HP 48 G
My calculator won't turn on. I already tried the RESET button, pressing the A and F while pressing the on key. What else can I do? I'll take my SATs soon! I really need it! Thanks!
    New Friend:
  • 3 Answers
Well, before trying something like opening the calculator, I'd advise archiving anything that you want to save to your PC. But what's done is done.
Are you sure that you're inserting the batteries with the proper polarity? Are you sure that the batteries are good?
It does sound to me like some sort of hardware problem, but strange things could happen if RAM gets corrupted (such as by being without power for too long).
It could be that the calculator really is on, but isn't displaying anything. The following solutions assume that the calculator is on.
Try a warmstart, that is hold down the ON key, press and release C, release ON.
If that doesn't work, try forcing a warmstart with a paper-clip reset. Remove the upper right (as viewed from the back) rubber foot. You'll see a small hole with the letter R next to it. Insert a straightened paper-clip (or something similar) straight in as far as it will go, and release it.
If that doesn't work, and you're willing to lose everything you had stored on the calculator, try clearing all user memory. Hold down ON, hold down A, press and release F, release A, release ON.
Regards, Sharp el531w
Posted on Jul 12, 2013
Testimonial: "I've tried all of that. Do you have any more advice?"
SOURCE: HP 49g+ Calculator Does Not Turn On
Try n cold start, reseting the calculator, introducing an wire in the back small oriffice in the calculator. It may fix the problem.
JC
Posted on Nov 05, 2007
oldnovii
  • 667 Answers
SOURCE: HP 32 won't work
Hey Dave- take a look at the following link. I like to have the user actually look at the user guide instead of describing it. If this solves your problem PLEASE rate this as fixed. If this isn't exactly right or you need more help just add a comment and I'll be glad to help you further. Thanks.
http://h10032.www1.hp.com/ctg/Manual/bpia5305.pdf
Jeff
Posted on Apr 30, 2008
SOURCE: i lost the instructions to
3(2x^+4) = 4(2x+6) I can't figure out how to in put this problem into the calculator...It won't let me type the equals sign
Posted on Sep 16, 2008
SOURCE: TI 83 plus calculator bricked
i was having a similar problems with my sisters TI-83 calculator it wouldnt turn on so I replaced the batteries and then the buttons didnt work at times and i tried some of the suggestion I used compressed air for like cleaning key boards and i also tried removing the batteries, after a couple of attemps the screen had a "mem clear" message then all the buttons started working.
Posted on Nov 15, 2008
SOURCE: the calculator, hp49g+, will not turn on by pressing the "ON".
Hi, if pressing on and F5 together immediately starts the selftest your keyboard is OK, but one of the capacitors on the HP49G PCB are broken. I replaced all three and the turn on/off problem was gone.
Hope this helps.
Joachim
Posted on Nov 20, 2009
Water from a water bottle spilled all over my TI-84 Calculator. I dried it the best I could and replaced the batteries after drying them but none of the buttons work and it won't turn or. And way I can...
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
I also hope you let the calculator dry out thoroughly before replacing the batteries.
Sep 03, 2013 | Office Equipment & Supplies
My calculator won't turn on the batteries are fresh plz help
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible. Does it?
Feb 13, 2013 | Office Equipment & Supplies
It just won't work with the new batteries!
Sep 11, 2012 | Texas Instruments TI-83 Plus Calculator
It takes too much time to turn on
Is the screen off during this time? it might be the batteries Try buying new batteries. I recommend you rechargeable batteries. If it doesn't work try installing the latest firmware from hp.com/calculators
Dec 26, 2011 | HP 50g Graphic Calculator
My HP 48GX recently have ((.)) in the display. I thought that is the indicator of low battery. However, I replace battery new several times the same display still appears. Even after turn off...
Somehow an alarm got set. Execute the command ACK once and see whether the indicator goes away.
To enter the command, press and hold the ALPHA key, then press and release the A, C, and K keys in turn, then release ALPHA, and press ENTER. But you already knew that, didn't you?
Oct 25, 2011 | HP 48gx Calculator
"ON" button doesn't work; calculator won't
In most cases this cannot be economically repaired... the cost to repair would be more then the calculator is worth...
heatman101
Jun 18, 2011 | HP 48gx Calculator
My HP 48GX just displays a black (all pixel) display screen with one vertical stripe down the middle. I tried reset button and now it displays 2 vertical stripes (the new one divides the right half in...
I just had this exact problem so I reset the memory as instructed below. Know I am back in business. Memory reset A memory reset will return the HP 48 to its factory-default state, which will erase all stored user memory. Use this feature very carefully.
  1. If necessary, turn the calculator on.
  2. Press and hold the ON+A+F keys simultaneously.
  3. Release all three keys at the same time. This should cause the calculator to display the message "Try to recover memory?"
  4. Press the A key to attempt to recover memory or the F key to erase the user memory. When A is pressed, occasionally the objects in memory are recovered in new sub-directories of HOME labeled D.01, D.02, et cetera, although there is no guarantee that all of the variables will be recovered. Pressing the F key will cause all information stored by the user to be erased from calculator memory. This will also affect any RAM card that is merged with main memory. If the card is not merged or it is write-protected, it will not be affected by this reset.
Hardware symptoms and solutions I. The display screen has a blue/purple blotch of color, even when the unit is off The screen is damaged, and the calculator requires service. Please contact HP . II. All of the pixels on the screen are lit (blue)
  1. Try to adjust the contrast by holding down the ON key and repeatedly pressing the [ - ] key.
  2. If the screen is still dark, try to halt the system using the keyboard.
  3. If this does not correct the problem, try to reset the system using the reset hole with the batteries removed.
  4. If this does not work, remove the batteries and let the unit sit for 48 hours. After 48 hours, replace the batteries. If the problem persists, attempt a memory reset. Although removing the batteries for 48 hours should erase the user memory, performing a memory reset will ensure that the calculator is reset to its factory defaults.
  5. If the problem persists, the unit requires service. Please contact HP .
Dec 30, 2010 | HP 48gx Calculator
48 gx does not turn on
Warning
In the keyboard test (below), make sure the keys are pressed in the right order. If the calculator fails the keyboard test then it needs repairs. (Ignore the beginning of the post and skip to the last part For Repairs )
You can reset the calculator:
Turn the back of the calculator towards you. Extract the top left rubber pad on the back of the calculator and use a paper clip to press the Reset button. If that does not restore the calculator to health, you should perform the diagnostic tests.
Make the calculator perform a
Self test.
  1. Turn calculator on
  2. Press and HOLD the key [ON]
  3. Press and release the key with "E" to its right (the one before last in first row)
  4. Release the [ON] key.
It tests the RAM and ROM. You will see various patterns on screen. Afterward you should see
IROM OK,
IRAM OK,
HP48GX OK
The self test will continue repeatedly until you perform a
System Halt
  1. Press and HOLD the [ON] key
  2. Press and release the "C" key
  3. Release the [ON] key.
The empty stack should appear.
If you do not see IROM OK and IRAM OK, the calculator requires service.
If the above procedure is successful, you may want
to test the keyboard.
  2. Press and HOLD the [ON] key
  3. Press and release the "D" key.
  5. Press and release the "E" key. KBD 1 should appear on the top left corner of the screen.
  6. Starting at the upper left corner of the keyboard, and moving Left to right, press every key in sequence. If you follow the sequence and the keys are functioning properly you should hear a hight pitch sound at each press.
  7. If everything is OK, when you press the last key (+) the screen displays KBD 1 OK.
To exit the keyboard test proceed as described above under System Halt.
If you follow the proper sequence and a hexadecimal number appears after pressing a key, the calculator requires service.-
For repairs
You can also try this site. They do repairs on most models, except the newer ones.
Jun 12, 2010 | HP 48gx Calculator
How to fix a none responsive button in hp 35s calculator
Resetting the Calculator
If the calculator doesn't respond to keystrokes or if it is otherwise behaving unusually, attempt to reset it. Resetting the calculator halts the current calculation and cancels program entry, digit entry, a running program, a SOLVE calculation, an ∫ FN calculation, a VIEW display, or an INPUT display. Stored data usually remain intact.
To reset the calculator, hold down the C key and press GTO . If you are unable to reset the calculator, try installing fresh batteries. If the calculator cannot be reset, or if it still fails to operate properly, you should attempt to clear memory using the special procedure described in the next section. If the calculator still does not respond to keystrokes, use a thin, pointed object to press the RESET hole.
The calculator can reset itself if it is dropped or if power is interrupted.
CLEARING the MEMORY
If the calculator fails to respond to keystrokes, and you are unable to restore operation by resetting it or changing the batteries, try the following MEMORY CLEAR procedure. These keystrokes clear all of memory, reset the calculator, and restore all format and modes to their original, default settings (shown below):
  1. Press and hold down the C key.
  2. Press and hold down the R/S key
  3. Press i (You will be holding three keys simultaneously)
  4. When you release all three keys, the display shows MEMORY CLEAR if the operation is successful.
Mar 02, 2010 | HP 35s Scientific Calculator
HP 20S Calculator
If the calculator has locked up you should perform a reset.
  1. Press and hold the [C] (ON/OFF) key
  2. Press and hold the [LN] key (third key from the left on the top row).
  3. Release both keys simultaneously. T
  4. The calculator should display "0.00" (if the number of decimal places is set to two.)
If that does not bring it to life you should perform a full memory reset
  1. Press and hold the [C] (ON/OFF) key.
  2. Press and hold the first key from the left ( the Square root x key) and the first key from the right (the SIGMA+ key ) on the top row.
  4. Calculator should display "ALL CLr".
  5. To clear the message press the [C] (ON/OFF).
  6. The calculator should display "0.00."
If the calculator does not respond as expected,
  • Remove the batteries, and
  • with a metallic coin (and what coin is not metallica) short-circuit the calculator's electrical terminals.
  • Maintain the coin for about ten seconds.
  • Replace the batteries (preferably fresh ones) respecting the diagram inside battery compartment.
  • The Calculator should display "ALL CLr".
  • To clear the message press the [C] (ON/OFF).
  • The calculator should display "0.00."
If the calculator does not respond to the foregoing procedures, remove the batteries and leave them out of the calculator for 24 to 48 hours to drain capacitors.
If it continues to malfunction, it will need to be repaired. One repair shop in Pennsylvania, USA has a website at http://www.fixthatcalc.com Here is the link . You should contact them.
Hope it helps.
Thank you for rating the solution.
Sep 03, 2008 | HP 20s Calculator
43 people viewed this question
k24674
jasbo
jasbo
