Question about Garden
Cub cadet troubleshooting
My slt1550 has no drive power when pressing gas pedal.....
    Problem Solver:
  • 14 Answers
Not sure why they are talking about your deck but I would start with just a trams drive belt, you may also have a transmission fluid bottle in the back, if so make sure it is not low,,
Posted on Jul 12, 2013
3 Suggested Answers
  • 202 Answers
SOURCE: Cub Cadet-Blades won't stay engaged
sounds like either a saftey switch problem or a bad drive clutch on the pto. usuallly the mower shuts down,not the blades, they may have changed this though. my best guess would be a safety sensor try calling your local cub dealer and talking to the repair person he can shed light on the problem.
Posted on Jul 24, 2009
kel1guy2002
  • 3740 Answers
SOURCE: I have a Cub Cadet
Check your blade bearings of the deck. Either jack up the mower and put on jack stands / tripods but make sure you can get under the mower deck and grab the blades safely without having the mower fall on you. Grip the blade(s) on the outer end of each side and then try and teeter the blade(s) in the bearing mount. Have someone watch the drive pulley on top of the deck as you do this. The drive pulley and the blade should NOT move. If either one of them moves, your going to have to replace the blade drive bearings.
Also check each drive pulley to see that they are running true. I use the stand off approach where you place something in a fixed position then mark it with a piece of tape at the top and bottom of the pulley, (2 rings of tape.) Then rotate the pulley to see if it remains true during rotation. (no wobbles up or down) If you note either the upper or lower part of the pulley moving up or down as it rotates... replace the pulley. This applies to the engine drive pulley also. A stick or a ruler works fine for the stand off. You just have to keep changing the position of your tape marks on the stick for the top and bottom of each pulley.
Last look at each pulley V-groove to make sure that the groove itself is true. Use a stand off for a distance grip then take a philipps screwdriver and place it in the V-groove. The shank of the screwdriver should not move side to side or up and down. If it does... change the pulley.
By doing this your going to find something wrong as you have gone through 4 belts in a short period.
Thanks for choosing FixYa,
Kelly
Posted on Apr 12, 2011
How do i replace v belt on ltx 1040 cub cadet.
Nolan, Check the attached links,instruction and guides for belt replacement on Cub Cadet. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Change the Deck Belt on Cub Cadet Riding Lawn Mower Using Model...
How To Install or Replace Drive Belt on Lawn Mower Cub Cadet
How to Change the PTO Belt on Cub Cadet Riding Lawn Mower
cub cadet belt replacement diagram Google Search
Jun 30, 2016 | Garden
Cub cadet lawnmower wont go forward or reverse when you press pedal you here a grinding sound
what ever model cadet ride on mower
needs inspection and or repair
electric clutch system fitted on these
or drive part has failed
might just be a bearing
May 31, 2016 | Cub Cadet Garden
Drive pedal
pump is bad replce it
Apr 19, 2014 | Cub Cadet Garden
Troubleshooting cub cadet LT1042 safety shutdown system
knowing the problem would help cranking but not starting the brake pedal has a switch there is a switch in the back on the trans one on the seat
May 12, 2012 | Cub Cadet Garden
I have a cub cadet rzt 50 with a kawasaki 22hp engine it cranks and runs fine for a while and then sounds like its running out of gas, I shut the pto off and it eventually quits running, I pull the choke...
PDF]OPERATORLS MANUAL - Cub Cadet
https://www.cubcadet.com/.../CubCadetCatalogAssetStore/.../own...Cub CadetRZT Series Tractor - Model RZT50VT. Form No. 769-04647 ... Please read this entiremanual prior to operating the equipment. It instructs you how to safely and ...
Basic Troubleshooting - Zero Turn Riding Mowers (Gasoline ...
cubcadet.custhelp.com/.../basic-troubleshooting---zero-turn-riding-mowe...
Scripting must be enabled to use this site. Support Center. Cub Cadet Website ... Basic Troubleshooting - Zero Turn Riding Mowers (Gasoline Powered). Answer ID 10646 ' Published 01/22/2014 11:27 AM ' Updated 01/22/2015 02:50 AM
May 23, 2011 | Cub Cadet Street Sign- tractor lawn riding...
Jul 24, 2009 | Mtd Garden
Garden Logo
60 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
