My panasonic viera is brand new and the arrow up/down channel wont work but all of the other functions do, i went back to the store and they gave me a new original control and the same prob, everything works except for the up/down channel button.
    Top Expert:
  • Televison & ... Master
  • 74,459 Answers
Up/Dn buttons will work only after an item have selected.
Posted on Jul 12, 2013
Kimi
  • 277 Answers
SOURCE: Panasonic Viera 42" TH-42PV30
Check the 2 main interconnection cables (24pin and 26pin) rear of PDP and Tuner box. Make sure they are firmly connected. (Loose connection of 24pin will cause no power on symptom.)
Posted on Oct 21, 2005
SOURCE: Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Posted on Oct 23, 2008
SOURCE: Channel Up/Down button quit working on the remote control
I had the same problem. You need to go into SETUP > CHANNEL > SKIP and select NO for every channel with a signal. A few months after we purchased the TV it defaulted to this (software glitch). We had lived with it for months before figuring this out. There is no easy way to reset these that I know of. I literally had to go to each channel and then change "skip" to "no." JM
Posted on Jun 13, 2009
SOURCE: Panasonic viera has flashing channel info in upper left corner
I had this exact same issue just yesterday. Channel info would flash intermittently. While set was in this mode, could not enter menu, change channels, etc. from remote or front panel controls. Similar to tjh492, I thought it might be an overheating issue. But unplugging the Viera and waiting for set to cool made no difference.
I then remembered that this issue popped up the instance I surfed to a particular channel (FWIW, 26-3 "Me Too" on Comcast here in Aurora, Illinois, USA). I had a hunch that there might be an issue with the signal on the channel that prevented the Viera from properly syncing, so I decided to unplug the antenna cable. Once I did that, the channel info displayed steady. I was then able to change channels (of course screen was blank as antenna cable was unplugged) and enter the Viera menu. I immediately went to channel set-up and manually removed channel 26-3 from the channel list. After reconnecting cable, Viera was back to normal. Since I'm not a big fan of "Me Too", problem solved :)
Not sure why a digital channel sync issue would effectively make the Viera remote and front panel controls inoperable. Pure speculation, but it could be that the Viera microprocessor was overloaded trying to sync to channel and this prevented any interrupts from remote or front panel controls.
Posted on Jun 24, 2009
SOURCE: Viera Link not work between two brand new Panasonic devices
You need to select setup from the TV menu then switch the Viera link on. I think retuning must have switched it off.
This worked for me
Posted on Oct 03, 2009
Plugged in USB device on Panasonic vierra gave me overload warning screen went haywire. Now it won't turn on . no blinking light though
usb overcurrent error message on plasma tv - PC World Forums
pressf1.pcworld.co.nz > Forum > PressF1
Jul 4, 2012 - 10 posts - ‎5 authors
we have a panasonic viera tv ( plasma) when i plug in my 1st portable ... Since thedevices are not powered the overcurrent warn isn't from external sources which leadsme to think there is a physical problem with the 2nd drive. ... for the TV doesn't work, try getting firmware for the drive from WD's site, that ...
How To Use DLNA And External HDD On Your Viera TV ...
? 4:08
https://www.youtube.com/watch?v=JqeLDaB5nvQ
Feb 9, 2011 - Uploaded by PanasonicUK
http://www.panasonic.co.uk/ How to setup and use the DLNA andUSB HDD functions on Panasonic Viera TV's. ... Is there not any way to access an external hard drive without recording ... I can record using the HDD but it doesnt let me record SCART or HDMI, why is this? ... Anyone have the same issue?.
Dec 25, 2015 | Panasonic Televison & Video
I have a cable coming from the wall, and when I hooked it up to my TV Panaconic 42'' viera Just bought the TV today. . the screen is black and keeps saying No signal.... what could the problem be? Just had...
You either set the options incorrectly when running the "First Time Setup" or you skipped the first time setup entirely. Even though the cable works with your older TV, you still need to setup your new TV correctly to receive the cable feed.
The quickest way to do this is run the setup manually from the menu as follows:
1. Turn the TV on
2. Press the "MENU" button on the remote
3. Use the DOWN arrow key to highlight "SETUP" (the arrows are the big ring button around "OK")
4. Press "OK" to enter the SETUP MENU
5. Use the DOWN arrow key to highlight "PROGRAM CHANNEL"
6. Press "OK" to enter the PROGRAM CHANNEL MENU
7. Use the LEFT/RIGHT arrow key to ensure "CABLE" is highlighted
9. Use the DOWN arrow key to highlight "AUTO"
10. Press "OK" to enter the AUTO SCAN MENU
11. Highlight "ALL CHANNELS" using the UP/DOWN arrows
12. Press "OK" to start the AUTO SCAN
The scan may take several minutes to complete.
13. Highlight "APPLY" using the the LEFT/RIGHT arrow keys.
14. Press "OK" - all of the scanned channels will now be saved.
The TV should now return to viewing mode and you should be able to watch cable on your new TV. If the TV does not automatically exit the menu, simply press the "EXIT" key on the remote, next to the MENU button.
Please run through the above steps and if you are still unable to get the cable channels on your new TV, please post back for further assistance.
Regards,
BElectric
Dec 16, 2010 | Panasonic Viera TH-46PZ85U Plasma TV
Panasonic Viera TH-50PX60U Plasma is stuck on one channel. Only the power function works on the remote and only the On/Off function works on the TV. Any ideas??
Forced to factory default: press and hold [VOLUME ( - )] on the TV and press [MENU] on the remote 2 seconds. Exit: Unplug Power to reset.
If it does not help, the main board need to replace. For further questions, please add your comment.
May 20, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Panasonic Viera LCD TV Can't Find Channel 7
I can't receive channels 3 and 6 right across the Delaware in Philly. Welcome to the club.
Aug 15, 2017 | Panasonic Viera TC-L32C12 32 in. LCD TV
Jun 24, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
Panasonic dmr-eh50 Clock setting greyed out - unable to reset clock after clocks went back.
To resolve this issue follow the steps below:
(1) Remove all discs from the unit.
(2) Set the unit to DVD Mode
(3) From the front panel of the unit, open the middle door to display the up and down channel buttons
(4) Press and hold both the up and down channel buttons until the unit displays "BYE" and then flashes "12:00 A"
(5) Release the up and down channel buttons
(6) This will clear the unit and you will be prompted to reset the TV Guide Settings
(7) Setup your TV Guide according to the on screen display
(8) From your remote select "SETUP"
(9) Scroll down to "Setup", right arrow to the options on the right, and down arrow to "Clock Settings"
(10) Select "Set Clock Manually" if your TV Guide Function is not providing you with the proper time
Good luck!!!
Oct 26, 2008 | Televison & Video
No sound on some channels
Had same problem on Viera 3D Plasma TH-P54VT20A
Select Sound from setup menu and ensure SPDIF Selection is set to PCM (not Auto)
Feb 28, 2008 | ViewSonic NextVision N2010 20 in. LCD...
Panasonic Viera Plasma TH-42PV7HS- Shutting down
CHANGE P.A BOARD. THIS BOARD IS FOR TUNNER VOLTAGE..IF THIS BOARD IS BAD, THE LED FLASH 10 TIMES IN RED AND THE TV NO TURN ON.
Oct 30, 2007 | Sony KLV-S23A10 23 in. LCD HDTV
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
