Question about Garden
Lawn tractor 917 288260
Will turn over will not start
  • 63 Answers
SOURCE: lawn tractor will not start
It sounds like a stuck or unhooked safety switch. Make sure you have the blades disengaged first, then check the safety switch on the blades.
Please rate if this helps-
Posted on Mar 29, 2009
  • 110 Answers
SOURCE: craftsman riduing tractor turns over but won't
If you have spark and compression, the only thing left is fuel.
Check that fuel is being deluvered to the carb (remove fuel line to carb and make provision to catch ejected fuel. Crank engine. Fuel should be pumped from the tank and out the open line at a good rate.
If this checks out (or there is no pump fitted, but there is fuel issuing from the pipe), check the electrical connector on the bottom of the carb. There should be battery voltage on this conection for the engine to run - if not - that's the problem.
If that checks out, the cut-off solenoid (fed by the connection you just checked) is suspect.
Posted on May 09, 2010
wadembly
  • 513 Answers
SOURCE: 16 hp lawn tractor won't start; replaced battery
starter cylinoid is bad i almost bet
Posted on Jun 27, 2010
Testimonial: "Fixed it in now time. Thanks for your help."
  • 19 Answers
SOURCE: 42 in. Deck 19.5hp Lawn Tractor: Craftsman Lawn tractor my engine clicks but will n...
battery has a low charge or the starting gear on the starter is bad. just remove cover and see if the starter ingages and cranks the fly wheel. look at the gear itself to make sure the teeth are good ,if not replace the plastic gear. takes 5 min.
Posted on Jul 19, 2010
  • 5 Answers
SOURCE: My lawn tractor has started going backwards. How
manual ...www.LRNelson.com
Posted on Jul 28, 2010
Solenoid clicks but starter does not kick in to start tractor
Clicking Sound While Attempting to Key Start - Riding Mower
troybilt.custhelp.com/.../clicking-sound-while-attempting-to-key-start---r...
Jul 19, 2002 - Why does the tractor make a clicking sound and not start? ... Thesolenoid connects the battery to the starter motor when the solenoid is energized. ...It can click, but not make a complete connection. ... Starting - Riding Mower · Professional Shop Manuals · Basic Troubleshooting - Lawn & Garden Tractors.
How Do I Tell If the Starter Solenoid Is Bad on My Kohler ...
homeguides.sfgate.com > Real Estate Advice > Basic Real Estate Advice
Most large Kohler engines on riding lawn mowers use an electric starting system. ... A bad solenoid can deny electricity to the starter motor and prevent engine startup. ...Lawn Mower Will Fire but Not Start · Replacing a Solenoid on a Craftsman Lawn Mower or Tractor · How Does a Starter Solenoid on a Lawn Mower Work?
My Bolens lawn tractor won't start. It just clicks when I turn ...
Dec 03, 2015 | Garden
Lawn trc murray 17.5 hp 42in cut
my specialty,but,you didnt post what the problem is,so,here goes,if it wont start,it is probably a bad safety switch,take the small black wire off of the coil,if it starts,then its a safety switch,if it doesnt then it is the coil,if it only clicks with a charged battery,it is the solenoid,turn on your key and short between the two big bolts on it if it starts it is bad,if you need a belt,i will need the numbers under the seat,otherwise i will try to find them for you,i will post a user manual for you here, Murray 425607x52A 42 34 Lawn Tractor Parts
Murray 425016x48A 42 34 Lawn Tractor Parts
Murray 425306x48A 42 34 Lawn Tractor Parts
Murray 425600x48A 42 34 Lawn Tractor Parts
Murray 425618x48A 42 34 Lawn Tractor Parts
Murray 42560x52A 2000 42 34 Lawn Tractor Parts
Murray 42820x24A 1996 42 Inch Cut Lawn Tractor Parts
Murray 425619x24A 42 34 Lawn Tractor Parts
a few manuals,find yours here or go here to find it by the numbers under the seat,all part numbers are in them, Search eReplacementParts com
Apr 24, 2015 | Murray Garden
My LT 2000 lawn tractor starts to turn over but turn once than stops. What is wrong?
Dead battery ... replace it ... at best, you will only get 2 years out of this size battery.
Mar 08, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Difficult to start -- bad kill switch?
You have 3 safety switches located on the tractor, any one of which can cause the tractor to not crank over.
I assume the deck lever is not engaged, you are sitting in the seat and you push the clutch down when trying to start?
Start by lifting the seat and disconnecting the seat switch, push the clutch in and try to start.
Start there and we'll go from there.
Regards,
Aug 21, 2009 | Craftsman Garden
I cant shut off my lawn tractor with the key
I actually had the same problem with my tractor and it turned out to be that I had to run a second ground wire (ground to a separate point) that forces the coil to ground). My suggestion is to remove the flywheel cover and attach a wire (at a different point) to the coil and then start the tractor and when you go to shut it off. Turn the key and then just find a metal point on the tractor to touch the wire to and hopefully the tractor will shut off.
Jul 22, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Won't start
it sounds like the battery doesnt have enough crankinc amps. thats a pretty big engine and should have probably have atleast 250 cranking amps. its possible the starter is going bad also
May 03, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Lawn tractor will not start
Mar 28, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
