Thi will be the 2nd time I ha to do this. The sound just goes off. !st time cost me 75 dollars to have someone come to the houseand just reset it. I know it's in theback
I don't know that it is a common fault with this specific model, but laptops in general have this issue mostly due to a dying LCD power inverter. It is typicaly located at the bottom of the LCD screen and costs between $30 - $75 dollars for the part, and usually $75-$150 for someone to replace. If you like the laptop it is usually worth it to have replaced. You can also hook up a monitor to the VGA port on the laptop and then go into your display control panel and enable 2nd monitor to use it instead of your laptop lcd.
coil over spark plugs one of the coils r bad DO NOT UNPLUG COILS AND PLUG THEM BACK IN WHILE ENGINE IS RUNNING. this causes a electric spike that goes back to ecm and ruins it. the ecm cost me 600dollars and then i had to have it flashed for 700dollars at dealership. didnt make any money on that job ha ha
If you do it your self,and you work cheap ha ha,the cost of the axles at NAPA auto parts is about 57.95 each give or take a couple of bucks.At reasonalble shop,labor would run about 40.00 to 50.00 dollars a side.
It would cost about 3 times as much as the radio IF it could be done. I myslef don't believe it can be, techs can't even turn up the wattage in those things.
The high-pitched squeal is from the power supply, usually because of failure of the horizontal output transistor, flyback transformer, or both. Without a specific model I can't give more definite information about part numbers or likely costs. But repairs of this type usually have parts costs in the 10 to 75 dollar range (depending on just which parts are bad, and where replacements come from) plus whatever labor costs the repairer charges.
Sounds like the bulb has burned out in the TV. Sometimes the TV has surges or spikes in power and it can overload the picture bulb and fry the bulb without you even noticing anything. The main indicator of this is that there is no picture but there is sound. The bulbs can cost anywhere from 75 dollars to more than 300 dollars. If you can finally reach the company you bought it from and have them look at it they will tell you the same. There are sites to look up the prices of new bulbs but if you have a warranty through the company you bought it from then it would be free of charge to replace.
Some large hardware stores like Home Depot stock them. Most appliance parts stores sell to the general public. Marcone appliance parts in St. Louis will sell mail order. Have the model and serial Number available. I always replace belt , idler pulley and back support wheels together. They usually go bad about the same time. I'll bet that the dryer is pretty loud isn't it. The support rollers usually cause the belt to break or a stiff pully. Total parts cost is under 50 dollars
ESTIMADO DISTRIBUIDOR:
TENGO UN TELEVISOR ILO32HD Y NO PUEDO CAMBIAR DE CANAL NI CON EL CONTROL NI MANUALMENTE ME HE COMUNICADO CON USTEDES Y NO HA SIDO DEVUELTO LA LLAMADA. LE AGRADECERE QUE SI NO ES MUCHA MOLESTIA ME PUEDAN AYUDAR AUNQUE SEA ENVIANDOME UN EMAIL ATRAVEZ DE MI CORREO ELECTRONICO PARA DICHO PROBLEMA. PARA PORDER CORREGIR LA AVERIA QUE DANDO PREOCUPACION ME HA CAUSADO. GRACIAS
CORDIALMENTE,
MARIBEL RIVERA
110 E. BROAD ST APT A203
TAMPA FL 33604
[email protected]
