Question about Panasonic Technics Sa-gx290 Home Theater Am Fm Stereo Receiver Sagx290
Receiver does not work anymore.
Hi, my Technics SA GX 290 receiver has stoped working. I opened-up the box and confirmed the fuse was OK, not burned. Any ideas on what would be the next steps to identify the root cause of the problem? Any help is apreciated
5 Suggested Answers
yalmer
  • 552 Answers
SOURCE: dead SA-HE 100
Most likely if all fuses are good and everything checks out, the something is blown on the circuit board.
In the future it would be best to use a GFCI outlet and a protective power strip, because a power strip for lightning strikes is not fast enough, but the GFCI outlet is and the combination will save sensitive electronics.
I would recommend finding a service man on the website to fix it.
Posted on Feb 13, 2008
  • 905 Answers
SOURCE: Replacing a Surround Sound System Receiver
the difference is the "same speaker connections"
the front and rear will connect the same but the subwoofer is amplified by the HT75 , and the HE75 does not have an internal amp for the subwoofer speaker , only a "pre output"(has to be amplified)
Posted on Mar 24, 2009
  • 4234 Answers
SOURCE: My Technics stereo system ...the display screen shows nothing
The question is, do you hear any sound? Is just the display off or is the entire unit shutdown? Can you tell?
These displays are known to develope poor solder connections at the power input and ground pins. If you can solder, open up the unit (unplugged of course) and examine the pins for the display. This will be on the PC board attached to the front panel. The pins at either end of a long line of pins will be the power and ground pins. Reasolder those pins, taking care not to short the pins together and try the unit once done. If that does not resolve the problem (assuming it is just a display problem), update this with as many details as you can about the behavior of the unit and we'll look further.
Dan
Posted on Nov 18, 2009
rommelalilin
  • 2178 Answers
SOURCE: I have just purchased a
It "sounds" like it - no pun intended. I believe the sub output on this is not amplified.
Posted on Jan 07, 2011
When I turn on my technics sa-gx amplifier I can't hear the sound
Have you noticed if the speakers selector switch in the front panel is set to off ? That position for the switch is only suited to listen heaphones. Good Luck.
Flavio/BRAZIL
Jul 28, 2010 | Technics SA-DX750 Receiver
Hi: I have an sa-gx technics amplifier and when I turn it on I can hear the sound
Try to turn it on with volume knob at zero position. That might work well.
Good Luck.
Flavio/Brazil
Jul 28, 2010 | Audio Players & Recorders
My Tchnics Sa-Da10 shuts down on what appears to
Ahh technics. Technics always had overheating problems, trust me. Every since they started, their amps would get so hot they would hurt to touch. The reason the fan is not coming on seams to be something inside the circuit board. I'm sure that technics could fix this. If the fan works out of the receiver, then it must not be the fan. ;P
I would maybe get a computer fan, and just put it on top of the receiver and turn it on, or send it in for fixing. Also, do you have to crank the volume to get the speakers to play at your volume, and does the impeadence match the receiver. Because you may be pushing the receiver too hard.
Oct 11, 2009 | Technics SA-DA10 Receiver
I need a code for my Technics receiver SA-GX100 to program remote
technics codes:4007, 4008, 4026, 4045, 4073,
sony cd codes: 5001,5002,5099,5100,5101
sony vcr: 1001; 1002; 1003; 1004; 1005
good luck and vote for if it works
Aug 02, 2009 | Televison & Video
Technics sa 400 Receiver
check inside to see if you have a blown fuse on the left channel
May 27, 2009 | Technics Audio Players & Recorders
Panasonic Technics Sa-gx290 Home Theater Am Fm Stereo Receiver Sagx290 Logo
27 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
