What would be the top 2 reasons 1 of the outside 20 amp fuses would blow?
Carrier air conditioner model 38CKC024340 blew 1 of the 20 AMP fuses outside what are the possible causes? Would the compressor be the most likely cause? Is it possible the capacitor could be the problem? Replaced both fuses and fan in house runs but nothing outside.
  • 15,557 Answers
There are only two possible things that it could be. The compressor or the fan motor. The compressor is self contained and cannot be serviced. You just replace the whole thing. The fan motor can be replaced.
Posted on Jul 11, 2013
kstfas
  • 75 Answers
SOURCE: Air Conditioner malfunction
Hi, Sounds like you have a short in the control circuit to me. Turn off all power going to the unit. Write down or otherwise mark the wires leaving the control board going to the thermostat. Remove them from the control board. Replace the fuse. Turn power back on and see if the fan still runs. If it does, check and or replace the heat limit switch that brings the fan on during the heat cycle. It may just need adjusted. If the fuse blows, I would think that the control board is probably bad. If it doesn't blow, Remove the thermostat. Leaving all thermostat wires open check them with an Ohm meter. There should be no continuity between them. Twist all the wires together at one end and ohm them again at the other end. You should have complete continuity on all wires. If the wiring checks out, down power the unit. Double check your wire colors and rewire the control board. With all wires open at the thermostat, turn the power back on. Touch the RED wire to the YELLOW wire. The Condensing unit should come on. Touch the RED wire to the GREEN wire. The fan should come on. Touch the RED wire to the WHITE wire. The heat should come on. Down power the unit. Replace the thermostat. Test unit. If the fuse has lasted ok but blows now it is either wired wrong at the Thermostat or the thermostat is bad. I hope I have helped. NOTE: If you can not understand these instructions. Call a licensed Heating / Air conditioning company. kstfas
Posted on Sep 23, 2007
22yooper
  • 828 Answers
SOURCE: RV ROOF TOP AIR CONDITIONER TRIPS BREAKER
Possible low voltage condition would cause that kind of a problem. To small a cord without the ability to carry and maintain the voltage would cause a voltage drop. I would test the voltage supply and make sure it is within 10% of that required for your A/C to operate properly.
Posted on Jun 16, 2008
motor1258
  • 6674 Answers
SOURCE: Air conditioner fan will not come on and unit will run for 1 minute and stop
You hear the compressor kick in (Hum) but no fan comes on? Will the fan come on when just in fan mode, not cool, or do you have that set-up?
Posted on Aug 14, 2008
philbran
  • 242 Answers
SOURCE: My A/C (Carrier weathermaker 8000 hybrid) is not cooling properly
set the t-stat low and let it run for 5 minutes , stick a thermometer in the return air closest to the unit as possible until you get a good reading , then stick the thermometer in the cold air supply again closest to the indoor unit as possible let sit until it stops going down in temp.
this is called your temp difference and it should be atleast a 14deg. F difference from in to out. if its lower you have a refrigerant problem, Let me know how it goes.
Phil
Posted on Jun 10, 2009
luker711
  • 91 Answers
SOURCE: I have a Ruud air-conditioner/heat pump and it blows 5 amp fuse.
It sounds like the thermostat wire going to the condenser is ground, It either got pulled loose and is touching the housing or as in most cases the wire got cut or was chewed by an animal. You need to turn electric off to both devices and physically inspect the thermostat wire going from the air handler to the outside unit, also inspect where they connect inside the unit. When you find the break, cut and strip each individual wire and securely wire nut each conducter red to red white to white and so on. There you go all fixed. That's when I give you the bill for $75...except this time you write that check to yourself. Good Luck
Posted on Jul 14, 2009
My comfort pro 6000 apu screen said low voltage and ac wouldnt work
1.Need to check the generator belt to make sure it's not lose or broke.
2.Remove bottom inspection cover and use a fluke meter and check for 110 at generator.
Those two thing's would be where I would start for the low voltage alarm. now for the a/c alarm. There could be multiply thing's to cause the a/c not to work. Do you have and functions on the driver control panel? I would start.
1. Remove the top cover on the APU. Check the 20 amp fuse. If the fuse is blown it will cause you not to get voltage to the CCU board witch could be a reason the a/c is not working. Also if the fuse is blown the first place to look would be the condenser fan on back of the truck. You can use a fluke meter and ohm it out. Don't quote me but I believe it ohms at 10.4 I'd have to look in the book. also use a screw driver and see if the blade is spinning freely it is very common for these to lock up and blow the 20 amp fuse. You can remove the top cover on the CCU under the bunk. There are 4 3/8 bolt's. There should be a little green service light flashing. Then start the APU and there should be green light's light up these light's are your input lights meaning you are getting voltage. When you chose a function on the driver control panel there should be orange light's light up witch would be your output light's. these light's wont come on if the 20 amp fuse is blown. If you need more information I'm willing to help just ask.
Nov 07, 2013 | Carrier Heating & Cooling
I have a 2007 Honda Civic 2 door bought the car found the legacy LA 960 in the trunk worked great for 1 year took on a 500 mile ride and woofer gave out. Took to a repair shop they said fuse of 20 amps...
1. Stop going to this shop.
A fuse that keeps blowing is a sign of a problem. You never replace a fuse with one of a higher amperage because the idea is the fuse is suppose to blow before the the wires melt and catch on fire. The reason it stopped working and the fuse didn't blow is probably be cause the wire did melt someplace and you are lucky the car didn't burn. If it did burn and the insurance company found the 40 amp fuse, they would probably have refused to pay.
The idea that a repair shop would do this tells me that they don't know what they are doing. Read this
FUSES
Oct 18, 2013 | Legacy Audio LA960 Car Audio Amplifier
3 amp fuse blows when ac is switched on. Heater works fine.
There is a short in the low voltage wires somewhere for sure. The most common place is the low voltage on the outside unit, sometimes animals chew through them or they get cut with a weed eater. Just my experience. You basically have to trace it back all the way to the thermostat and heater. The only other thing is the contactor
Jun 30, 2012 | Carrier 38CKC060 Air Conditioner
I have a carrier air conditioner model 38CKC024340 it cool the house sometimes, then a block of ice will form on the unit outside and it stops cooling, what could be the problem
Have you changed the air filter?
The 2 main reasons for frozen units in cooling mode 1. Not enough air flow. 2. Low on refrigerant.
You can fix #1.
#2 will require a service call.
Jun 02, 2011 | Carrier 38CKC024 Air Conditioner
My fuse box cover has numbers to show what fuses go to what, I need a list of the numbers
1. 15 AMP Dome Lamps, Power mirrors (on 2 door models only), radio memory
2. 6 AMP front washer/ wiper
3. not used
4. 15 AMP stop lamps, 4 way flasher
5. 15 AMP back-up lamps, daytime running lights, rear defrost, turn lamps and turn indicator
6. 10 AMP speed control
7. 15 AMP instrument cluster warning lamps (explorer limited model #7 is 15 AMP heated outside mirrors)
8. 20 AMP horn
9. 10 AMP air conditioner switches, clutch coil
10. 15 AMP Park/ license plate lamps, trailer tow connection
11. 15 AMP radio
12. 20 AMP cigarette lighter, flash bright lights(from signal arm)
13. 10 AMP instrument panel illumination
14. 30 AMP power windows
15. 10 AMP ABS module
16. 20 AMP premium radio amplifier
17. 15 AMP rear washer/ wiper (explorer limited model #17 is 15 AMP warning gauges and lamps, 4 wheel drive)
18. 15 AMP heated exhaust gas oxygen
that's you list. hope it helps.
Aug 26, 2010 | 1992 Ford Explorer
I have a carrier 38ckc024340 air condition condenser unit and i want to know where the capacitor is located on it?
At the outside unit where the power goes into it, there should be a cover you can remove so you can see the contactor, circuit board, and capacitor(s). Some units have 2 (1 for the compressor and 1 for the fan) while others have 1 with 3 terminals that are for both the fan and compressor. It should look like a metal can but some are plastic.
Aug 10, 2010 | Heating & Cooling
Weather King blows fuse in Criterion II furnace
You probably have a shorted wire between the heater and the a/c. There are two wires that conncet the control power to the outdoor a/c from the heater they should be on terminal c & y in the heater. disconect those two wires and try it again if the fuse doesnt blow you have a short in the wire between the a/c & heater
Jun 01, 2009 | Weather King 10AJA2501AH Air Conditioner
3 amp fuse blows on a carrier 58mcb furnace board
Hi!!! Does your ac unit work fine?If not check your low voltage problem..You have a low voltage problem check the wire going out to your condensor make sure that they are not touching..Good luck..Check low voltage wires..short in progress..
Jan 04, 2009 | Carrier 52CQ-312-4 Comfort Series Heat...
Emerson Mwg9111sl microwave blows 20 amp internal fuse instantly everytime.
check your thermal fuse its about 2 inches long white on the outside black on the inside it has 2 wires going to it check for
cotinuity becareful of the capacitor you need to disapate that first by touching the two teminals together with a screw driver
Apr 01, 2008 | LG LTM9000 Microwave Oven
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
