Question about Radio Shack Pro-96 Scanner
Scaner not functioning properly wont scan
Scanner will not starting scanning when turned on
SOURCE: Pro-95 scanner has stopped scanning
Shit I don't know.
Posted on Jan 26, 2008
Mechanic688
  • 204 Answers
SOURCE: stuck on scan mode
Hi, It sounds to me like your keypad is locked. Pg 63 of your manual.
***using the keylock ***
Once you program your scanner, you can protect it from accidental program changes by turning on the key lock feature. When the keypad is locked, the only controls that operate are FUNC, key , SQ, and VOL. You cannot activate the keylock while you are entering a frequency into a channel. To turn on the keylock, press FUNC then key . Key locked appears for about 1 second. Key locked appears when you press any key after locking the keypad.
To turn off the keylock, press FUNC then key . The scanner beeps three times and Key unlocked appears.
The only other choice I see if that does not work would be to initialize it. Pg 84 of your manual. Hope this helps you,, Mechanic
  • 13433 Answers
SOURCE: will not scan properly
Hello
I suppose you are trying to scan the channels by hand, If I'm not mistaken this model can also be hooked up to the pc.
Manual pages 55 and forward are on scanning, I suppose you have been throught those.
I't must be a simple setting wrong somewhere.
Posted on May 15, 2008
BillB-SA
  • 2761 Answers
SOURCE: Scanner not receiving
Performing a RESET will not clear/erase frequencies or other data programmed into the scanner. If the RESET doesn't work though, you may need to INITIALIZE the scanner. That procedure will clear all programmed data and return the scanner to its "as new" state. Need the manual for your PRO-82? You canb download/print it here:
http://support.radioshack.com/support_electronics/doc69/69887.pdf
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Bill B
Posted on Feb 24, 2010
  • 8 Answers
SOURCE: Pro-96 Scanner: My pro 96 scanner says all channels locked and it ...
If there is no frequencies on your scanner it will lock all channels out. if all your frequencies are on one bank and you accidentally hit that bank number and turn it off it will lock out all channels. If that's the case just hit that bank no. back on and they will unlock.
Posted on Aug 05, 2010
How to get windows to see the scanner every time.
Buy and install the 'Viewscan" scanner driver utility.
Then: Found that for windows to reliably see the scanner start windows, go to device manager, turn the scanner on and as it goes through its setup, right mouse click and select "scan for new devices" Windows 7 will now see the scanner right away.
May 13, 2014 | Acer ScanPremio 1220ST Flatbed Scanner
Wand Scanner - panscn08 buttons do nothing
Yes follow the first steps to set up the scanner (charge it, properly insert the memory card, etc.) Then you are ready to scan
Once you press the SCAN button and the Green LED stays lit its time to roll the scanner down your document to be scanned. When finished press the Scan button again to STOP the scan. If successful your Document count in the display will move from 000 to 001. That is the only indication that you now have a successful scan.
Next Press and hold the SCAN button until the display goes blank.
Now you can remove the memory card (by pushing in and it will release). Place this memory card into a memory card reader on your computer to transfer and view your scanned documents. Rinse and repeat.
BTW, I found a quick start guide for this Pandigital Handheld Wand Scanner Model PANSCN08 at:
http://www.qvc.com/footers/E167092_quick-start-guide.pdf
Good Luck!
May 04, 2012 | PANDIGITAL PANSCN Office Equipment &...
Scanner gives me code 5,145,61 how can fix it ?
RE: Scanner gives me code 5,145,61 how can fix it ?
I was using wireless router and receive exactly the same error code as above.
SOLUTION: Turn-off printer/scanner; reset or turn-off the wireless router power and then turn-on again. Turn-on the scanner. Start scanning.
Mar 11, 2012 | Canon PIXMA MP495 InkJet Printer
How do I get it off manual scan uniden bc72xlt when i turn it on it won't scan. thanks need help.
these scanners are a little hard to operate i have one of these it took me a while...Ok its because you have it on hold.when you turn your scanner on press your scan button.and your scanner should start scanning...
Jul 09, 2011 | Uniden BC72XLT Handheld Scanner
Hello,i have this type of printer :samsung scx-4623f.the question is if i can scan without toner cartridge?the toner is empty and i want to use only the scaner,is possible?
Hi there!
It should work, most multifunction works even with no toner in it, just make sure that the scan function and scan driver is installed. You can scan using (for windows XP) Scanners & Camera Wizard. Start>All Programs>Accessories>Scanners & Camera WIzard. for windows VISTA & 7 Click on Start type in WIAACMGR on the start search box and click on it. You can also use Windows fax & scan for windows 7
.Hope this helps. Please rate if this works Thanks!
Mar 30, 2011 | Samsung SCX4623F Laser All-in-One Printer
Hello am using sharp ar165 m copier machine .and am installing my pc also but scaner is not working please help me.
How are you doing? In order for scanner to work in all multi-functional printers, you must install all functions. While installing printer Sharp Ar165m, it will ask you if you need to install scanner and you must select that box otherwise it will install printer alone. Also there is an option where you are to configure the button keys on scanner function, please configure the buttons while installing. This will allow you to press scanner key on the copier to start scanning without necessarily selecting from the computer otherwise --- will appear and nothing happens. So insert the software CD and remember to select scanning option.
Dec 15, 2010 | Sharp Office Equipment & Supplies
Scaner Short Cut
did u tried to search for the scanner button software ? try to see for it
Jul 23, 2010 | Canon LIDE20 Flatbed Scanner
After 2 yrs unused have decided to run in new dell
Did you plug in the scan unit and then installed the software?
If you did you will have to unplug or turn off your scanner then uninstall your software.
Reboot and the with the scanner turned off reinstall the software. If the install asks you to plug in your scanner, turn it on. If it asks you to reboot, then reboot. After rebooting, turn on the scanner then start the Easy Scan Utility. This should work.
It worked for me.
Jan 26, 2010 | Konica Minolta Dimage Scan Dual IV Film...
Hanging problem
scan the exit code it will close your scanner and then scan the recall default code (4 times) then scan the ENTER code your problem will be solve
Eshwer
Dec 18, 2009 | Eclipse Metrologic MS5145 Barcode Scanner
It just scans and scans it never picks anything up. No clue how to work this scanner or where to get codes for it. When you turn it on, it just scans thru all the channels but doesn't seem to pick anything...
Sounds like either your squelch is set too high or you don't have the proper frequencies for your area programmed into the scanner. When it starts scanning turn the squelch down gradually until the scanning stops and you hear noise, then turn up slowly until it starts to scan again. If you still don't pick up anything, you probably need to reprogram the frequencies. For a list of active frequencies and systems in your area visit
or
www.CityFreq.com
In case you need it, here's a link to the manual for your scanner.
If you have any other questions, please contact us again.
If this response helps, please take a moment to post a rating for me. "Very Helpful" would be appreciated.
Nov 26, 2009 | Radio Shack Pro-2051 Base Scanner
Radio Shack Pro-96 Scanner Logo
49 people viewed this question
Top Radio Shack Radio Communications Experts
Jason
john milligan
Steve
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
