Question about Pool & Spa
Sundance marin 850 error message "FLO"
Just drained and refilled spa. also replaced jet nossels/covers. worked fine for a while and then FLO message appeared. pumps work fine. water level ok. heater now not working. found 4 small ball bearings in bottom of spa. Any recommendations on how to fix this problem?
SOURCE: heater won't go on my jucuzzi model 315
Hey, I am having the same problem... Did u figure out the problem? How did you fixed it??
Thanks
renato_rmj@yahoo.com.br
Posted on Jun 01, 2009
john224
  • 1378 Answers
SOURCE: Power Flo Matrix pump, leaking from underneath?
Replace the pumps mechanical seal with a replacement seal #200. It's less than $10.
Posted on Jul 20, 2009
john224
  • 1378 Answers
SOURCE: Loud buzzing sound when turned on. Some flow to jets just not muc
Replacing the whole thing is pretty easy but costly. You could save up to about $100 just replacing the motor which is still around $300 alone. Try local electric motor shops that advertise pump or pool repairs. The motor may also be fixable so you would be best served to take it to one of those shops for an inspection prior to just ordering anything new.
Posted on Aug 24, 2009
Mike258
  • 1498 Answers
SOURCE: pump was working fine yesterday popped the breaker
Hi Mohn,
Don't know your geographic location, but where I am we've been in the single digit temperatures for three days. Everything that can freeze has frozen.
If you are in a similar area, even though the water in the spa (I'm assuming the spa pump is being used on a spa) is heated, the pump housing isn't. If it iced up, it could very well cause the problems you describe.
Comment back with some more detail before I continue down what might be the wrong path.
Best regards
Mike
Posted on Dec 11, 2009
SOURCE: Refilled my hottub and now there is a
simple fix its one of two things you did not prime the spa when filling it meaning that u just did not lay a hose in the spa then fill it you always need to prime the heater first along with the circ pump if you do not you will get a thing call airlock which is what it sounds like air in the main circulation pump for the heater.Also could be that u removed the filter while you still had the spa running an clogged the circ pump or it could be the flowswitch. Sounds like u might have a sundance spa an if the flo is flashing its either the air lock or your pump went or its clogged if the flo sign is not flashing then its the flowswitch but in that case w/a solid flo nothing would b working. To fix the airlock just shut the power down an take your hose an force water into the intake side of the filter area this is what u should always do 1st when you fill it that how you prime yuor pump an when fillin it all the way it best to fill it through the other end of the filter just put the hose into the filter tube w/the screw on it.IF THATS NOT IT THEN FEEL YOUR CIRC PUMP IT WILL BE THE SMALLEST PUMP IN THE SPA IF U CAN NOT TOUCH IT FOR MORE THEN A FEW SECS. THEN IT WENT ON U OR IT CLOGGED
Posted on Mar 27, 2010
I have a Sundance 850 spa that when you switch it on at mains power , runs for 5-10 sec then shuts off. Have message - - - - that comes on display panel
Had a similar problem; the heater was blown. You might want to try disconnecting heater wires (with breaker to spa OFF).
Then see if spa pumps work after turning power on.
I got an after market heater that works great; VERY hard to install while spa is full...but I did it anyway. Good luck.
Feb 22, 2016 | Pool & Spa
My new flo-master xp2 spa pump will not engage the low speed. The hi speed (jets) works fine but the low speed doesn't engage. I just hear a clicking and nothing comes on.
if you had ice in it and it was powererd up.. you may have burned out the start capacitor or even the start windings..why was it iced up while working on it..it should have been freewheeled by hand before startup..I just got a tub in here.. had to wait 6 days for it to thaw out..(sign of good insulation) we just ran it for the first time yesterday..got some seals to replace and some switches to repair..
Jan 08, 2014 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Sundance spa
may be getting water in the blower and the safety bypass is turning it on to blow the backed up water out of those lines..the tub may be too full..
Nov 14, 2013 | Pool & Spa
Circulation pump is running but FLO is displayed on panel and heat light goes out.
FLO is displayed because something has caused a reduction in water pressure through the heater. The spa control will turn the heater off when FLO is displayed to prevent a burn out.
I suggest checking the filter cartridge, the suction fittings & any valve which could be partially closed & restricting flow.
Try run the spa with out the filter cartridge if this clears the error then it is the cartridge.
If none of these work it is possible the your flow switch and/or pump is beginning to fail.
Mar 24, 2013 | RTO Sundance Heater Element Harness Black...
I have a 2005 Sundance 850 spa. Pump 1 continues to cycle on for about a minute and then shuts off and then cycles on for a minute. I can not turn it off from the control panel. Everything else works fine.
the motor running for a short period of time and turning off then back on then off is either going to be a bad winding in the motor or a bad relay on your circuit board.
Do you have any error codes on display in the topside panel?
Rod
US Parts Center
888-521-6183
Feb 27, 2013 | Pool & Spa
OH message showing on sundance spa sentry help!!!
If you are seeing OH and FLO codes, you need to shut it down at the circuit breaker, until it can be serviced. It likely needs a new circulation pump and the flow or pressure switch may be failing to shut down the heater causing the boiling
Aug 08, 2012 | Pool & Spa
Refilled my hottub and now there is a ''FLO'' signal and the heater will not come on. Pumps and jets work fine.
Jan 29, 2010 | Jacuzzi RapidHeat In-Line Heater U395000 [...
Low water pressure
IF ITS PUMPING FINE-( NOT RUNNING, PUMPING ) YOU PROBABLY HAVE A LEAK SOMEWHERE DOWNSTREAM. IS A WELL OR WHAT IS THE PUMP USED FOR?
Mar 14, 2009 | Jet Flo 04325143A Marine Heavy Duty Water...
Pool & Spa Logo
145 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
