Question about Janome Magnolia 7330 Sewing Machine
WHERE DO YOU LUBE>>>???? - Janome Magnolia 7330 Sewing Machine
  • Janome Master
  • 7,365 Answers
If you have a manual the information should be in it, if you don't have a manual
here is a link for a manual, but it's not free,
http://www.sewingpartsonline.com/janome-7330-manual.aspx
if you don't want to buy a manual,, then contact janome customer service and ask them if you can oil the sewing machine yourself or if it's a self oiling sewing machine..
Posted on Jul 12, 2013
The zig zag and other stitches does not work. This is on the Bernina 930 which has not been used for several months.
Bet the machine hasn't been thoroughly cleaned and lubed in quite a while. The mechanics have seized due to old, dry oil in the moving parts. Lots of patience, time, good quality lube, and a handheld hairdryer will probably take care of it.
Be sure to move the levers and dials and apply a drop or two of lube there too. The most difficult one to reach is the feed dog dial mechanism. Unfortunately, the feed dogs are not changed very often so it is also one of the most likely to seize.
BEWARE, on your 930, there is a basting stitch mechanism accessible about the midway point of the slit where the take-up lever travels. Do NOT apply lube to this area as it will most likely cause the basting stitch to seize. It has seized when the needle mechanism rises to the top and refuses to lower again, no matter what you try. (Bernina oil diagram below.)
Wheel on right side that controls the needle up and down is very tight...
Mar 05, 2017 | Sewing Machines
My Tuffy Lock serger is squeaking and slow to start sewing. I think the belt needs oiling and I don't know where to oil it. Anyone know?
The belt should NOT be oiled. However, the metal moving parts would benefit from oiling--my preferred lube is Tri-Flow Synthetic Lube from the hardware store.
Feb 17, 2017 | Sewing Machines
My brother lock 546D has seized what can I do
Ooh, do not use WD-40 or old sewing machine oil. WD40 will work for a short time but turns to gunk quickly and just add to the current problem. The old oil has solidified and turned to glue.
Pick up some liquid Tri-Flow Synthetic Lube (hardware store or bike shop). Apply 1-2 drops every place that metal rubs on metal. Do NOT oil belts, synthetic parts, or tension disks.
Then direct heated air from a handheld hairdryer into the internal mechanism. You may have to repeat alternating lube and heat. If the oil has solidified and seized, this activity should loosen it.
In the future, be sure to keep the machine cleaned and lubed (even when in storage). An overlocker requires more frequent lube since it stitches so much faster than a sewing machine. If you want, you can pick up oil that is especially for sergers--it is usually a lighter weight than regular sewing machine oil.
Oct 08, 2016 | Brother Sewing Machines
White sewing machine. The control for the feed dog pressure isn't working, how do I fix it?
It has most likely seized due to lack of oiling. Apply a couple drops of liquid Tri-Flow Synthetic Lube to the feed dog mechanism and then direct hot air from a handheld hair dryer into the internal mechanism. Alternate lube & air--may take several times over several days. Eventually, it may loosen. Do not force the feed dog knob, but wiggling it may loosen things.
Sep 26, 2016 | White Sewing Sewing Machines
Machine binds up
Seems you need to clean and lube your machine. remove the top and bottom cover cover open the front cover brush out all lint check bobbin for thread lock and lint. lube all moving metal parts with "non petroleum " light oil. Do not lube plastic parts unless there is apparent fiction. " DO NOT USE PETROLEUM BASED LUBRICANT " as it will dissolve or soften plastic parts!
Mar 02, 2015 | Singer 4166 Sewing Machine
Where to oil machine
You need to lubricate everywhere motion occurs as well as anywhere friction happens (joints and gears). The needle hammer is the most obvious point, but the shuttle friction points are key spots as well. I find it is more important to clean out the dust and debris than actually lubing the parts.. Lots of loose threads and fabric dust seem to accumulate all over and especially where lube is present.. First clean off stuff and then lube in those spots... Also good to replace grease on gears and bearings every couple of years too (more invasive, but keeps the wearing parts healthier)...
Apr 09, 2014 | Singer 2662
Blocked motor message for 2140. Has happened 3 different times. Sewing machine repair is two hours away and I need my machine today. I did all the thread things suggested with the bobbin, re threading,...
You said the hand wheel barely moves. Is that all the time? If the hand wheel is hard to turn the motor is getting overloaded and is protecting itself by stopping and giving you the error message. You need to determine why the hand wheel is tight. There could be thread caught or something might need lube. These are non oiling needed machines however sometimes a linkage might need fresh lube.
Sep 12, 2013 | PfaFF Sewing Machines
I think it needs to be lubricated because it is very difficult to move the needle up and down. How do I do this? Janome 10000
Your Moen single-handle push-pull sink may become difficult to force down and take up if the tube within the tap has missing its oiling. Hard-water enzymes may be a aspect, but you can fresh away any remains while lubricating the tap. To make managing the tap simpler, just take apart the tap and lube the tube. Since your Moen single-handle sink has few inner areas, this is an straightforward process
<a href="http://www.digit-embroidery.com/embroidery-digitizing">Embroidery Digitizing</a>
Jul 20, 2012 | Janome Memory Craft 10000
The foot pedal for this machine keeps getting stuck which makes the machines motor struggle and churn instead of stopping, when you lift your foot off
Put some spray lube on it or oil at the pivot and that should take care of it. Make sure the switch is making good and clean ,might want to spray that as well. Try and do a dry lube cause liquid lubes attract dirt.
Apr 05, 2011 | Singer 4830
Pool cleaner will not move in water power switch is on
This is dependant on the pump which should be running when you switch it on. Alot of times these stop working due to air in the system which greatly reduces the suction of the pump. There is a bleeder screw on top of the filter which will help purge the air out of the system. Many times the air leak is simply a poor seal on the pumps filter basket. There is a large o-ring on that clear cover which seems to stretch and become ill fitting to the ride area of that pump to o-ring and cover. It is highly advisable to use lube on that o-ring as well but not petroleum based lubes (like vasoline or spray lube).Use a plumbers grease or lube provided by pool equp. store designed for o-rings. If your suction is up to par and cleaner still will not function,there is a special diaphram in the unit where debris can get caught inside causing the unit to malfunction. Look inside the suction area of the cleaner and you should be able to see and inspect the white rubber diaphram from there.If you are lucky, you can lube the o-ring and remove debris from the cleaner and resume operation...good luck
Jul 26, 2009 | Sewing Machines
Janome Magnolia 7330 Sewing Machine Logo
71 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
