Question about Foxconn Dell Vostro 400 Motherboard , G33m02
OEM G33M02 manual pdf www
Need to know all sata ports for
Manual for Foxconn G33M02
Hi you can find the manual here
http://www.foxconnchannel.com/driverdownload/Motherboard/Intel/Socket775/G33M/manual/Easy%20Guide/%283A2505E00-000-G%29-G33M_easyguide.pdf
Feb 06, 2013 | Foxconn Dell Vostro 400 Motherboard ,...
How to activate the VGA monitor port on motherboard Foxconn g33m02?
You need to use DVI to VGA convertor but mostly it is recommended to use a dvi compatible monitor. VGA wont work. Im pretty positive
Feb 01, 2013 | Foxconn Dell Vostro 400 Motherboard ,...
CAUSES BLUE SCREEN OF DEATH
It's most likely faulty, swap it for a new or know good unit and test this is the only way to tell. It's that or the SATA port itself, but that's unlikely.
Oct 12, 2011 | LG GH22NS50 22X DVDRW SATA Drive OEM...
I have a compaq evo w8000 desktop and want to install a sata drive instead of the built in scsi drive. I can install windows xp (i've got the sata card drivers and pressed F6 etc, that all works fine)...
ok a very very old DT , desk top, ive done this vast times, back long long ago... 17 years old, you use this old of hardware why?
we dont use XP in uSA its VIRUS magnet. horred
and no updates, now, means will get worse each day forward in time. endless...
has built in, SCSI chip. l Ultra160 SCSI and Ultra ATA/100
that ATA means PATA port, not SATA back then.
my wild guess now is that someone put an a new SATA card in the PCI slot, (ive done so vast times)
The BIOS in your machine will never support that.
that means you can not boot to PCI SATA. for sure.b
but wait, the better SATA card works just like a new Adaptec
ultra160 card that if love.
the new SATA card has what is called a BIOS extension ROM on said card, and a new HOT key to access it.
some are CONTROL +A but each maker of said card ,does as he pleases, so READ THERE MANUAL.
you set it to boot o STAT port and it does if port 0 is bootable drive. SATA.
here ill take you now to newegg.com and show you hardware that works.
if you showed a photo of your CARD and # id have answered, 10x better. !!!!!
i cant shop for you, nor pick SATA 1 ,2 or 3 for you.
but here
https://www.newegg.com/Product/Product.aspx?Item=9SIAC0F5KW5808&cm_re=sata_card-_-9SIAC0F5KW5808-_-Product
the big trick here is making sure you relic MOBO
supports the current levels of PCI>
like above
32-bit / 66MHz PCI interface compliant to PCI Rev 2.3
(Backward-compatible with PCI 33
https://www.promise.com/media_bank/Download%20Bank/Datasheet/FT_TX2300_DS091406.pdf
Control +F (see page 11)
https://www.promise.com/media_bank/Download%20Bank/Manual/FastTrak_TX_Series_User_v3.2.pdf
warning, ive run in to big problems using very old relic
motor-boards that use the very old PCI signals and levels.
and will fail on some newers card
I warned you,
the above reads good. for that. (hope )
now my question why use such old hardware.
when goodwill has truck loads of 10year old pCs for $20
why, love of XEON?
id trash it.
find a use desktop with SATA ports, ALL DO now, or scrapped.
May 08, 2017 | Compaq Evo Workstation W8000 PC Desktop
SATA Drive on MSI K8T Neo upgrade hard drive. More detail.
Sata drives are backwards compatable so should work no problem but some drives have a jumper that needs to be reset ,check the website for your drive.
Aug 10, 2009 | MSI K8T Neo-FSR Motherboard
Need to replace existing CPU and want to upgrade.
Dell's web site provides all of the technical documentation for your computer.
Apr 25, 2009 | Dell Inspiron 530 Desktop Computer
Does a Foxconn 633 m02 motherboard have pci express slots?
You have a Foxconn G33M02? then you have PCI express ports, so you'll need to look at pci express video cards to fit on your pci express x16 ports (the long pci-e port, probably blue colored) on your motherboard.
Jan 03, 2009 | Foxconn VGA FOXCONN 8500GT-512 R PCI...
HDD Installation
Hi gravni,
The bios (MUST see the drive). If the bios does not see the drive neither will windows!
The down below port (as you mentioned) is for IDE devices. IDE1 by name. Use your ATA IDE port for the slower IDE drives or cd-rom drives. (This board does not have a second IDE port).
If the WD drive is a SATA drive connect it to the SATA 2 port. See your manual. Go to page 1-4.
As show in this pic below.
2711d19.jpg Is the WD 500Gb drive SATA or IDE?
It's suggested when adding a new drive into a working system, the user should setup the drive by using the manufactures guide. Click on this link & download WD's pdf file:
http://www.wdc.com/en/library/sata/2079-001042.pdf
You mentioned the drive is hot. This only means it is running.
Include in this post the model number of your WD drive? So I can check the specs.
Mike
Oct 28, 2008 | MSI P965 Platinum Motherboard
Foxconn Dell Vostro 400 Motherboard , G33m02 Logo
52 people viewed this question
Top Foxconn Computers & Internet Experts
David
David
Gareth Cockram
Gareth Cockram
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
