Question about RCA P61930BL 61" Rear Projection Television
Why does tv have double color picture appears in three d?
Serial # 922651109, chassis # ptk195et june 1999. after having power outage last night, when turned tv on today, the picture appears to be in 3d. looks like all the colors are overlapping. tried resetting, unplugging, and turning back on to no improvement. what can it be, and how much would cost to repair?
    Champion:
  • 247 Answers
U need a tech to reset the tv convergence problem the cost depends with the tech and your area check with your nearest tv repair shop
Posted on Jul 14, 2013
  • 74 Answers
SOURCE: Older RCA Projection screen, Blue picture!
take the front speaker cover off, then remove the four screws on the cover behind it. you will see a 2"x2" black thing with 6 controls on it 3 on top three on bottom, your looking for "screen". they should also be marked r g and b, try turning the blue down (counterclockwise). it may help a little and prolong the life of your tv
Posted on Sep 10, 2008
ladywinn
  • 5138 Answers
SOURCE: Picture(Color Convergence)
Go to menu look for convergence on menu if it is not on menu then you have a open fuse located next to Flyback Transfomer on deflection board.
Posted on Sep 24, 2008
abhishek33
  • 1239 Answers
SOURCE: picture in 3d without the 3d glasses
HI Since , you need technical person to examine TV and rectify what board is required.   high tech item and fault diagnosis also required special tools and jigs. I would recommend to call for proper repair.
Posted on Oct 12, 2008
ladywinn
  • 5138 Answers
SOURCE: Tv's green light comes on then off three times
On same Board that you replaced fuse Look at cp 150 if it is puffed up on top it is bad so replace cp150,114,120 one will be 2200u 16v
other 2 caps will be 220uf 35v With tv turned OFF Press and Hold Vol- and CH - at same Time on Front Panel board wait untill set comes on you should now be in Service mode Go to Convergence Try to aline convergence Do Auto converge
Posted on Feb 08, 2009
  • 418 Answers
SOURCE: my rca projection tv is a 52 inch. and i turned it
Check video in cables or set top box.
Posted on Apr 14, 2010
Last night about 3 am I turned off my tv. when I usewd my remote to turn it back on it would not ( t v) come on and no picture or sound . I turned it around to see the back of it but it has no reset
Your TV have faults on Horizontal deflections, the oscillator and the Flyback might be the problems. If you are not familiar with TV circuits?... call tecnician to check your set.
Oct 03, 2014 | Televison & Video
I have audio, but no video, what's up? last night I was watching, and the picture went out, I truned off the TV, then restarted it...the picture came back. Today I tryed to turn it on and no picture, just...
s the audio coming from the TV's internal speakers, or from an external sound system? In the 169 series chassis, if the power supply caps or secondary rectifier are bad, or if the high voltage splitter has shorted inside, the set will not run and there will be no picture or sound from the TV. If the picture is completely black but the TV still has audio, press the menu button and see if the menu comes up on the screen. If the menu is there, check your cables on the back of the TV. If you are using a cable or satellite box, the box could be bad or the video wire could be bad or loose. If you do not get the on-screen menu, then I would guess that the solder joint next to the flyback transformer that sends filament (heater) voltage up to the picture tubes has cracked, or the low value resistor in the heater circuit has opened up. If that is the case, have the set serviced by a qualified tech familiar with the 169 series chassis.
Oct 17, 2008 | Televison & Video
I turn on my Mitsubishi WD-73833 TV and it turns itself off
Lessing of brightness on a DLP set is a sign of imminent bulb failure.
A new bulb is in order.
Nov 23, 2013 | Mitsubishi WD-73833 73" HDTV
I have a Panasonic 32' crt tv
some of those chassis develope small cracks or cold solder joints
should be resoldered in several areas know to have that problem
transformer pin connectors-heatsink transistors/ic's have to be checked
Aug 30, 2009 | Panasonic Televison & Video
53FDX20B NO PICTURE AND SOUND
It powers up but no picture? In my experience with Hitachi TV's this has been an issue with the convergence IC's failing. You will need to have a technician replace those if needed.
Jul 23, 2009 | Hitachi 53FDX20B 53" Rear Projection...
Phillips magnavox
Could be an open internal fuse or power supply failure
Mar 18, 2017 | Philips Televison & Video
Loses Picture, Goes Black... Sound stays on
Sounds like power supply. Probably time for a new tv. You have already got almost 20 years service.
Dec 05, 2017 | RCA F36685 36" TV
GE 31GT660 picture is intensly WHITE
The GE (actually RCA) 31GT660 uses the CTC187 series chassis. This chassis is notorious for bad solder joints on the shields around the tuner and microprocessor. When the solder joints on the shields crack, the microprocessor and EPROM lose their ground and the EPROM's data becomes corrupt. The solder joints on the shields will all have to be resoldered and the EPROM reprogrammed or replaced by a qualified tech familiar with the 187 series chassis.
Aug 22, 2007 | GE 31GT660 TV
Tv will not turn on
your tv needs to be repair again power supply problem or circuit.good luck.
Apr 04, 2007 | Toshiba 37HLX95 37 in. LCD TV/DVD Combo
Televison & Video Logo
48 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
