Question about Kitchen Ranges
How to replace fuse light on Delongi Range Hood Desigma90
How to get into fuse box to replace the light fuse
4 Suggested Answers
duane_wong
  • 6826 Answers
SOURCE: 96 buick century - lights/brake lights/dome
Check fusible links coming off of the starter, with the battery disconnected.
Pull on the various colored wires that have a barrel of foam on them about 1/2" to 2/3" long that indicated that the wire is a fusible link.
If a fusible link stretches, the inside of it is blown. Many circuits can be controlled by the fusible links.
REPLACEMENT
Fuses protect all the major electrical systems in the car. In case of an
electrical overload, the fuse melts, breaking the circuit and stopping the flow
of electricity.
If a fuse blows, the cause should be investigated and corrected before the
installation of a new fuse. This, however, is easier to say than to do. Because
each fuse protects a limited number of components, your job is narrowed down
somewhat.
Fig. 1: Fuses come in different colors which indicate different
amperage ratings
The amperage of each fuse and the circuit it protects are marked on the fuse
box, which is located under the left side (driver's side) of the instrument
panel and pulls down for easy access. To replace a fuse, simply pull it from the
panel. Insert a new (same amp rating) fuse in its place.
Posted on Nov 03, 2010
  • 288 Answers
SOURCE: no park lights on rt. side front & rear replaced all bulbs
Check for voltage at the rear of the lights. If none there then they have become disconnected somewhere between there and the left hand lights.
Posted on Oct 30, 2011
  • 5317 Answers
SOURCE: need to replace the fuse in space 19 in the under the hood fuse box of my 1999 Chevrolet Tracker>
Take off the negative battery terminal first. Use pliers to pull the fuse remnants out. If not enough room, try removing surrounding fuses. The fuse only has two spade terminals into the fuse block. Pull on them back and forth until loose.
Posted on Feb 19, 2013
My Zephyr Typhoon Range Hood (AK2100) neither light nor fan work i can not find fuse box
There shouldn't be a fuse box on the range hood.
You'll have to check your main house circuitbreaker or fuse box.
Jul 22, 2016 | Zephyr Kitchen Ranges
Why didmy tail lights quit working,now my range rover wont come out of park,And where is the 17 fuse?
The tail lights sound like a fuse. The interior fuse box iss under the passenger seat. Access thru the pop out cover on the seat base surround.
If you have a dead battery your gear selector will not disengage from park.
Hope this helps a bit. Feel free to repost with more info and ill do my best to follow up.
Jul 09, 2014 | 1996 Land Rover Range Rover
Whirlpool accubake
follow this steps with VOM and fix it. God bless you
1. No power to the range hood
Make sure there's power getting to the range hood. Check for a tripped circuit breaker or a blown fuse. Check the wall socket (unless the hood is hard wired) for power with a voltmeter or by plugging something else in.
2. Fan switch
If your range hood only has a fan and no light or any other features, it won't start with a broken fan switch. Replace the switch if found defective.
3. Fan motor
If your range hood only has a fan and no light or any other features, it won't start with a broken fan motor. Replace the motor if found defective.
Read more: http://www.appliancepartspros.com/repair-help/rangehood-repair-help.html#ixzz2aSy5FKwN
Jul 29, 2013 | Kitchen Ranges
No reverse light, all fuse good. reverse Switch?
It's not that simple anymore . The transmission range sensor switch is what they have now . This range sensor informes the PCM - engine computer what gear the vehicle is in. When you put the gear selector into reverse B+ voltage from the range sensor to the PCM tells the PCM reverse has been selected , the PCM then will energize the reverse lamp relay (located in the under hood fuse/relay box) there by turning on the reverse lamps . There are two fuse's in the under hood fuse/relay box . F27 10amp. & F35 10amp.
Aug 11, 2017 | 2010 Ford Escape XLT
Exhaust fan and lights do not work
see this steps and fix it. God bless you
Switch If the range vent hood fan and light are not working the switch might be defective. Watch our video on switch testing and test this switch for continuity.
Selector Switch If the range vent hood fan and light are not working the selector switch might be defective. Watch our video on switch testing and test this switch for continuity.
Rotary Switch If the range vent hood fan and light are not working the rotary switch might be defective. Watch our video on switch testing and test this switch for continuity.
Rocker Switch If the range vent hood fan and light are not working the rocker switch might be defective. Watch our video on switch testing and test this switch for continuity.
Switch Kit If the range vent hood fan and light are not working the switch kit might be defective. Watch our video on switch testing and test this switch for continuity.
Micro Switch If the range vent hood fan and light are not working the micro switch might not have continuity. The best way to test the switch is with an Ohm meter. See our switch testing videos for help testing this micro switch.
Thermal Fuse If the range vent hood fan and light are not working the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Main Control Board If the range vent hood fan and light are not working the main control board may be defective.
User Control and Display Board If the range vent hood fan and light are not working the user control and display board may be defective. Check other causes before ordering this board.
Oct 02, 2012 | Dacor Millennia DHI602 Kitchen Hood
I have a Cavaliere 218 range hood and the lights don't come on. Lamp button illuminates, but no lights come on. Bulbs are good.
We have a Cavalier range hood as well that the two halogen lights stopped working. Bulbs were good and the light switch illuminated. I ended up ordering and replacing the transformer and it works great:
https://www.lightsonrus.com/store/products/Hatch-RS12%252d80M-(RS)-Series-Electronic-Transformer-80Watts.html
Dec 30, 2009 | Kitchen Ranges
My Delongi dsf905 oven stopped working
FIRST CHECK THE FUSE IN YOUR PLUG IF OK THEN IT MIGHT BE THE TERMOSTAT IS FAULTY CHECK THE ELEMENT IS NOT BURNT OUT IF SO REMOVE AND BRING TO A ELECTRIC AND PLUMMERS SUPPLY STORE FOR REPLACEMENT.
Nov 29, 2009 | Ovens
How do you take out light ballbs from dacor hod fan
To replace the light bulb:
1. Remove the right filter and turn off the main power
switch.
2. Gently push the suction cup on the light replacement
tool A (provided with you range hood)
onto the lens of the light bulb B .
3. Turn the tool counter-clockwise until the bulb
comes loose.
4. Remove the tool from the bulb and put it on the
lens of the replacement bulb.
5. Screw the new bulb into the light fixture clockwise
until it is tight. Turn on power at the fuse or junction
box. Turn on the main power switch and touch
the light key to make sure it is working.
6. Replace the filter.
You can download the manual here.
Good Luck And please Rate FixYa!
Dec 19, 2008 | Dacor EHD3618SS Kitchen Hood
Broan Allure QS2 Range Hood
Had same problem & fuse fixed it.
Before buying a new control board (approx $160), check the 3 amp fuse located on the inside of the vent on the control board. You have to take the light/bottom housing & black plastic air chute off to see control board/fuse.
Feb 21, 2008 | Broan-NuTone Allure II QS230SS Kitchen...
Lights stopped working
Have you opened the hood at all? Service instructions should be on the cover of the controller box. FYI the fuse is on the 12V side of the transformer so it which feeds triac controlling lights and controller board so nothing works when it blows.
Sep 23, 2007 | GE ZV850SBSS Kitchen Hood
Kitchen Ranges Logo
178 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
