Question about Garden
My Ariens A22A46, has the automatic trans. The part on the top of the trans that activates the trans when the pedal is pressed is broke. The part is not in my manual. I need to know the name and part number.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 344 Answers
The transmission is made by General Transmission. you can call them for parts: North America Head Office : General Transmissions, Inc 2345 Hudson Blvd - Brownsville, TX 78526 - USA T?l (+1) 956 541 3443 Fax (+1) 956 541 9941 Best, Joe My Ariens A22A46, has the automatic trans. The par - 1_31_2014_3_10_43_pm.png
Posted on Jan 31, 2014
My Airens riding mower won’t go foward or backwards . But it runs fine!
Ariens A22A46 will not go forward or reverse
Reasons Riding Lawn Mower Won Go Forward or Reverse Hunker
If this doesn't help, you might try posting the query with the Airens model number. There might be a service manual available, as well.
Nov 25, 2017 | Garden
Blades will not engage on Ariens A22A46
Some Ariens mowers have electric clutches. You can check for it and wiring to it. Maybe a wire is disconnected, wore thru etc. It sounds like it's not engaging.
Oct 14, 2016 | Ariens Garden
Car will not move when it is in gear and gas pedal
your trans may have broke the planetary gear and does not engage.
Aug 28, 2014 | Cars & Trucks
Blades do not turn on Lawn Tractor Model 1548H
is the an electric cluch or just an activating lever
belt may be broke
clutch not engaging
belt off
Oct 14, 2013 | Ariens Garden
Top gear broke on top of starter
some starters the gear is held on with a span ring and some with a roll pin
Sep 28, 2012 | Ariens Lawn Mower Universal Solenoid...
What is the ignition immobilizer on a 2000 accent
Hello William. On standard transmissions you have to press down the clutch to start the car, and on automatic transmissions you have to press down on the brake pedal in order to start the car. Look for your immobilizer under the dash at clutch or brake pedals depending on trans. Hope this was helpful, GOOD LUCK.
Oct 07, 2011 | 2000 Hyundai Accent
Brake lights not working when i press brake pedal
test the brake light switch which is located at the top of the arm the brake pedal is attached to, there should be 12 volts at both sides of the switch when the brake pedal is pushed.
May 31, 2009 | 1979 Pontiac Firebird
Not going into gear
have you checked your brake lights? are they working? most cars have a safety feature that require a signal from brake lights (by stepping on brake pedal) to activate a relay to disengage the shifter interlock, OR can you move the gear selector into gear, and it just won't move? is it an automatic or stick shift ? If it's an automatic start the car, after it has ran for 5 - 10 minutes check the trans fluid dipstick, it should have fluid level between add / full marks , if not add or remove fluid as necessary. If is a manual trans, it is possible the clutch is bad. need more info on vehicle, how many miles? engine size?
May 31, 2009 | 2000 Hyundai Elantra
Garden Logo
647 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
