Question about 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Viper LED not flashing when armed
I have a viper car alarm and the blue LED will not flash when i arm it. the lock/unlock/auto start buttons work perfectly but when i press the lock button to arm the car, the LED will not flash. However, when i am inside the car and i arm it the LED flashes. Any ideas on how to fix this so that the LED flashes when it is armed and i am not inside?
  • John Bernal Jul 11, 2013
    Problem solved, turns out it had to be locked then unlocked then locked again and it works now
jpk528
  • 95 Answers
SOURCE: when i arm the car how can i hear the sound viper on
whats the make and model fo the alarm? and go to viper.com/support for more information
Posted on Feb 16, 2009
  • 5 Answers
SOURCE: i have a viper alarm with remote start the remote
the alarm is in valet mode .open a door press lock unlock lock on the remote and it should take it out of valet mode
Posted on Oct 09, 2009
SOURCE: viper alarm keypad will beep for 30 seconds every time I arm or disarm
Change the battery, 2-way remotes require 2 slim batteries on top of one another. Regular remotes only require 1.
Posted on Nov 16, 2009
  • 306 Answers
SOURCE: viper 5701 remote issue
sounds like the remots have lost two way communication. try to disconnect the windsheild antenna.try remotes again after pluging antenna back in.
Posted on Feb 08, 2010
iadame
  • 676 Answers
SOURCE: My Viper 5701 has been
Check to make sure that the valet is not engaged. The alarm will notify you by having a constant lit light. If the light flashes like it should open a door and check to see that the light blink on and off as if the alarm were triggered. If this happens the your problem is with the siren, just have it replaced.
Posted on Jul 27, 2010
My viper alarm system when armed and disarmed there is no sound from the speaker
Either the system is in valet or, the chirps have been deleted or, the siren is broken.
If the LED is on solid the system is in valet. open the door, press lock, unlock, lock on the remote to remove valet.
Press and hold the lock button. This activates the car finder/panic. The siren should begin to wail. If it does, the siren works. If it doesn't and all you see is the aprking lights flashing the siren is defective.
Mar 04, 2013 | 350 HV ESP Security System 350HV ESP
Viper 5701 led light does not flash when armed, stays lit when alarm is disarmed
If the LED is on solid then the alarm is in valet. To exit valet, press "F" twice then press unlock on the remote. The LED should turn off.
OR,
enter the vehicle, turn the ignition on then off, press and release the valet/programming button on the antenna. LED should turn off
Jan 30, 2013 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I think I messed up the remote programing.. When I press to lock the doors they do lock but the horn doesn't honk anymore.. The blue light on the dash does not light up either.. I can still remote...
If the led is solid blue when the key is out of the ignition that means your in valet mode. Which would disable the alarm, but not the starter.
Simply turn key to IGN position then back to OFF.Push the valet button which is on the antenna next to the led and the led should turn off.Close door on vehicle and lock vehicle.Siren should now chirp.
Cheers!!
Sep 16, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Hi. I have a Viper 5701 alarm in my car. Arm and disarm goes very well with the control unit. But I cannot programming to pasive arming, always have to use de button in remote control to works. Is ther a...
Open door, turn ignition on then off. Press aand hold programming button until you hear one chirp. After you hear the chirp, release programming button, press and release button one then press and hold. You will hear one chirp. While holding the programming button, press lock button on remote to change option. One chirp is active arming(what you currently have), Two chirps is passive arming without locks, Three chirps is passive arming with locks. Turn ignition on to exit programming. Test system.
Jun 13, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Just notice blue lights flashing in the car. I unlocked, from inside the house, and manually locked from the lock on the inside door. That stopped the flashing blue lights. What has caused...
Do not be alarmed; the blue light is flashing because you used the remote to lock/arm the vehicle. It is a visual theft deterrent, even if you do not have an alarm. It's normal. The reason the light stopped flashing is because you unlock the vehicle with the remote and locked it with the door switch.
Feb 11, 2011 | 5301 LE 2 Way Car Remote Starter System
My led light for my alarm stays on and the alarm dont work anymore but the button still locks?unlocks/and starts
Your system is in valet. To take the system out of valet with remote: open any door, press lock, unlock, lock. Now check the LED; it should be off. Close the door and arm the system to check.
OR
Turn the key on then off. Within ten seconds press and release the valet switch. The LED should be off now. Close the door and arm the system. The alarm should chirp to confirm that it is armed.
Nov 26, 2010 | Remote Start System
I have had my Viper system for some years now with never a problem, that is until yesterday. Now when I arm or disarm my system the horn does not chirp and the small red dash light stays solid red instead...
Your alarm is is in valet. to take the alarm out of valet with the remote: open any door. Press lock, unlock, lock. The LED should be off now. Close the door and lock the doors with remote. The alarm should chirp to confirm that it is armed.
OR
Turn the key on then off. Within ten seconds press and release the valet switch. The LED should be off now. Close the door and lock the vehicle with the remote. The alarm should chirp to confirm that it is armed.
Installed. Arm the car locked. About 2-3 hours
You must change the doors trigger connection if you have a negative input change it to positive input or vise versa and try. I’m sure that this is going to end your problems or the smart way is, take it back to Best Buy
Jan 08, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
The alarm doesn't chirp and no flash of my headlights anymore. Also the blue light stays on the little receiver/antenna on the windshield wheather it is locked or not. What is the problem?
sounds like the alarm went into valet mode. that's usually what a solid blue light means on most viper alarms. check your owners manual on how to take the alarm out of valet mode. with the 5701 alarm its usually done with the remote. hope this helps
Aug 04, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
5701 VIPER 5701 2-WAY ALARM w/REMOTE START Logo
85 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
Tre Elkins
Shehu Pro
Shehu Pro
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
