Question about Electric Currie EZIP 500 Scooter
Wiring diagram when i turn it on the light comes on full and as soon as i give it some throttle the light goes out
Mine too
Posted on Oct 26, 2013
2003 saturn vue 2.2l 4cyl. code P1516, SES and reduced power light on. What is causing ETC fuse to blow.
P1516 Electronic Throttle Mod Throttle Pos This is the code for the TPS switch you changed the ETC should be for the cooling sys. It could be a short inside the temp sw. itself or a bad wire see if you can run a wire from the battery to the cooling fans and see if they run ok. if so I would change the etc switch as it doesn't cost that much and go from there. The limp home mode is probably caused by overheating at this point. Reset the ecm and see if it comes back after you change the etc switch. Hope this helps.
Jul 24, 2016 | Saturn 2003 VUE 4 CYL
I need to no where the red wire from computer goes on fuse box ( had new harness installed and was told the red wire from computer goes to fuss box
Typically the red wire is a Positive voltage wire. If you were told the wire goes to the fuse box, you should get a wire diagram for the wire harness. On the diagram it should show connections marked with numbers and possibly colors. The computer on the wire diagram should show a red wire marked Vcc or Positive or something like that, trace that wire on the diagram carefully to the fuse box on the diagram, the fuse box on the diagram should be marked with a fuse rating at the location where the wire connects. As long as the fuse rating is the same and it's marked as "ECU" or something similar related to the "engine control unit", that is where you connect it. DON"T put it on any other connection with a different fuse rating, it could damage the computer as soon as you turn the key. this should give you enough info to get it connected and if not you can refer to this to explain to someone else. Good Luck.
Nov 26, 2014 | Cars & Trucks
Why would throttle position sensor need to be replaced multiple times?
Sounds like the Voltage to the TPS is to high, burning them out to soon, unfortunately the only thing I can think of is a FULL COMPUTER DIAGNOSTIC !!
Nov 15, 2017 | 2004 Ford F-250 Super Duty
The oil light come on when I turn right in my 96 ford taurus
It depends on what the problem is.
It could be a problem in the wiring, or you could really have low oil pressure.
If the engine oil level is up to the full mark, I would check the pressure switch and the wiring. You may need to connect a mechanical gauge and drive it to make sure the pressure is normal.
Feb 26, 2013 | 1996 Ford Taurus
When my head lights comes on in my 1997 lincoln town car the radio do a constant scan, just keeps scanning i have changed the light switch
The headlight wiring and radio wiring is getting in contact and causing the short.Both the grounds needs to be checked.Because when headlight is off,the radio work's fine.As soon as the headlights are turned on,the radio goes in scan mode.Its clear indication of radio and headlight wiring issue.The wiring's are getting in contact with ant metal surface or both the radio and headlight wire are coming in contact,where they should not.I suggest you to check the headlight and radio wiring diagrams for your lincoln town car.Here is the direct link.Click the link below :---Check out all the 3 links one by one.Radio wiring diagram for 1997 LincolnTown Car?http://technoanswers.blogspot.in/2012/02/radio-wiring-diagram-for-1997-lincoln.html
----------------Lincoln Town Car Radio stereo wiring?
http://technoanswers.blogspot.in/2012/02/lincoln-town-car-radio-stereo-wiring.html
---------Headlight wiring diagram for 1997 Lincoln Town Car?http://technoanswers.blogspot.in/2012/02/headlight-wiring-diagram-for-1997.html
----------This will help.Thanks.
Feb 13, 2012 | 1997 Lincoln Town Car
My 1989 full size bronco has had a problem starting. i have a push start in it but i have to turn the ignition to give power. when i do that it takes all power away from vehicle so it cant start. with the...
It sounds like you have mixed your PRIMARY POWER
to your starter solenoid (Specifically "S" and "B" leads).
My best suggestion would be to either get a REAL
shop manual for your ignition switch... or use the
FREE wiring diagrams from BBB Industries...
Registration is required at
BBB Industries Premium Alternators Starters Power Steering Products
THIS simple REVERSAL would
allow the starter to crank... but releasing
the key would cause it to die...
"B" is on full time battery (Coming out of the solenoid)
"S" only has battery on it when the IGNITION KEY
is in the "START" position
Looking at the DRAWINGS
Savvy...?
Carnac the Magnificent
Oct 10, 2017 | 1989 Ford Bronco
Replaced motor after a rod failure now no throttle and motor does not shut off when key is turned back also low coolant warning came on but the tank is full
Please do replace the TPS (throttle position sensor) to resolve the problem. This will surely help on the lack of power. Regarding the engine issue, have the computer resetted.
Feb 08, 2011 | Chevrolet Silverado 2500HD Cars & Trucks
Engine runs on reduced power
Pt 1 2007 Chevy 2500HD Reduced Engine Power Warning Fault Code P1516...
There are a number of these type videos on youtube ! Do you have a DVOM - digital volt ohm meter ? Find a wiring diagram at http://www.bbbind.com/free_tsb.html Three are two position sensors on the gas pedal an two on the throttle body . Find videos on test TPS - throttle position sensors , check the circuits too the PCM an from the gas pedal to the PCM . You can also check motor circuit as well .
GM Reduced Engine Power Mystery Solved
Drive by Wire Function and diagnostics by Wells
Mar 24, 2017 | 2002 Oldsmobile Bravada
1985 S10 Blazer; Choke light comes on, overcharge indicated
As for your choke problem--- Check for blown fuse under dash labeled as choke. If ok then check for faulty fuseable link at starter.
Mar 31, 2009 | 1985 Chevrolet S-10 Blazer
Electric Currie EZIP 500 Scooter Logo
187 people viewed this question
Top Electric Toys Experts
Robert A. Watson
Robert A. Watson
Tom Chichester
 Russ Hill
Russ Hill
Are you an Electric Toy Expert? Answer questions, earn points and help others
