Question about Clothing Accessories
Look like a geen walking stick hanging by a thread from a tree
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 52 Answers
Make the question more clear please.
Posted on Aug 21, 2013
Hi i have a empisal 550d overlocker . I have difficulty with cotton breaking after sewing for a few seconds. Can you help please ?
Could be the tension is set too high on that particular thread tensioner.
If it is not the tension, then this is the first thing to try (I know, it's painful but 99% of the time takes care of my issue): Remove all the threads from the machine, ALWAYS RAISE the presser foot and then rethread from the beginning. Verify that you are threading each in the "proper" order and that the threadpath for each is correct.
If it is a needle thread, replace with a brand new needle. Try a different brand of thread or spool on that particular threadpath. AVOID old or bargain bin thread. Check to make sure that particular thread is not hanging up on a burr, a sharp spot, or looped in the thread tree, etc. that catches the thread and holds it from advancing through the path.
Serger needle thread breaking sewing discussion topic PatternReview com
Lower Looper Threader Keeps Breaking Thread sewing discussion topic...
Jun 09, 2017 | Sewing Machines
Why does my bobbin thread keep sticking?
thread skipping (that's what its called) is most of the times caused by Not the bobbin but the main thread tension being too tight , as it goes thru to get a wrap on bobbin thread its too tight to make a loop large enough for the shuttle to grasp a loop and pull it tight , this tension needs to be changed 4 every change in texture or thickness of fabric as rarely its one setting takes all
Feb 05, 2016 | Juki TL2000Qi Sewing & Quilting Machine...
Why does the upper looper thread keep busting?
Quite possibly the machine is not threaded correctly, the tension setting for that looper is too tight (could be the upper looper tension disk is stuck or dirty causing the thread to hang), or the thread is looped around something like the thread tree.
Replace the needles. Remove all the thread and re-thread from the beginning. Be sure to RAISE the presser foot before threading. Make sure to thread the threads in the correct order.
Serger Troubleshooting For Any Serger Serger Machine Series Ep 4
Nov 01, 2015 | Brother 1034D Serger Sewing Machine
Mylock 334d
Your thread tension wheel may be set to too high of a tension, which will cause the thread to pull out from the bobbin. Try a lower tension setting.
If set too low, then threat from the top end would hang loose and possibly snag, instead.
Oct 14, 2013 | Sewing Machines
Tree diagram...is there a threaded tube running between the two parts of the tree on the front end?
There is the steer tube that is pressed into the lower tree/clamp. This tube is threaded on the top so that you can put a nut on it after the upper tree/clamp to preload the headset when you install the front end.
Oct 05, 2013 | Honda CB 750F2 Seven Fifty Motorcycles
I need a Singer Profinish "Thread Tree" replaced. Where can i order one?
Here is a link to a parts supplier.
http://www.sewingpartsonline.com/singer-14CG754-serger-machine-parts.aspx
The part you describe is:
4 Thread Holder, Universal #412519
$25 plus shipping
Feb 03, 2013 | Singer 14CG754 - ProFinish Serger
If I want to put out bird seed as a treat for the birds, how do I hang it? I don't want to use a table, I want to hang it from the trees.
There are recipes for homemade bird seed treats that involve suet or some other sticking agent that keeps it together so you can hang it in a lump. But I came across a very cute web posting with a recipe for a bird seed treat that is heart shaped! Check out this link http://kids.nationalgeographic.com/kids/activities/crafts/wild-bird-treat/
Aug 21, 2012 | Birds
How did my dog get ticks?
Is it possible that your dog has gone through high grasses or walked through the woods recently? If so, you have your answer. Ticks hang out along the ground of trees and shrubs. All it takes is for your dog to walk past them and they will cling to your dog immediately.
Aug 01, 2012 | Pets - Others
Thread hangs up
Remove the needle plate and look for any burrs or nicks that may be catching the thread. If you find any they need to be removed with a small file or emery stick.
sewman7
Jul 09, 2008 | Sewing Machines
Clothing Accessories Logo
Top Clothing Accessories Experts
Da Doc
ray gallant
Are you a Clothing Accessory Expert? Answer questions, earn points and help others
