Question about Aftermarket 00 01 02 03 04 dodge neon 2.0l at radiator fan motor
04 dodge neon keeps blowing eatx fuse new fuel pump and filter ran a week after that and began doing the same thing HELP
Have a 1999 Dodge Avenger V6. Keeps blowing Engine Fuse under hood
Fusible link 3 feeds the PCM. the ASD relay, and fuel pump relay. Assuming it has A/T, that fusible link also feeds the starter relay, the EATX-ECM, and the EATX relay. A short in any of those elements could be causing the trouble.
Dec 16, 2016 | 1999 Dodge Avenger
97 dodge neon keeps blowing fuel pump fuse
look for a bad ground on the pump or a pinched wire on the gas tank.
Aug 04, 2014 | 1997 Dodge Neon
My fuel pump fuse keeps blowing on my 97 neon. i replaced fuel pump. no help.
What is no help ?
Surely you know what a fuse is for !
Replacing a blown fuse won't fix a thing
Have to diagnose the fuel system electrical,
to find a problem
Replaced the fuel pump why?
Was it tested & failed ?
No Fuel Pressure?
Keeps blowing fuel pump fuse. Why?
This normally happens due to short in the wirings.Or if someone has connected a stereo or some other electrical contrivance to the wiring harness (bundle), either under the dash or under the hood.To confirm this unplug the fuel pump wiring connections and insert new fuse.Then start the car and see,if still the fuse blows then its a short in wiring.But if the fuse does not blows then its faulty fuel pump relay or faulty fuel pump itself.So first replace the fuel pump relay and see,if the fuel still blows then its faulty fuel pump.But if the fuse not blowing then relay was the faulty part.The fuel pump relay located on the fuse box under the hood.---------This troubleshooting tips will help you locate the fault and solve it.-------Thanks.Helpmech.
Dec 13, 2010 | 1996 Dodge Neon
My 2004 dodge neon keeps blown the fuel pump fuse. Can some one help
It's either the fuel pump having the problem or you have short in the electrical wiring going back to the pump. Make sure the fuse is the proper size for the fuel system. Hope this will help you.
May 15, 2010 | 2004 Dodge Neon
My 2004 dodge neon keeps blown the fuel pump fuse. can some one help
If it is working for a time and just blowing once in a while you probably need to replace the fuel pump. If it blows as soon as you put it in, then look for a short circuit in the fuel pump wiring.
Mar 29, 2010 | 2004 Dodge Neon
Suspect the fuel filter.
fuel filter is inside fuel tank. i really dont know what you are asking???
Oct 01, 2009 | 2005 Dodge Neon
Fuel pump fuse keeps blowing on 99 dodge neon. Changed relay, but didn't help. Fuel pump or something else? It mainly does it when you hit the brakes.
Usually if a fuse blows when applying something else( brakes) indicates they are on the same circuit. Verify the brake lights don't work when the fuse is out or blown. If lights still are working then it's probably not related. If on same circuit then the extra load of the brakes is enough to blow the fuse. Insure you are putting in the correct fuse. Also, this indicates you fuel pump is in a strain either due to restricted fuel filter or worn pump. Replaceing the fuel filter now will only buy you a little time before the pump goes on out. It's blowing fuses because it's drawing more amps in order to run, but always replace filter when replacing pump.
Sep 18, 2009 | 1999 Dodge Neon
1997 neon, fuel pump fuse keeps blowing
I had a neon that did this in my shop. I found one of the wires to the Oxygen sensors was melted near the exhaust and when you would give it gas the exhaust would flex and short out the o2 sensor.
Jun 11, 2009 | 1997 Dodge Neon
Fuel filter
The fuel filter for 93 to 99 dodge neon is inside the gas tank. it is part of the fuel pump. to replace it you have to replace the whole thing. the part is beween $280 and $340 depending whether you have a metal or plastic fuel tank. i had this same thing a week ago with my 97 neon.
May 17, 2009 | 1997 Dodge Neon
Aftermarket 00 01 02 03 04 dodge neon 2.0l at radiator fan motor Logo
27 people viewed this question
Top Aftermarket Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you an Aftermarket Heating and Cooling Expert? Answer questions, earn points and help others
