No sound from speakers but radio is on
    New Friend:
    Problem Solver:
  • 9 Answers
Check they might be disconnected
Posted on Jul 11, 2013
I have a 2000 oldsmobile alero and I can't get sound out of my rear speakers good speakers and connection just no sound
OLDSMOBILE ALERO 2000 speakers - Sonic Electronix
www.sonicelectronix.com/oldsmobile-alero-2000-car-speakers.html
OLDSMOBILE ALERO 2000 speakers - find speakers that fit your ... sound. This size is capable of delivering exceptional mid-bass that can't be found in smaller ...
2001 Oldsmobile Alero Car Radio Stereo Audio Wiring ...
www.modifiedlife.com/2001-oldsmobile-alero-car-radio-stereo-audio-wi...
Easy Plug and Play Wiring Adapter. ... 2001 Oldsmobile Alero Car Radio Stereo Audio Wiring Diagram ... If you can't find your car audio wire diagram, car stereo wire diagram or car radio ... Right Rear Speaker Positive Wire (+): Dark Blue ... olds alero and I have replace the stock stereo and have found that the sound out put ...
Request a Oldsmobile Car Radio Stereo Wiring Diagram
Jan 21, 2016 | Oldsmobile Cars & Trucks
Radio has no sound
First check whether the connector for the speaker wires is firmly plugged in behind the radio. Try unplugging and replugging to make sure. (Note: the connector may be attached to the radio or it may be on the end of a short length of wire.)
If the speakers are firmly plugged in and you still don't get sound, the next step is to test the speakers. Do this by unplugging the wires behind the radio, then run a meter across one pair (for one speaker) to make sure you don't have an open circuit (broken connection). Alternatively, feed audio from the speaker outputs on a boombox or other stereo to that pair of wires. If you don't get sound or if the meter says there's an open circuit or direct short, either the speakers are bad or there's a broken wire between the radio and the speakers. Most bad connections happen at one end of a wire or the other, so look at the connectors at the radio and at the speakers.
Finally, if the speakers do check out, you'll have to test the car radio itself. Run a pair of wires for one speaker from the radio's outputs to an external speaker (any working speaker will do). If there's no sound, your radio is broken.
Of course, the easy way to do this is take it to a place that installs car radios. They can check it out quite easily and make recommendations. Don't take it to a Chevy dealer. They'll charge you a fortune, and if the radio is bad, they'll sell a refurbished unit for more than you'd pay for a high-end Kenwood or Pioneer.
Oct 08, 2014 | 1998 Chevrolet Cavalier
Dennis my 1995 lincoln towncar JBL radio quit producing sound the system comes on fine but I get no sound could u help me please, what is the problem?
The Amp in the trunk might have blown,
Town Car Radio Wire Diagram
Car Radio Battery Constant 12v+ Wire: Pink/Light Blue
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: Blue/Red
Car Stereo Antenna Trigger Wire: Blue
Car Stereo Amplifier Location: Trunk
Car Audio Front Speakers Size: 5? x 7? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Car Audio Rear Speakers Size: 6? x 9? Speakers[img src="http://www.assoc-amazon.com/e/ir?t=modilife-20&l=as2&o=1&a=B00009UHRE" width="1" height="1" border="0" alt="">
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Check the fuses
24851106-prgqozi4aluuon54ixeydqz4-5-7.gif 24851106-prgqozi4aluuon54ixeydqz4-5-0_0.jpg
Jul 20, 2014 | 1995 Lincoln Town Car
No sound from speaker but through ear piece I get sound.
Many devices will automatically switch off the large speaker when ear phones are plugged into them. Also there may be a switch or button or prompt on your radio to switch between regular speaker and ear phone jack. Look for that first.
Try connecting and disconnection ear phones while listening to a station and see if the problem is intermittent. If is works sometimes but not every time then it is most likely an internal connection.
You will have to access the inside of the radio to investigate further. Connect a working external music or sound source with speaker wire to the terminals inside the radio that connect to the radio's speaker. If the radio's speaker works with the external sound source then you know it is a bad connection inside your radio. If the radio's speaker does not work with the external sound source then it is most likely a faulty radio speaker. Look closely for a broken solder point or broken/disconnected wire.
Sep 10, 2013 | Eton E100 SW/FM/AM Radio
Car radio has no sound
When you have no sound on the radio the first thing to checkl is the speakers. Using the smallest voltage battery you can get hold of and handle easily (AA or AAA) conect +(ve) and -(ve) terminals of the battery to the 2 speaker connections. If the spreaker is OK it will produce a cacling sound. If non, replace.
If speakers are OK the trace connection from radio/amp to speakers. If OK then radio needs attention.
Aug 29, 2012 | Mercedes-Benz Cars & Trucks
My radio worked when I bought my truck but now it turns on but will not play any sound to the speakers
Park your truck in a silent place (best time to do at night) ask someone to get close to any speaker and in a silent place and turn on the radio. When turning on there should a slight "click" sound in the speaker. If there is a click sound then tune to other radio station and try if still no sound then there is a problem with your receiver circuit. If there was no click sound then either:
Your radio amp circuit is gone or
Wire connecting speaker are broken
You can trace the broken wire by physically checking the wire from speaker to head unit, if its fine then your radio needs repair.
Jun 09, 2011 | Pioneer Premier DEH-P410UB Car CD/ MP3...
I have a 2008 Hyundai Tucson with the premium sound package. The first radio was replaced by the dealer as the radio has no bass at all. The treble even turned to the lowest setting pierces my ears. The...
Try replacing the factory speakers with a better quality speaker. make sure you listen in a sound room before you have them installed. make sure you like the sound of the new speakers before installation. also have the radio tech listen to your car to make sure radio is ok
Feb 12, 2010 | Car Audio & Video
Radio wiring diagram for a 96 thunderbird with premium sound
1996 Ford Thunderbird Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Black/Orange
Radio Ignition Switched 12V+ Wire: Yellow/Black
Radio Illumination Dimmer Wire: Light Green
Radio Antenna Trigger Wire: N/A
Radio Amplifier Trigger Wire: Dark Blue
Front Speakers Size: 5′ x 7′
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): White/Green
Right Front Speaker Wire (-): Green/Orange
Rear Speakers Size: 5′ x 7′
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Gray/Light Blue
Left Rear Speaker Wire (-): Tan/Yellow
Right Rear Speaker Wire (+): Orange/Red
Right Rear Speaker Wire (-): Brown/Pink
Jan 13, 2010 | Car Audio & Video
1998 bravada has six radio speakers; two dash speakers and two in the front doors speakers plus two rear doors speakers. the front doors speakers work good but no sound come from the dash speakers or the...
Did it fail while you had vehicle, or like this when you bought it? Could be bad radio or wiring harness was chopped up when previous owners had an aftermarket radio installed. They probably just slapped the OEM radio back in when selling car. And didn't put all the OEM wiring back in.
Nov 07, 2009 | 1998 Oldsmobile Bravada
Cracking sound from Radio Speakers
I disconnected the amp and ran jumper wires for the proper speakers (two wires per speaker eight total) . Basically I bypassed the amp now all speakers work and sound fine.
Jul 10, 2008 | 2006 Chevrolet HHR
15 people viewed this question
 Grubhead
Grubhead
