Question about Tools & Hardware - Others
Sonitek TS500 depth
I want to find out how to adjust the depth of the TS500 machine
Does the Tannoy arena TS500 power the arena lite satellite and centre speakers or do i need another amplifier to power the satellite speakers.
The TS500 is a stand-alone powered subwoofer. Other speakers are independent of it.
Th 'Lite' is a system but only the sub is self-powered. The rest are passive.
http://www.independentaudiovideo.com/store/item_view.asp?estore_itemid=1000328
Sep 15, 2011 | Audio Players & Recorders
WHILE THREADING 4" CONDUIT THE MACHINE WILL NOT
If I remember this machine, you have an adjustable thread cutting head. 4" is a large area for a thread cut, how you can help this is by using lots of oil, and make your cut with the cutting teeth not at the deepest they can go. In other words, cut the full length but cut it shallow at first, then redo the cut a little deeper and so on till you get to the depth that you need.
Joe
Feb 22, 2011 | Ridgid 26092 1224 Threading Machine
I have been installing a treated pine deck, but the nails are been driven in to far, i have tried adjusting the pressure from the compressor but have had no luck is there a depth adjustment on the gun?
Yes, there is a depth adjustment. Most of the Bostitch models have a push button on the left side near where the nails come out. With the air unplugged, push in this button and you can slide the head assembly up or down to make your adjustment. Slide it out for less depth. It sounds like maybe yours is fully seated, providing the maximum depth.
Dec 13, 2010 | Stanley Bostitch Coil Framing Nailer
Bn125a nailer not sinking nails all the way
The depth to which a fastener is driven is controlled by the depth adjustment
knob (A) Fig. 19 below. The depth of drive is factory adjusted to a nomimal setting.
Test fire a fastener and check depth. If
a change is desired, rotate the
adjustment knob (A) Fig. 19: the
adjustment knob has detents every 1/4
turn. Rotate the knob clockwise (see
Fig. 19), to increase the depth of drive,
rotate the knob counterclockwise to
decrease the depth of drive. Test fire
another fastener and check depth.
Repeat as necessary to achieve
desired results. The amount of air pressure required will vary depending on the
size of the fastener and the material being fastened. Experiment with the air
pressure setting to determine the lowest setting that will consistently perform
the job at hand. Air pressure in excess of that required can cause premature
wear and/or damage to the tool.
Good Luck
Nov 26, 2010 | Porter Cable Cable BN125A Factory -...
I have a Brother Innovis CS8060, the bobbin no longer winds completely, only halfway, can you advise?
being a computerized machine i would take it to a service center, if this isn't an option at this time next to the post you put your bobbin on is the depth adjustment, there is a screw in the top of it very gently loosen scew and slowly rotate the depth gauge until you think it is where you want it . you may have to sdjust it a couple of times before you get it where you want it so go slowly and carefully
Nov 05, 2010 | Brother CS-8060 Computerized Sewing...
I have dewalt dc618, nail doesn't goes all the way in, please help?
Below find information on how to adjust for depth, however if you have already made adjustment then check for broken tip on driver blade. The blade is not expensive and available from dewalt service center.
Please note the following from manual:
Adjusting Depth
The depth that the fastener is driven can be adjusted using
the depth adjustment wheel (C) on the side of the tool.
WARNING: To reduce risk of serious injury from
accidental actuation when attempting to adjust depth,
ALWAYS:
• Remove battery pack.
• Engage contact trip lock-off.
• Avoid contact with trigger during adjustments.
1. To drive the nail shallower, rotate the depth adjustment
wheel (C). There are twelve depth settings, 1 being the
shallowest and 6 being the deepest.
2. To sink a nail deeper, rotate the depth adjustment
wheel (C) to a higher setting.
Sep 08, 2010 | Dewalt DC618KA Angled Nailer Kit
How to adjust adjustable depth screw setter
hello. thanks for choosing fixya. you adjust with 8mm socket or adjustable wrench. just turn the shaft as you hold onto the brass piece. make the phillips head as deep or shallow as you choose for your application.
Nov 10, 2009 | Dewalt DW2043 Adj Screw Depth Setter
Adjusting depth of blade
generally you dont adjust depth of blade, you buy the blade in different lengths to suit the job and material
Jul 11, 2009 | Black & Decker Saws
My depth finder flashes 00.0 I can not get it to work
The shallow water sensitivity adjustment is set too far to an extreem. Center the adjustment, then recalibrate at the dock.
May 24, 2009 | Uniden Qt206 Thru Hull, Digital Depth...
Tools & Hardware - Others Logo
60 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
