Question about Toshiba Satellite 1800-4K1 Notebook
004k1 1800 ps183c satellite toshiba - Toshiba Satellite 1800-4K1 Notebook
How can i remove a toshiba satellite A500-01w keyboard?
try this first
a. turn over computer overnight and let it 'drip dry'
b. take a hair dryer on low heat and fan and GENTLY run it over the keyboard about 1 inch back and at angle
try that first and report back
you might get lucky
Jun 14, 2012 | Toshiba Computers & Internet
How do i turn it on ?
hello
look for a key button or on/off slide switch
Jan 03, 2012 | Toshiba Computers & Internet
Product: Toshiba Laptop, Satellite 1800 (PS183C-00HV9P)\r\n1.1 GHz, 512mb, Windows XP Pro Problem: I recently reinstalled Windows XP Pro. I am having problems with display. Videos do not run smooth - its...
The video driver is specific to the model laptop, there may be a few different video card used in the same model laptop, in this case you may need to install one at a time to find the correct driver.
You can download any/allthe Windows XP or Vista device drivers for your model laptop from the ToshibaWEB site from their download page. Make sure you enter the model of your laptopso you can get the correct drivers. Please click on these links : - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
http://blitware.com/adpages/driverfetch/manufacturer/?manufacturer=Toshiba&gclid=CMOVxNCBx6ACFSgnawodoHNGbA
Dec 05, 2010 | Toshiba Satellite 1800-S207 Notebook
Dec 05, 2010 | Toshiba Computers & Internet
How do I replace the keyboard?
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. nboulikas@gmail.com for any additional questions.
Nov 06, 2009 | Toshiba Satellite A105-S4004 Notebook
Keyboard inoperative
press and hold fn and press f11.it sounds like you activated the sticky keys
Nov 22, 2007 | Toshiba Satellite A135 Notebook
Mouse
Well, there's not too much to those assemblies. You might want to reload the drivers, pull the assembly and check for any loose parts, check to make sure there aren't any gummy bear leftovers or potato chip crumbs down in any of the cracks and crevices. If you previously used the buttons a lot, they may just be worn out.
Also, you may want to look around for a cheap used unit that you could steal the touchpad assembly out of.
Ron-
Nov 07, 2007 | Toshiba Satellite 1800-4K1 Notebook
How to Enter BIOS Settings in Toshiba Model: PS183C (Sattelite)
Press either the "Esc" key or "F1" when first turning on computer to boot up.
Jun 14, 2007 | Toshiba Satellite 1800-4K1 Notebook
Open Questions:
Ñ? меня ноÑ?Ñ?бÑ?к toshiba satellite1800 Ñ? меня ноÑ?Ñ?бÑ?к toshiba satellite1800 model ps183c-004k1 не смог найÑ?и дÑ?айвеÑ?а на эÑ?Ñ? модель. пÑ?обÑ?вал искаÑ?ь на сайÑ?е toshiba посеÑ?ийномÑ? номеÑ?Ñ? Y1070222J мне оÑ?веÑ?или Ñ?Ñ?о ненайдено. пожалÑ?йсÑ?а помогиÑ?е .... ноÑ?Ñ?бÑ?к Ñ?же Ñ?сÑ?аÑ?ел но для Ñ?абоÑ?Ñ? мне подÑ?одиÑ? . спасибо.
Feb 26, 2017 | Toshiba Satellite 1800-4K1 Notebook
Toshiba Satellite 1800-4K1 Notebook Logo
65 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
