't know if or where the fuel filter would be. Thinking it might be the solid state...
If you know that you have a good plug, and you don't have spark at the plug, then it is a bad Ignition Coil (Module). If you need further help, let me know.
Good Luck!
Jim
Aug 16, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
My craftsman 22" self propelled
Your problem is at other end . Engagement problem is probably due to a loose belt. Make adjustment in that area of mower. GOOD LUCK.
Jun 16, 2011 | Craftsman Garden
22 In Craftsman Self propelled.Starts easy, runs good for about 15-20 mins. Starts missing and dies. Will start again in about 30 mins New spark plug/ air filter
Aug 05, 2010 | Craftsman 22" Rear Bag Rear Propelled High...
Craftsman 6.75hp self propelled mower starts and turns off
Jun 12, 2009 | Craftsman Garden
I have a 7hp briggs and straton craftsman self propelled push mower. It's a few years old but runs great, the only thing wrong is the self propelled part won't engage. I took it apart down to the axle but...
Could be a stretched out/broken belt, a worn out transmission or the drive teeth on the inside of the wheels could be worn out. I would start by looking at that. Remove the drive wheels and check for damaged or missing teeth.
Apr 20, 2009 | Craftsman Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
