Question about Preethi Nitro Mixer Grinder - 110 Volts for USA
Preethi blue leaf wiring diagram
I need wiring diagram for preethi blue leaf mixer
Replacemnt of brushes 750 watts preethi mixer grinde
replacemtn for a brush can be a spatula sometimes. depends on the dinner
Sep 09, 2016 | Food Mixers
Preethi eco plus mixie not working (first time)
I recently brought(just 2 days back) a Preethi ECO Plus mixie from India.(US made)
It works fine for some days when i use that to grind some soaked
rice it was working fine for some time, suddenly the motor is not running. But I can see the power light switched on in the mixie. But its not working.
I am not sure if there is some service centres for repairing these kind of issues.
I am located @phoenix ,Arizona,usa
please let me know.
Indira
May 13, 2013 | Preethi Nitro Mixer Grinder - 110 Volts...
I want to know how does an overload switch works in mixer grinder
when the motor get stuck it cuts the power to the motor. some models you have to reset by hand. means opening up the unit and taking out what has blocked it in the first place. but there is a thermal switch in the motor and if it overheats it blows this. and you will either need to get another motor. cut the wires back on the motor to get to it but doing this can be dangerous and you can blow the hole unit up and you don't want to do this when you are in front of it can cause death.
Apr 12, 2013 | Preethi Nitro Mixer Grinder - 110 Volts...
Hi, Our Indian made Preethi Eco Chef mixer had stopped working after pressing the overload button repeatedly, any idea whether any repair centers in and around Ipswich
Hi, please replace the Overload button (Circuit Breaker) with a new one. You can purchase the Overload protector (Circuit breaker) in any nearby Mixer repair or Electrical shop. Please take the old Overload protector to get the new one of same specification which suits for your Mixer.
Apr 16, 2011 | Food Mixers
I need wiring diagram for Belle 150 cement mixer 110v
Small BLUE at top right hand corner, then the two rows of two...
top left is BLACK, top right is GREY, bottom left is BLUE from the power supply and bottom right is a short BROWN wire with a spur, which leaves a BLUE to connect to the spur. should be it :)
Oct 09, 2010 | Garden
A - 200 3 speed mixer needs a wiring diaram
how do you know diagram is wrong , you could have wired it wrong the timer kit i belive comes with 3 or 4 different diagrams for that mixer you need to pick the right one
Aug 27, 2009 | Hobart A200 Stand Mixer
NEED A WIRING DIAGRAM FOR A A200 HOBART MIXER
I had a look on google and came up with a service manual. not sure if this has the wiring diagram but the only other thing i can suggest is to contact te manufacturer direct. Go to http://cgi.ebay.com/HOBART-A200-20-QUART-MIXER-SERVICE-PARTS-MANUAL_W0QQitemZ160203114233QQcmdZViewItem
hope this helps.
Feb 02, 2008 | Hobart A200 Stand Mixer
Preethi Nitro Mixer Grinder - 110 Volts for USA Logo
374 people viewed this question
Top Preethi Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Preethi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
