Question about Toro LX423 20HP Lawn Tractor 13AX90RS848
Lx420 transmission jerking
Transmission jerks in gear change
Trans jerk is a sign of wear and tear. You don't say how many miles its done? Is the trans fluid level correct? When was it last serviced? Have you asked a good home mech/garage to ride with you to see fault?
Nov 01, 2015 | 2001 Buick Regal
My car jerks going down the road its a 95 Buick century and it changes gears fine when I take off just stares jerking a few days ago
When you say it "jerks," this description could fit several actual symptoms. If by "jerks" you mean the engine misfires, it could be caused by the need for a major tune-up (including plug wires and distributor cap), or it could be a problem with fuel delivery, contaminated fuel, or defective components in the fuel system.
I assume the CHECK ENGINE light is on (and has probably been illuminated for some time now). Begin by doing a readout of the stored codes, and use the results to begin your diagnosis.
If by "jerks" you mean the transmission is slipping (engine revs but car slows down or doesn't accelerate), you have a transmission issue. If the transmission fluid and strainer/filter have not been replaced within the past 5 years or 50,000 miles, have a complete transmission service performed.
If by "jerks" you mean that the steering wheel wobbles or pulls, you have a problem with the front suspension.
If by "jerks" you mean that the car shudders or pulls when you apply the brakes, you need brake work.
I think I covered all of the "jerks." ;)
May 13, 2015 | Cars & Trucks
Car giving jerks
One of the more likely possibilities is a problem in the transmission. I wish I could be more specific, but I don't know enough to offer more details.
Jun 04, 2014 | 1994 Ford Taurus
1nz engine automatic transmission shift with a jerk how do i stop the jerking
it maybe ECU malfunction bring your car to a mechanic for checking fault code
Dec 09, 2013 | 2002 Toyota Corolla
2006 Kia Spectra transmission will not have overdrive once it jerked. Usually RPM is at 2500 when driving up to 70 mph; but after it jerked, RPM will stay over 3000 when driving over 50mph, also it will...
you might have to have your transmission downloaded.you have to go to a kia dealer\'put it on a machine.if the code is out it will make your trans mission jerk.cost me $400 dollars.in my 2006 kia spectra ex
Nov 02, 2013 | 2006 Kia Spectra
Car chugs and jerks like crazy while cruising
Determine whether the jerking is engine or transmission related. One way to determine if it is the transmission lock up converter is acting erratically is to down shift out of OD. And see if jerking persist. If it goes away suspect transmission to have problems with torque converter or TCC solenoid . If it doesn't go away determine whether or not the engine sounds to be misfiring. If so vehicle may require a tune up. Many vehicles can be diagnosed for free at your local Auto Zone.
Jul 19, 2010 | 1995 Oldsmobile Eighty Eight
My 2000 Beetle is jerking when it changes gears. I had a transmission put in about 14 months ago. I had it looked at a the local VW business and they told me that I needed a transmission. My machanic said...
when it jerks during gear changes it could be a couple of things.
First of all, check the fluid level in the automatic transmission.
Secondly, check the mounts for the engine that they're tight and secure and if they are then
Thirdly, ask the transmission shop if the torque converter is bad in it.
The torque converter could be locked up somehow causing this jerking and I wouldn't be surprised if the transmission shop lists a recall on it.
Actually, even if there is NO recall on it, tell the transmission shop that put the transmission in to check it out, and if possible rectify it under warranty.
I wish you luck in getting this fixed correctly.
Jul 14, 2010 | 2000 Volkswagen Beetle
My car jerks when changing gear what do i do
theres most likely a bad sensor located somewhere on the transmission.
Apr 11, 2010 | 1999 Honda Accord
Transmission jerks when you step on the gas
check the transmission mounts, also check the transmission fluid level,
Jul 30, 2009 | 1992 Buick Regal
Toro LX423 20HP Lawn Tractor  13AX90RS848 Logo
24 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
