Question about Coby TVDVD2050 20 in. TV/DVD Combo
Sound from anything but cable?
I get good picture and sound from cable input. I get good picture, but no sound from internal DVD or external VHS Or DVD. I have no remote. What do I do to get sound from any input?
Is my TV Teac model LCDV 2010M suitable for connection to digital TV or do I need a "box" for it?
Posted on Jul 11, 2013
How do I get the DVD to record what is on the VHS tape not the TV?
You can record from an external component, such as a camcorder or VCR, connected to any of the Recorder's external inputs.
1. Make sure that the component you want to record from is connected properly to the Recorder. See page 14.
2. Press AUX repeatedly to select the external input to record from.
• AV1: Audio/Video Input mounted on back panel.
• AV2: Audio/Video Input mounted on front panel.
• DV: DV Input mounted on front panel.
page 37 from manual:
http://resources.jvc.com/Resources/00/01/15/LVT2016-001B.pdf
If this fails, try to disconnect the tv input cable and connect the vcr cable.
Feb 04, 2016 | JVC DR-MV150B DVD Recorder/VCR
I have a logic tv which is just out of guarantee. Worked perfectly. Switched it off during the weekend. When I switched it on yesterday, I have sound but no picture. Any suggestions please?
Hi CJ,
First let's make sure you simply haven't pressed the MUTE button on the TV or LogicTV set top box (if equipped - I'm unfamiliar with LogicTV but most of these problems come back to a pretty simple solution). Adjust the volume down to 1/4 level.
If that is OK, make sure that you have selected the correct audio output mode for LogicTV. Typically, a Stereo Output is offered that uses a traditional Left and Right cable and jacks. The jacks are usually Red and White and labeled L and R. Other audio options include a Coaxial or Optical output over a single audio cable. This may be call a Digital Audio or Dolby Digital output. Finally, an HDMI output may be offered that sends BOTH the video AND audio over a single cable with a wider, flat jack that looks a *little* like a USB plug.
Determine which audio type your LogicTV uses and make sure that you have directed the LogicTV to use that same connection in the setup. Next, check that the A /V input for LogicTV is ALSO using the same audio type in the TV set up. If all is set right and there is still no audio continue below.
Next, we need to determine if there is no audio on ALL input sources of the TV. Try connecting an A / V device such as a VHS, DVD, video game console to one of the other A / V inputs of the TV and select it. Start the device and once you have a picture, check for sound. if you do not have sound, there may be a problem with the TV speaker or amplifier.
If you have sound, that eliminates a problem with the TV speaker and amplifier. Remove the VHS / DVD/ Game cables from the TV input. Move the LogicTV input cables to the input jacks that were just used by the VHS / DVD / Game and see if you can hear the sound in the new input selection. If not, there may be a problem with the LogicTV set top box.
Hopefully, you've found the problem! Good luck!
Mar 03, 2014 | Televison & Video
I've had my tv for maybe three years. I turned on the tv this afternoon, and I have picture but no sound. Can this be fixed?
Certainly. The only question is how hard it would be to fix it and how much it would cost. First, if you are on a cable service, try another set to make sure it isn't a cable company problem. Next, ask if anybody has tried changing sound options. Maybe somebody set it to run the sound through an external sound system with internal speakers off. Another possibility, if you intentionally set the TV sound to go to an external amplifier, is a pet, small child or person cleaning behind the set has yanked the sound cable, or the external amplifier is not working as intended.
If you've checked all of these, tried an external sound system (a "boom box" with an auxiliary input will do), and you can see the volume indicator bar go up and down without hearing anything, then you have a problem with the sound demodulator inside the set. If it works with an external sound system but not the internal speakers, the problem is in the internal amplifiers. A work-around until you can get it fixed is to use the closed caption system.
Oct 24, 2010 | Vizio L32 32 in. LCD HDTV
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
My dvd/vhs combo has sound but no picture on the vhs side?
Check ur RCA cable setting might have a short in the cables.
Dec 12, 2009 | Televison & Video
We have a picture but no sound, it is hooked up to our surround system and the dvd and radio work and we have sound coming out of the speakers but no tv sound....help
Try switching the external/internal speaker switch on the back of the tv to internal. This way you should at least get sound (from the TV not the sound system) when you change the volume of the TV itself.
Explain your set up if you need more help. By that I mean what do you have hooked to the TV and sound system, Satellite or digital cable box DVD ?
Make a note of where all the inputs to the sound system come from.
Dec 04, 2009 | RCA P56830BL 56" Rear Projection...
Hooking up my DVD/VHS player to TV & Convertor box
I would just hook up the dvd/vhs player with the red,white,yellow rca cables that should of come with your unit and just go to the input on the tv to watch your dvd/vhs player. This will give you a better picture and sound while allowing you not to have to watch dvd/vhs on a channel which helps make the dvd/vhs player independent. Also if possible I would hook the converter box up with the red,white, yellow rca cables to the tv as well if your tv has more than one set of red,white,yellow plugs since it is a better connection that coax and you probably watch more tv than vhs/dvd anyway. So bottom line try to hook up both boxes red,white,yellow and watch each box on different inputs instead of like channel 3 or 4. Also to record of converter box you can run coax from converter box to dvd/vhs combo and make sure your dvd/vhs player is on tuner input or channel 3.
Nov 16, 2008 | Insignia Digital-to-Analog Converter for...
DVD in, have sound but no picture???
Initially, a couple of ideas:
  • check the cables from the DVD to the VHS to the TV (I am assuming that the sound is likewise connected to the TV and not to a home receiver system or an amplifier);
  • I am assuming again that you are using RCA and not RF, if yes pls pay special attention to the yellow RCA on both the DVD to VHS and VHS to TV;
  • diagonal roll often indicates a loose ground or a defective cable/RCA connector;
  • verify settings/configurations in all three; DVD, VHS, TV. TV should be set to AV or Video, VHS likewise to A/V INput;
  • try playing a known good VHS tape, if normal playback, problem is between DVD and VHS, if likewise no video, problem is between VHS and TV.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 13, 2008 | KLH DVD8350 DVD Player
I have connected my DVD/VCR to my Samsung 32 inc television but I get no sound
I had a strange issue yesterday too.
Our Samsung DVD/VCr all in one combo did a similar thing.
I used the HDMI cable for the DVD into the TV input labeled HDMI/DVD. That worked okay.
But the VCR part didn't work.
At one point I got sound but no picture. Using the RCA cables in the back on another input "Component 1"
I was trying to squeeze the best picture out of the player using the S-VHS cable.
I thought it did picture only, but the Plasma seems to be more picky about input sources.
I got everything to work keeping the DVD as a separate HDMI to Plasma TV feed.
The VCR was 3 RCA's Yellow (picture) red and white for stereo sound.
I then reset (toggled through the inputs to "reset" the TV.
It finally worked but I was two days mulling it over.
See if this works for you.
My TV was a Panasonic Plasma, but shouldn't matter.
Skip the S-VHS line and connect the inoputs with the TV off.
You MAy need to go into the input of set up menu on the TV (ours had a wrench as an icon) and set the Component 1 or 2 to "VCR".
Aug 04, 2008 | Samsung Televison & Video
No sound only get sound when dvd or vhs
Good Day;
No sound on what? DVD & VHS, okay?
Need more information:
1. Where don't you get any sound from?
2. Are you using cable box, sat.,or.....? What?
3. If box what type?
4. ANT, VIDEO, COMP, HDMI or ECT. inputs.
If you are using a cable box there are some boxes that have volume controls on them, please check volume level.
Please clarify what source you are using & check all 'other' cables.
Good Luck, Day, Big Irish.
Jun 16, 2008 | Sony KP-51HW40 51" Rear Projection...
Coby TVDVD2050 20 in. TV/DVD Combo Logo
57 people viewed this question
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
