Question about Dryers
Whirlpool le570 need to replace can you give me the specs on the le570m?
How to change the internal light?
Hi Tony
Well, if the manual says nothing then I'd give it a go yourself.
Not sure about your particular unit. So.... it's up to you....
I found that my light was simply covered by a plastic lens plate. I flexed it slightly and it opened up. Others have a single screw to remove so that the lens moves to one side.
Then I reached inside and turned the bulb & remove it.
It was a low wattage bulb rated at the same voltage as the AC wall voltage. But it's often stamped on the side. Just match up the same base type and specs.
Is this your Microwave
Whirlpool Microwave Bulb Replacment
Hope this helps!
Good Luck
Jul 08, 2015 | Whirlpool Microwave Ovens
I have a 2006 accord lx v6. I'm changing the automatic belt tensioner assembly. I need the torque specs for the lower and center bolts for the tensioner assembly. Thanks Eddie
i cant find information on alldata they give me all the info to replace tencioner but no torque specs i give a list 40 nm
Oct 24, 2014 | Cars & Trucks
What are the dimensions of Whirlpool Fridge Model ET18GKXGW01?
You would be safe if you used the current dimensions for todays
18cf Top freezer ref. 28" w x 67.5" h x 31" d
You are right no published spec's left too old I guess?
May I suggest measuring the space allowed for the fridge?
Jul 27, 2014 | Refrigerators
Specs for drain pump model LXR6232EQ0
It wont pump that high, well it will BUT when the pump stops it will drain all the water back into the machine or it will give you an error that it is not able to drain fast enough. The only thing that might work it the installation of a check valve.
Jan 30, 2014 | Whirlpool Washing Machines
Need to replace head gasket and require Nissan Patrol Y60 TD42 engine Head bolt torque specs
I frequently use and highly recommend registering for free at www.autozone.com Your registration gives you access to a variety of repair and shop manuals, most giving you detailed repair instructions diagrams and specs.
Jul 21, 2011 | Nissan Pickup Cars & Trucks
Need timing specs. 1997 toyota rav4
Chuck give toyota parts dept a call the can fax or print you a copy for your file make sure you have your vin available
Jan 27, 2009 | 1997 Toyota RAV4
I need the part number of the belt for whirlpool awz410
go to the whirlpool website and in the support section type in your model # and it should have all your specs.
Dec 05, 2008 | Whirlpool AWZ410 Front Load Washer/Dryer
Dryers Logo
Top Dryers Experts
