Question about Kitchen Gourmet 2 Slice Non-stick Waffle Iron W/ Lock Clip & Carry Handle
I lost the instruction on how to use waffle maker.
How do I make waffles?
Lost instruction manual
Instructions
How to Select a Waffle Iron
Determine what type of cooking you'll be doing. If you're planning on preparing one waffle at a time, for example, then the smallest model of waffle iron will be the best fit for you. On the other hand, if you plan on frequent entertaining, or if you have a larger family, you'll probably want to choose a deluxe model.
Decide on the type of waffle maker that you'd like to own. There are a number of these available, ranging from simple differences---round versus square, for example. Some feature removable cooking elements that can be replaced with others, such as grilled sandwich attachments.
Internationally Accredited Hospital Visit Now to Get a Healthy Life!
www.apollohospdelhi.com
Take the varying grades of quality available in waffle makers into account when choosing one. This point may seem obvious---choose the highest quality waffle iron, right? Not necessarily. If you plan to use your waffle maker on rare occasions, say, once every couple of months, then you won't need the highest quality available. Waffle making several times monthly, however, will warrant a sturdier model with thicker non-stick coating applications applied to the cooking elements.
Consider the cleanup aspects of each waffle iron that you're comparing. Some waffle irons feature removable cooking elements; this is a tremendous benefit when cleanup time comes around, as it is much easier to clean the grill elements separately than attached to the entire waffle iron.
5
Take brand into account when making a decision. Brands with a reputation for high quality are usually more expensive than lesser-known labels. However, this doesn't mean that an "unknown" brand can't produce a good product. When taking this aspect into consideration keep in mind the requirements that you need and purchase a waffle iron accordingly. Additionally, many celebrity chefs have endorsed cooking products---including waffle irons---which adds a little more cost to the product. Finding the company's non-endorsed model of waffle iron will mean the same quality at less cost.
Jan 11, 2013 | Kitchen Appliances - Others
I lost the instructions for my sunbeam waffle maker, and I dont know how long Ihave to bake it.
Here is a direct link to the User's Manual for your appliance:
http://dl.owneriq.net/d/db0acd4e-57c1-43f0-a51b-4ef04ad30e2d.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
See page 2 of the manual for detailed operating instructions. Basically they read as follows:
Preparing Waffles
1. Close Waffle Maker and plug into outlet. Use only voltage specified on bottom of Waffle Maker. The Power light (Red) and Ready light (Green) will come on.
Caution: Touch Waffle Maker only by handles during use or directly after use. Take care not to touch hot surfaces.
2. The Waffle Maker is ready for initial use when the Ready (green) light goes out (approximately 2-4 minutes).
3. Open Waffle Maker, pour approximately 3/4 cup waffle batter onto grids. For best results, pour batter around outer edge of waffle maker. Close cover. It is very typical to have a small amount of batter run over grid and down Waffle Maker. However, if an excessive amount of batter runs over, use less batter.
4. Close the Waffle Maker by lowering the upper plate onto the lower plate and secure with the safety latch. Do not open cover while steam is escaping. Most waffles bake in approximately 2-4 minutes, depending on personal taste. Waffles are generally done when the Ready light (green) goes out and when steam no longer escapes from sides and front of Waffle Maker.
5. When waffles are done, remove with a fork or wooden tongs. Note: Be careful you do not scratch the non-stick cooking surface.
6. Close cover and wait for Ready light to go out before preparing another batch of waffles. The next waffle may be baked in less time because the plate will store heat.
I hope that was helpful to you, good luck and take care.
Joe.
Aug 31, 2011 | Sunbeam 3852 Waffle Maker
To whom it may concern, I lost my instructions
You can download the instructions manual in PDF format by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
  • To magnify the text of the manual, click the [+] button in the Adobe Reader window.
Hope this solves your problem. Thanks for using FixYa.
Jun 22, 2010 | Black & Decker G48TD Grill & Waffle Maker...
Instructions for Nordic Ware Microwave waffle
I have a Nordic Ware microwave waffle iron and cannot find the instructions. The instructions on the waffle iron are ok untill it says see instructions. (Which I do not have). Anyone out there have the instructions and can scan them and e mail them to me at vdanziger@gmail.com thank you
Apr 04, 2010 | Kitchen Appliances - Others
No instructions for used Sunbeam#3856 waffle maker
download here:
http://www.retrevo.com/support/Sunbeam-3856-manual/id/952ag122/t/2/
Apr 30, 2009 | Sunbeam 3852 Waffle Maker
I need instructions for a waffle maker mine are lost
When making a waffle have your batter made plug in your maker and get it started heating if there is a light it will go off whenit is hot enough if not wait aprox 2-3 minutes at the most 5 then spay or brush the inside of the plates with a nonstick cooking spray or brush with butter then pour your batter in the center of the bottom plate and close the lid it should start steaming right away watch the steam it is a never fail indicater of how done your waffle is the less steam the more done your waffle is, there is a lot of trial and error with waffle makers, you should spay or brush between each waffle or they will stick. Let me know how it all cooks out. goofballlovers
Mar 24, 2009 | Kitchen Appliances - Others
Kitchen Gourmet 2 Slice Non-stick Waffle Iron W/ Lock Clip & Carry Handle Logo
57 people viewed this question
Top Kitchen Gourmet Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Gourmet Kitchen Appliances - Other Expert? Answer questions, earn points and help others
