Question about GE WBSE3120B Top Load Washer
Won't spin except when empty, leaks.
The washer began leaking on full loads, we mitigated that by not doing absolutely full loads, but the boys came in from college and REALLY loaded it up, now if it has much in it at all it won't spin or agitate even though the motor can be heard turning, and during spin cycle it is very loud, a sound somewhat like out of balance but really just grinding noisy. What all do I have to change out, and how do I troubleshoot to limit the parts I need to replace (for example, maybe just the transmission, or both motor and transmission, or just motor, or ????) your wisdom is greatly appreciated.
  • 641 Answers
SOURCE: Loud clicking/thumping in rinse and spin cycle
It doesn't look like a motor problem !!! It seems like an unbalanced tub issue. The machin has suspension dampers and suspension rods, and it's look like one of them was damaged or "run away" from its location during machin's movement. Goog luck !!
Posted on Jun 28, 2006
jsrock516
  • 5911 Answers
SOURCE: Washer leaking
There are several things that will leak under a GE washer. The the usual suspects are drain hose connections, or hoses that have cracks or holes. I would inspect the hoses first as this would be the easiest fix. The other thing that can causes problems is the wash tub seal on the bottom of the tub. If the spanner nut (under the agitator) comes loose, the seal will unseat and the tub will begin to drip (I've had this one happen to me). Another cause can be the wash tub itself (I've also experienced this one). Inspect the wash tub for cracks. The tub can develop stress cracks and begin to leak. Especially if this is a washer that was involved in a move. To access the inside of the machine, the front should come off by pushing under the front lip of the machine with a putty knife. There are metal clips that hold the front to the top. Look in the crack with a flashlight to locate them. Push in with a putty knife to release and the front should just come off. I hope this helps you.
Posted on Jul 06, 2007
gittos73
  • 244 Answers
SOURCE: very loud washer during spin cycle
it will be your bearings not the belt or pulle you can check this out by having it empty open the door place the palm of your hand on the outside were the top of the door closers to place your fingers ti the inside of the top of inner drum and pull your fingers towards your palm if there is the slightist movement than the bearings need replacing
Posted on Aug 22, 2007
fanny
  • 146 Answers
SOURCE: Everything is working except the spin cycle
Sounds like the spin coil/brake solenoid is burnt out or broken. This is a coil situated on the motor plate under the machine with a lever attatched to it. When the machine goes into spin cycle, this solenoid pulls the brake away from the outer drum to allow the drum and agitator to spin together. The shaft that goes into this coil should move in and out freely. If tight, replace spin coil/brake solenoid.
Posted on Oct 31, 2007
  • 7 Answers
SOURCE: Washer won't agitate or spin out.
Well it is ethier Belt, Cluch ,motor ,Or transmission. But it does sound like your transmission . The loud clunk is the brake in the gear case ( Trans.). It might have broken off.
Posted on May 05, 2009
Mav4757aww leaks water during spin cycle with full loads only
Thanks for the quick responses.Pulled front cover,ran a load on high level, no leaks .Ran a load on super level and when drum spins when full of water water level rose and poured out of left front side on top of drum. Pulled plastic ring on top of drum and and found piece of seal missing where leak occured .Ordered upper tub seal, should solve problem
Jul 27, 2012 | Maytag Ensignia MAV4757AWW Top Load Washer
Spins slow, does not drain and leaks a little.
SOUNDS LIKE MIGHT BE SEAL LEAKING WILL NEED TO DO BEIRINGS AND SEALS
Jun 17, 2012 | Maytag LAT2300 Top Load Washer
We put a heavy blanket in the washer and the load stopped suddenly with a washer full of water. It wouldn't spin or empty and made a weak sound but nothing worked. We had to manually empty the water....
Usually that means the drive belt is loose and slipping. You should be able to tighten or replace the belt.
To test the belt you have to remove the washer back.
Jul 29, 2011 | Kenmore Washing Machines
We had this unit for about 4 years. We've just recently moved and brought our washer with us and now we have a leak that is showing up on the floor. The unit is working fine except for this leak. What do...
sounds like someone may have disturbed the drain hose or pump, tilt the washing machine forward and look for wet spots underneath when it is empty of course.
Feb 09, 2011 | Kenmore Oasis HE 27082 Top Load Washer
Leaking water on spincycle
I have the same problem with my washer. The problem just began a few weeks ago. It is splashing out the front left corner of the tub and running down the inside of washer and then leaking out the bottom of the frame. It is just enough water to be annoying. The washer is about 6 years old.
Model: FAV6800AWW
Serial: 11277017EG
Any ideas??? Help!
Jul 27, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Water leaking out the bottom load rumbling while spinning.
Oh boy.. You most likely have a defective rear tub bearing that caused a seal failure and the resulting water leak. Try to avoid using standard detergent in your next front load machine.
You are looking at a very expensive repair.. I'm sorry.
Jun 12, 2010 | Frigidaire ATF6000ES Front Load Washer
I have a top-load washer that began leaking at the front of the unit. The water is dripping from the front-center of the machine. It begins leaking immediately upon filling and will continue to leak for...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Check the area for the motor and pump.
If you've checked the hoses to and from the pump the problem points to either the pump itself or to the Centerpost gasket.
Neither of these is too difficult to replace, the Gasket requires removing most parts of the washer although the pump is an easy replacement.
Sep 23, 2009 | Kenmore Washing Machines
Fisher Paykel Gw11, leaking, loud noise, not going through cycle
pump is a common fault and easy to change for about $25. all sound related. new machines are pretty inexpensive. your call
Aug 23, 2009 | Fisher and Paykel GWL11 Top Load Washer
Eco smart won't drain, smells hot
hi
you commented on hearing water in the machine after the wash , i know that f&p spin bowls have a liquid inside the actual spin bowl system i think it aids in the spin operation of the machine, but if you had something in the drain network then that will stop the machine from emptingout as it all works on a time basis check and see that you are not getting any leaks from the bottom of the machime as your new pump won't last long if it gets wet also if there is water leaking that can be the main seal on the motor shaft failing
cheers grant
Oct 19, 2008 | Fisher and Paykel GWL11 Top Load Washer
GE WBSE3120B Top Load Washer Logo
44 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
