Question about Cell Phones
Car charger car charger won't work found where the fuse goes but no place to lock the fuse in I need it for work was wornding how to fix this problem
    Problem Solver:
  • 6 Answers
Your video didn't work.
Is the problem with your cigarette/power outlet or with your device charger?
If your problem is with your device charger, and your fuse is not staying in the socket inside of your device charger, you are likely missing a connector or spring. If you took it apart and did not do so carefully, you may have lost a piece that is essential in creating a circuit before reaching the internal PCB and going to your cord. Look up your particular charger to view a diagram, and ensure that you have all of your pieces.
For any electrical problems with your vehicle refer to a mechanic or other trained professional. The following instructions are only for a trained mechanic or electrical engineer.
If your problem is with the outlet, check the fuses in the fuse panel (usually below the steering wheel in a small compartment), and find the one for your DC/AccPwr/Aux. (May be a combination or variation of these.) Refer to your owner's manual or a Haynes/Chilton Repair manual if the fuse panel does not have a diagram.
The fuse will likely be a green 30A fuse. If it is burned out:
Safely disconnect your vehicle's battery from power, then remove and replace the fuse.
If you have found the fuse and it is good, it is likely a bad connection to your power outlet.
If you know how to dissemble the console/dashboard and can access the outlet from behind:
With the vehicle's battery disconnected, determine the hot and neutral/ground wires with a volt meter. (In most modern vehicles the hot is "positive", and the "negative" wire is neutral and carries the ground as well.) The contact point- on the base of the outlet- is hot, and the "can" connection- on the side of the outlet- is the neutral and ground. If necessary, replace the female connectors on the wire ends and reconnect to the outlet.
Reconnect power and check outlet with a volt meter.
Reassemble.
If this still has not solved your problem, you likely have a short in your circuitry and will need to replace the wiring.
Posted on Jul 12, 2013
Door Lock Mechanism, Tail Lights, Speedometer Light not working
its definite that your old mechanic did not place everything in place. I would suggest that you just bring your car back to him and have him fix the problem he created. if you change his installations, he might blame you for the issue.
Jun 10, 2013 | 2004 Dodge Neon
Windows switches won't work intermittently then fuse blows so car won't start
It appears that you have a dead short in the switch, ehich would be like touchin teo wires together. Repkce of switch should solve problem,
Mar 28, 2013 | 2001 Dodge Stratus
My asb light comes on when starting and stays on. Lights won't come on , power locks won't work, power windows won't work, radio won't work. All fuses are good and car runs fine.
Those are all really common symptoms of the alternator going bad on those cars. I would have it checked to make sure it's charging properly.
Dec 15, 2012 | 1996 Oldsmobile Cutlass Ciera
NEED AN ORDERS MANUAL FOR 2003 FORD WINDSTAR
open the cover door and you will found some wrong here and not really work good '
Nov 19, 2011 | 2003 Ford Windstar
My lighter won't work and this means my cell phone
If the lighter won't work, your cell phone charger might not either. It is possibly the fuse or it has burned or shorted out. The fuse panel is under the dash on either side of the car. Look at the diagram on the cover and replace the fuse with exact number.
Nov 18, 2011 | 1992 Jeep Wrangler
My SCH-a930 won't charge. I still have battery life, and the phone works fine, but the phone won't charge. I have tried multiple wall outlets. Does anyone know how to fix this? Thanks!
Please, try using another charger with the phone.
If the problem continues, get a screw driver, unscrew the phone and bring the charging port out. The charging port is at the tail end of the phone.
Clean the surface of the panel where the charging port contact the panel with a spirit and allow it to dry for 30 minute. Couple back the phone and i am sure the charging phone will work fine.
Regards
Jun 28, 2011 | Samsung SCH-a930 Cellular Phone
My Garmin nuvi 265 was working fine until 2 weeks ago. We got a screen message saying that the XM traffic was not supported, and then noticed that the unit no longer could be charged using the car...
The traffic receiver is in the car charger cable. The charger should have a red light on if it is getting power. If the light is on and the unit is not charging and you have no traffic, the charger cable is bad. If the light is off, then either the fuse did not fix the problem, blew again, or is somehow not sitting properly in the charger. Another thing you can check is by using the unit in another vehicle. If it works fine there, then the charger is not making good contact with your vehicle outlet for some reason. You will probably have to buy a new traffic receiver charging cable.
May 04, 2017 | Garmin nuvi 265 Car GPS Receiver
Inside trunk release won't open trunk on 2002 Camry. Lock will not turn with master key. Remote trunk opener will open trunk.
1. Open trunk
2. Place latch in lock position
3. Pull inside trunk release to see what isn't moving
4. If trunk key won't turn, the key may be worn out and need to be replaced
Jun 05, 2011 | Toyota Camry Cars & Trucks
Gps won power up when car charger burn frm fuse
Unfortunately it sounds like when the car charger went bad it also did in the board on your tt. It would be cheaper to just purchase another unit than to get this one repaired out of warranty. My advice would be to sell it on ebay. People buy these all the time for spare parts.
Hope this helps
May 09, 2009 | Tomtom GPS
Cell Phones Logo
71 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
