Question about Vax U91-Ma-P Air Pet Multicyclonic Bagless Upright Vacuum Cleaner
Drive belt where is the drive belt?
  • Vax Master
  • 18,424 Answers
Go here> http://support.vax.co.uk/power-2-upright to download the manual
Posted on Jul 12, 2013
Roller turns, but carpet stops it, I am able to stop it with my hands and no breaker is being tripped like when new
belt may not drive the belt directly, but there may be a belt that drives whatever(gears) does drive the roller.
Dec 24, 2015 | Vacuums
How can I get to motor drive on g4 does it have a belt
The power drive has a geared belt on the end on the armature which operates the power drive. The power drive has been out since 1990, and I have yet to see a bad drive belt in 1000's of repairs. The drive unit itself will fail very infrequently, and need replacement. The belt can be accessed be removing the handle, switch plate, and upper motor shell. The power drive unit must be loosened and dropped down to remove the belt.
Dec 15, 2010 | Kirby G4 Bagged Upright Vacuum
The drive belt doesn't turn.
The drive belt may have just melted a notch into the rubber on the motor piston.
With the cover off, are you able to move the brushes by hand? When the brush bar turns, does the drive belt move too? If so, move it for a full rotation of the belt (make a mark with a Sharpie and move it until you see your mark again)
If there's a melted notch or "Dent" in the belt, you'll need to replace it
Apr 19, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Replace the belt on a upright vac
There is a very small wheel attached to the motors drive. Belt goes around the motor drive wheel and then around the drive roller assembly
Feb 22, 2010 | Kenmore 34612 Bagged Upright Vacuum
Belt drive not working. Won't turn beater brush.
You need to replace the belt. Here is the belt you need and the manual which has instructions:
Dyson DC07 Belt and Manual
Jan 09, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
My purple proggesive kenmore upright motor works but beater not beating help thank you
I just had the same problem - reset button didn't trip - cleaned the roller - ultimately found there is an override switch at the point where the hose attaches to the base of the vacuum - it disables the roller when you use the attachments. The hose had become loose (but not disconnected) enough to trip the switch. An easy fix after alot of tinkering... p.s. All those "experts" that said to change a belt obviously don't understand that this model is beltless...
Nov 09, 2009 | Kenmore 31913 Progressive Direct Drive...
MY VACUUM IS NOT PICKING UP
Hi This is quite complicated but I'll try and simplify this for you:
If this is a Panasonic upright then there are two drive belts as you know. Once you take off the sole plate (where the beater bar is) by undoing screws and the beater bar is looking at you, you would have to take off the smaller belt motor pulley first before putting on a new larger drive belt. If the smaller belt is still intact and you only need to replace the larger belt, you'll still have to take off both belts to put on the new drive belt.
Motor pulley belt has to be taken off first then the old drive belt, then grasp the beater and slide on new larger drive belt before having to attach the motor pulley belt and then the larger belt onto the motor pulley. Once all belts have been attached ensure that the beater bar is pushed in correctly before you screw the sole plate back on.
Apr 03, 2009 | Panasonic Vacuums
Eureka 5843 belt keeps slipping off of drive spindle.
Tough one. Typically the only 2 things that the belt contacts is the motor drive spindle and the brush roller. Anything else would only be there to protect the belt from debris. Can you turn the brush by hand and see why the belt is coming off? Is the spindle wobbly? If so, you may need another motor as I don't think it is easy to get parts for the motor. Hope this helps and good luck!
Mar 22, 2009 | Eureka Whirlwind LiteSpeed 5843 Upright...
Belt Stretched on my Hoover Windtunnel Farrington upright model U6431-900
hi, In order to to replace the V belt the one that turns the brush, One must take off the bigger belt " drive belt" that goes over that hugh wheel towards the back. When a belt gets stretched they will not turn the brush very well. If you have bought replacement belts the bigger belt Drive comes 2 in a package. Then you have your little V belt that helps turn your roller brush over. Yes the belts don't last long on my hoover. For kpatr22101 When you rpelace that V belt it goes over the roller brush into a little groove on the brush and then over a plastic round wheel then you must put on that bigger drive belt that must fit over that hugh wheel towards back and smaller on in front. Yes it is hard to get on. the I hope this helps. Cindy G.
Jul 17, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Need to change a belt on my Hoover Concept One Power drive
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=766023
Generic problem for all Vacuums
Posted by gentilly on Jul 10, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. On the Hoover Concept One Power Drive Upright vacuum there are 2 belts, a drive belt and a power drive belt, always use the Hoover genuine belts and for the best cleaning always change you vacuum belts every 4 to 6 months for the best cleaning. !st, remove the bottom plate and cut off the old belts – then you need to lift up the one side of the brushroll that has the pulley side for the longer of the 2 belts and slide it on. Replace the brushroll, B4 you go to far remember which went on 1st, the power drive belt (smaller belt) or the brushroll belt, in either case hook the belt(s) onto the pulley 1st and then use a belt puller or a screwdriver with a hook or bend on the end and stretch the belt(s) onto the motor pulley and then track the belts in a straight line – do this on both belts. Once you have done this then replace the bottom plate. Check your owner’s manual in the trouble shooting guide to see if they also have suggestions or check with your local vacuum cleaner dealer in your area or contact the Hoover website or the Hoover factory cust serv phone # listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 10, 2008 | Vacuums
Vax U91-Ma-P Air Pet Multicyclonic Bagless Upright Vacuum Cleaner Logo
244 people viewed this question
Top Vax Vacuums Experts
rugby prop
Are you a Vax Vacuum Expert? Answer questions, earn points and help others
