Question about Garden
The parts diagram with the manual does not show the part in the break down. It's right in the center of the trans and when you push forward on the drive pedal you can see the broken piece.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 338 Answers
Http://generaltransmissions.com/en/technology/ They are the MFG of the transmission. you can call them for parts. Best Joe The parts diagram with the manual does not show th - 1_31_2014_3_13_52_pm.png
Posted on Jan 31, 2014
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Garden Master
  • 102,366 Answers
What make and model? Can you give a more informative description of the part than "broken"? Metal? Plastic? Color?
Posted on Jul 11, 2013
  • Zeb McAllister Jul 11, 2013
    It's an A22A46, it has the 22hp B&S, with automatic trans. The trans I pedal activated not handle activated. The part is on top of the trans and its plastic. It's kind of horse shoe shaped. When you press the pedal, you can see where the part is broke.
5 Suggested Answers
miket756
  • 2702 Answers
SOURCE: Replaced the drive belt.
only that you never took up the slack in the brakes,,, take it up a bit more and the brakes will work ok then,,,
Posted on Aug 14, 2010
Mr BrokRench
  • 1623 Answers
SOURCE: brand new riding lawnmower, stop on hill, set park
Sorry to hear about your problem...you aren't the only one having it. Sounds like a hydrostatic problem or a pulley freewheeling on a shaft somewhere. If you bought your tractor at Sears they might could help you---the husky and are the craftsman are the same. Husky uses a little better engine is all. Hope this helps.
Posted on Jul 11, 2011
ccdcoll35
  • 21 Answers
SOURCE: I need the diagram of the deck on a poulan 42 inch ride mower
type in the name and brand of your lawnmower in google and then look and see if it is yours
Posted on Nov 02, 2011
  • 6468 Answers
SOURCE: Murray no forward drive - reverse ok
check the linkage adjustment on the pedal you might need to check the rod bushings as well
Posted on Jul 15, 2012
I have the Frigidaire Model BFHS2611LMO Side by Side and the handle on the right side is very loose. I took off the rubber seal on inside of door but dont see any screws to tighten. How do I tighten
The model number is actually BFHS2611LM0. The handles have keyhole openings that fit over the pair of screws (near the top and bottom of the handle) on the outside of the doors. Try pushing the right side handle forward and down to lock it back onto those screws. If that doesn't solve the problem, push the handle up and then lift it off the screws. Then tighten the screws a bit (or replace them if they have stripped threads). Then replace the handle over the screws and push the handle down. Do not overtighten the screws; that can damage the door components. The manuals is available from Frigidaire's support site: http://b2b.frigidaire.com/support/manuals.asp . The support page for your refrigerator is here: http://b2b.frigidaire.com/support/ResultsPage.asp?strModel=BFHS2611LM0&User=&Search=Search . The parts diagram shows how the handles are attached; it's the last link on the support page.
I hope this helps.
(please replace the door seal properly to ensure that your refrigerator maintains it's efficiency. http://www.searspartsdirect.com/frigidaire-refrigerator-parts/model-BFHS2611LM0/1428/0165000.html has another copy of the parts diagrams with the parts for sale.)
Jul 28, 2015 | Frigidaire Refrigerators
Does anyone have a diagram for the passenger side fender assembly on a 2007 Toyota Corolla LE? I've looked and looked (obviously I can't afford a manual right now) and cannot find a diagram that shows
Go to this site put in your info.click on body parts and then you should se fender in red click on that and it will show you a break down .https://parts.olathetoyota.com/toyotacorollaparts.html
Jan 27, 2015 | 2007 Toyota Corolla LE
1992 Pontiac sunbird was in some high water now clutch is stuck how do I break it loose?? HELP!!
probly need to get it to a good trans shop for test drive--water has messd it up--othr parts of car may hav similar issues-no long trips til
Dec 09, 2013 | Cars & Trucks
Ford F250 6 speed transmission
We don't have access to that
If your asking for parts break down &
diagnostics--- then go to ATSG.Com or a
local trans parts wholesaler & buy the
atsg books for that unit trans
Oct 06, 2012 | Cars & Trucks
Transmission oil found in radiator
there is a cooler for the trans fluid that runs threw the f the radiator the cooler splits and trans pressure being higher while running pushes into the coolant how ever as it cools down the coolant pressure can push the coolant into the trans so see if the trans fluid looks like a straw beery milk shake if so try and keep flushing the trans until the fluid is clean and fresh if the trans makes it threw the coolant then you will need to flush the cooling system i use pinesol it breaks down the oil
Oct 01, 2012 | Cars & Trucks
Where is the back-up light switch physically located? Is there a diagram available that shows the location? My Haines manual does not show it.
Hello jack isuzu
If you have a manual trans. with a 3.2 it's on top of the trans. if you have a 2.2 it's on the right side of the trans. My diagram does not show a seperate switch for the backup lights on an automatic
transmission, it may be part of the trans. gear position switch on the left side of the transmission.
Look for a red+yellow wire from the rear of the truck to the transmission, this wire runs from the
backup lights and you should be able to follow it back to the switch. Hope this is helpful.
Apr 27, 2011 | 1999 Isuzu Rodeo
I need a diagram electric washer machine GE mod S3700G0WW
go to www.sears.com and then click the parts direct link up top... type in your model number and on the right side it will ask is this part number or model click model. it will search and come up with your model if you have the correct one... should show you a diagram and parts break down...
good luck to you
Jan 06, 2011 | Washing Machines
I can't find reverse on my necchi 536fb. I inhereted the machine it's pretty old but works great. Sewing would be much easier if i had a forward/reverse button. Thx
Hi! Sewing is so much easier with a forward/reverse button! :-) I have a Necchi 536 fb also. Here's a picture of mine: efebd8b.jpg
The knob on the lower right controls the stitch length and forward/reverse. Push the center part in to get reverse and release it to go forward again.
You really need a manual for your machine--my Miss Sophia came from a pawn shop so I ordered one from relics.com (http://pages.sewing-machine-manuals.com/173/PictPage/1923115740.html) for $17.00.
I love my Necchi--you can read about her at www.robbiesews.blogspot.com if you like.
Happy Sewing!
Robbie
Apr 22, 2010 | Necchi 3101 Mechanical Sewing Machine
Stick shift
Hi:
The shift pattern is pretty much the same on all 5 speed cars. The top row is the odd numbers, 1-3-5
the bottom row is 2-4-Reverse. The center position is neutral
Here is the key: The shifter is slightly spring-loaded to the center position. If you hold in the clutch pedal and pull the shifter to neutral, and let go of it, it will automatically be lined up in the position, that if you pushed it forward , it would go to 3rd gear, and if you pulled it back, it would go into 4th gear.
This way, to start driving, you start out in neutral, grab the shifter lightly, and push it first to the left, then forward. This is first gear, where you start out. when you want to shift to second, push in the clutch, and keeping left pressure on the shifter, pull all the way back . Here is the easy part, 2nd to 3rd. When you are ready, push in the clutch, and just push the gear shift forward , till it hits neutral, and is spring loaded to the middle. Then you just push it straight forward to 3rd, then next shift, straight back to 4th.
Last gear, 5th: push forward to the neutral row, then Push to the right till it lines up ,and forward to the 5th gear. Reverse should only be shifted into from a dead stop. Find neutral, push the shifter all the way right, then pull back towards you. Hope this helps.
Practice a bunch in the driveway!
Apr 21, 2010 | 2001 Hyundai Elantra
1998 Saturn Sl 1 Won't start some times.
I could not find any diagrams.......but it may be the park lock cable.. or you could have something jammed underneath the shifter.... a penny....or some other misplaced object that can slip underneath the cracks and cause it to not go into park all the way....the center console is fairly simple to remove a few bolts and I think a couple pop rivets.... a Haynes Manual on all the s series Saturns is available at your local auto parts store (advanced auto, auto zone, Pepboys) it'll run you like 20 bucks but will definately prove helpful to you ... Im looking at mine right now and it shows you how to completely tear it down and rebuild it.
Jun 12, 2008 | 1998 Saturn SL
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
