Question about MPC Computers Netframe 620 Server
Install dell sco
Hello there, recently i 'm trying install the same version (SCO 6.0 O.S) on DELL PE 620 where the DISK controller are two, PERC H310 and RAID H710. All for SAS hard disk. There is my story: I had made parcial installed SCO Opensource 6.0 using librery's and extensions i found into sco.com support sites and many others (LSI megaRAID...etc..) in this DELL version. My installation recognice and install sco 95% into disk. Just 5% beford the Goald, there is comming always the following CONFLICT: "idmkunix: error conflict: int=0, vec=4, conflict=4, between=6, device=0..." This is the POINT WHERE I'm stock, I have a SIMPLE IRQ conflict (vector 4 i know it is similar at COM1 serial port).., The solutions was easy in old Dell models, as you know the jumper or CMOS disabilitation was enough,'i'm right? BUT THIS DELL 620 MODEL I can't does that, for 2 reasons: There is not exist phisical JUMP ajustment into mainboard and/or there is not exit any CMOS configuration (or I can't find it) arrangement, as you know DELL have BIOS FIRMWARE Software... Any solution sugestion of this? thank you so mouch in advance.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,226 Answers
Did you try to take out the battery and replace it with a new one yet?
Posted on Nov 02, 2013
3 Suggested Answers
dkammeyer79
  • 92 Answers
SOURCE: hi, i have a MPC
You will need to use the F2 option during the initial loading process to load RAID drivers for whatever RAID controller your hard drives are connected to. You caould probably get around it by installing an internal IDE hard drive and loading the OS to that too
Posted on Mar 01, 2011
  • 34789 Answers
SOURCE: need hardware support disk for mpc netframe 620
Try to obtain a disk from MPC
Posted on Apr 21, 2013
How to install sco openserver 5.0.6 enterprise editon in sata hard disk in intel core 2 duo processor.
1. For better compatibility with new hardware, try 5.0.7. for best compatibility, move to 6.0. 2. Look in your CMOS setup for SATA controller options. You must use "Legacy" or "Compatibility" mode. 3. You must use a disk 120gb or smaller. While you can probably install successfully on a larger disk, you will get file and data corruption.
There are other considerations, most of which you can find out about on SCO's website - Support - Knowledgebase.
Jun 19, 2011 | Sco OpenServer Enterprise System 5.0.6...
What can window does it take
I have loaded windows 2003 server on this but the following OS are supported:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=3279705&lang=en&cc=us&prodTypeId=15351&prodSeriesId=316537&taskId=135
Microsoft Windows 2000
Microsoft Windows NT 4.0
Microsoft Windows Server 2003
Novell NetWare 5.1
Novell NetWare 6.0
Novell NetWare 6.5
OS/2
Red Hat Enterprise Linux 2.1 (x86)
Red Hat Enterprise Linux 3 (x86)
Red Hat Enterprise Linux 4 (x86)
Red Hat Enterprise Linux 5 Server (x86)
Red Hat Linux 7.2
Red Hat Linux 7.3
Red Hat Linux 8.0
SCO Open UNIX 8
SCO OpenServer 5
SCO OpenServer 6
SCO UnixWare 7
SUSE Linux Enterprise Server 7
SUSE Linux Enterprise Server 8
SUSE Linux Enterprise Server 9 (x86)
Dec 25, 2010 | HP Compaq ProLiant ML350 G3 Server
I have a Compaq Proliant ml370 G3 with an HP smart array 641 controller that I am trying to load SCO open server 5.0.6 on. This is tied to three drives in a RAID 5 config. When I try to run the Smartstart...
SSCD is not supported for the installation of SCO 5,6,7 or 8 you may need to create the arrays using ORCA at the bios of the 641 controller at post and then install SCO directlly from the installation cd.
To access ORCA press F8 or F9 when the smart array controller is posted at the bios screen
Sep 21, 2010 | HP Compaq ProLiant ML370 G3 Server
Can i burn cd on sco unix host version
Yes.
You can use burncd or cdrecord. The source files may be downloaded from SCO's site and compiled:
ftp://ftp2.sco.com/pub/skunkware/osr5/fileutil/cdrecord/
David
Apr 20, 2010 | Sco OpenServer Host System 5.0.5 for Unix ...
Windows 2008 r2. cannot find SAS HDD during install. I have tried to use drivers from Delll official site. But it doesn't help.
What RAID controller are you using? Also, you must first configure RAID in CTRL-C (SAS 5/6) or CTRL-R (PERC 5/6) before even loading the driver will help.
Mar 18, 2010 | Dell PowerEdge 2950 (becwfk1_6) Server
Can I install sco open server 5.0.5 on poweredge server 2950 which is having PERC 6/1 raid controller
Hi ,
You can move a program from sco openserver 5.04 to newer platform it supports RAID controller.
Jan 27, 2010 | Dell PowerEdge 2550 Server
Our sco unix server was shutdown dut to power failure,now when we turn on the server it ask for root file system floopy, is it possible to download rootfile system of sco open server 5.0
I think you will need the original disk for this - its going back a bit but I think this is a security disk that was created at install...I hope you've got it somewhere...
Jul 10, 2009 | HP Compaq ProLiant ML370 G3 Server
Beeping PowerEdge 1300
When a Dell server beeps in every 3-5 second that mean it comes from Raid controller.
Dell calls PERC Controller.
It usually reason of a disk failure.
Install open manage server administrator on your server.
See which disks are failed ?
Try to run Power edge diagnostics on the failed disk.
If it passes the test reseat the disk.
if it fails disk has to be replaced with a new one.
If passes the quick test, reseat the disk and update disk + perc firmware and driver to the latest level. that will solve the problem!!
99% beeping comes from perc controller because of a failed HDD
cheers
Aug 18, 2008 | Dell PowerEdge 1300 Server
Constant beep on poweredge 840 appears to work alright
Hi
Besides standard beeps codes indicating Processor, CPU, Memory or Systemboard failures,
Dell PERC (PowerEdge Expandable Raid Controller) or SAS Controllers (Serial Attached SCSI) generate beeps to alert failures on the RAID sub-system.
From your description of the issues (when the beeps start), i suggest you check PERC or SAS setup. If you have Dell OpenManage Server Administrator installed, you can log-in and check for more information. Additionally, on the next reboot check the PERC/SAS/CERC boot up for any messages. You may also access the PERC (Ctrl+M), SAS (Ctrl+R) CERC (Ctrl+A) Management Menu for specific failures and attempt a rebuild (assuming you have a redundant RAID Volume).
You can also speak with Dell Support and raise a warranty call if the system has warranty.
Note: PowerEdge 840 would ship with PERC or SAS Controller. PowerEdge 700 will ship with PERC or CERC.
Mike
Apr 02, 2008 | Dell PowerEdge 700 Server
MPC Computers Netframe 620 Server Logo
80 people viewed this question
Top MPC Computers Computers & Internet Experts
Lee Durbin
Lee Durbin
Bee Santiago
maverick4lye
Level 1 Expert
Are you a MPC Computers Computer and Internet Expert? Answer questions, earn points and help others
