Question about Kitchen Appliances - Others
Assemble a stiffel floor lamp
I took the lamp apart to change the light socket and didn't expect the bottom to come apart now I cant figure out how to put it back together so that the pole movement will turn the light on & off
SOURCE: putting back together the trimmer
I Need to kno a answer to this as well
Posted on Apr 25, 2008
  • 980 Answers
SOURCE: Installing the hook and bobbin assembly.
The plastic bobbin case should sit on top of the raceway, it should slot in quite easily, once the bobbin case is in put the small metal clip at the top over to hold it in place.
Posted on May 28, 2009
triloberto
SOURCE: Conair GMT200 Assembly
Hey dude i had the same problem n_n. Attach the screws in place and try to screw one by one gently. Soon this pressure will keep the spring tighten (instead your finger's pressure) then it will be easier to reassemble the component. I know you'll fix it n_n.
Posted on Jun 07, 2009
SOURCE: i took the weider 2250 apart 2 move it and cant
Get the manual here, follow assembly instructions...
http://www.hammerwall.com/Manuals/Weider/Description/831.159300/Weider%20PRO%202250%20Weight%20System%20Exerciser/L0312111/
Posted on Feb 02, 2010
small6363
  • 18424 Answers
SOURCE: On/Off switch button, brushbar switch button, brushbar reset arm, and springs assembly. Does anyone know how to put this back together?
go to this link for help and pictures
http://manchestervacs.co.uk/DysonForum/index.php?topic=564.0
Posted on Nov 07, 2012
I cant figure out where my lamp bulb for my panasonic model pt-56lcz70 is located so i can replace it
You have to remove the back panel of the TV - bottom portion. It is a total of 8-10 screws - just took mine apart 30 min ago. Once you do that the LIFI4000 unit is on the right side (looking at the rear of the TV). Next you must unscrew the whole electronics shelf which runs across the whole back of the TV. There are 3-5 screws on bottom and 2 above the electroics in middle of TV. Then the whole shelf will slide out. There are approx 6-8 wires you have to unplug to get the electronics out. Be careful not to mess them up. The power supply for the LIFI4000 is a separate unit and sits on top. This must be unscrewed first and then lifted off of the LIFI assembly. Not knowing how this assembly came apart i wasted alot of time unscrewing all the screws I could find to get the assmbly apart. Be careful not to lose any screws. The LIFI unit pulls out of the end of the rest of the electronics assembly.
Oct 16, 2011 | Panasonic PT-56LCZ70 56" HDTV
I cant figure out how to change the low beam headlight
You didn't say what year it was,so I will assume not
over 10 years old
In that case you remove the entire head lamp housing
to gain access to the back & the lamps you want to
check out or replace.
Jul 12, 2011 | Buick Rendezvous Cars & Trucks
I have a 97 Mercury Montaineer and i need to replace the brake light bulb, and dont know how to..can someone tell me how
Please don't forget to rate....thanks!
Exploded view of the rear light assembly used on the Explorer/Mountaineer models
The Explorer/Mountaineer models only use two upper lens retaining screws, the bottom use barbed push pins
  1. Remove the 2 (Explorer/Mountaineer models) or 4 (Ranger models) screws retaining the lamp assembly to the vehicle.
  2. Remove the lamp assembly from the vehicle by pulling it outward. On the Explorer/Mountaineer models, make sure the 2 barbed retainers at the bottom of the assembly release.
Pull the lens assembly out from the vehicle body to access the bulb sockets
Grasp the bulb socket then twist and pull it out of the lens assembly
Remove the bulb from the socket by pulling it straight out
  1. Remove the lamp sockets from the lens housing by twisting it, then pulling outward.
  2. Remove the bulb from the socket by pulling it straight outward.
To install:
  1. Install the bulb into the lamp socket.
  2. Install the lamp socket to the lens and twist it to lock it in position.
  3. Position the lens assembly to the body. On Explorer/Mountaineer models, ensure that the barbed retainers are aligned with their mounting clips, and press the assembly until fully seated.
  4. Install the lens assembly retaining screws (four screws used on the Ranger and 2 on the Explorer/Mountaineer).
  5. Check the operation of the lights.
// // 0) preLoad.src = ctl00_cphLeft_chRepairTreeNav_tvTOC_ImageArray[i]; } ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.lastIndex = 35; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.populateLog = theForm.elements['ctl00_cphLeft_chRepairTreeNav_tvTOC_PopulateLog']; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.treeViewID = 'ctl00$cphLeft$chRepairTreeNav$tvTOC'; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.name = 'ctl00_cphLeft_chRepairTreeNav_tvTOC_Data'; //]]> var _strTreeScrollHidName = 'ctl00_hidTreeScrollPos';
Jan 19, 2011 | 1997 Mercury Mountaineer
The back button is not functioning.
I will not be very helpful but I have the same problem. I took it apart, fiddled with the ribbon flex and then it worked for a while if I squeezed it hard. Then it stopped working again, I took it apart, cleaned the ribbon flex and the sockets with alcohol but it didn't help...
Jan 05, 2011 | Sony Ericsson P1i
How do I change the rear turn signal bulb on my 2007 pontiac g6 convertible
Probably too late for you, but others may benefit as I just did this.
In your trunk on each rear side panel, you will find several rubber stoppers approximately 1" wide. take a flat head screwdriver and pry underneath to loosen then pull the stopper out.
Take a socket set you and find the right size socket for your nut and take out the 2 nuts on top and the bolt at the bottom (my bottom bolt didn't have a stopper on it).
Pull out the tail light assembly. Remove the bad bulb from the back of the assembly and replace with a new bulb (look up type of bulb to buy in your owners manual). Replace hardware and test lights.
Dec 26, 2010 | 2007 Pontiac G6 GT Convertible
How to change break lights
Tail Lights
  1. Open the endgate or liftgate.
  2. Remove the screws that retain the tail lamp assembly to the vehicle.
    Tail lamp assembly removal
  3. Rotate the bulb sockets 1/4turn counter-clockwise in order to remove the bulb sockets from the tail lamp assembly.
  4. Remove the bulbs from the sockets.
To install:
  1. Install the bulbs into the sockets.
  2. Install the bulb sockets to the tail lamp assembly by rotating the sockets1/4 turn clockwise.
  3. Install the tail lamp assembly to the vehicle.
  4. Install the screws that retain the tail lamp assembly to the vehicle. Tighten the screws to 17 inch lbs. (1.9 Nm).
Oct 23, 2010 | 2000 Oldsmobile Bravada
Need to change one of the daytime running light bulbs. Cant see how to get to it.
You will need to take the tire off of the side that the light is burned out on. Then remove plastic fender well insert. This will give you the enough room to change out any burned out light in the headlamp assembly.
Jul 10, 2010 | 2007 GMC Acadia SLE
Changing blinker on 2007 Pontiac G6
It's a monster pain to get to them, but it's doable. Once you empty the trunk, you'll see 4 black knobs - approx 1.5 inches in diameter. You'll need to remove all of these (they just unscrew, but they are plastic, so be careful not to strip the threading) in order to access the rear light assembly.
They're in there snug, but once you find the appropriate sized socket (I wish I could recall well enough to tell you what size, b/c I remember that it WAS an odd size), you'll have to remove all 3 bolts and then push the whole assembly out from inside the trunk.
Once the assembly is out, you will see the rear of the sockets, which simply push and turn to get the lamps out of. As long as you have everything open, I suggest changing ALL of the lamps (brake, tail, and turn signal) on BOTH sides, since the lamp life for all of these is about the same and it's such a pain to get to them in the first place.
Mar 31, 2009 | 2006 Pontiac G6
How do I replace a taillight lens on a 1991 Geo Storm?
Rear Turn Signal, Brake and Parking Lights
STORM COUPE
  1. Disconnect the negative battery cable.
  2. Lift the luggage compartment floor carpet toward the front of the vehicle and remove the spare tire cover panel.
  3. Remove the ten plastic retaining clips from the rear end trim panel.
  4. Disconnect the luggage compartment lamp electrical connector.
  5. Remove the luggage compartment trim panel and the rear end trim panel.
  6. Disconnect the rear combination lamp assembly electrical connector. Fig. 1: Rear Turn Signal, Brake and Parking Lights — Storm
  1. Remove the seven nuts and the rear combination lamp assembly from the vehicle.
  2. Disconnect the rear combination lamp electrical connector.
  3. Remove the four bulb sockets from the rear combination lamp assembly and remove the four bulbs from the sockets. To install:
  4. Install the four bulbs to the sockets and install the four bulb sockets to the rear combination lamp assembly.
  5. Connect the rear combination lamp electrical connector.
  6. Install the rear combination lamp assembly to the vehicle and the seven nuts.
  7. Connect the rear combination lamp assembly electrical connector.
  8. Install the rear end trim panel and the luggage compartment trim panel.
  9. Connect the luggage compartment lamp electrical connector.
  10. Install the ten plastic retaining clips to the rear end trim panel.
  11. Install the spare tire cover panel and the luggage compartment floor carpet.
  12. Connect the negative battery cable.
Mar 21, 2009 | 1991 Geo Storm
Kitchen Appliances - Others Logo
177 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
