Question about Garden
How to set timing on a honda gvc160 6.5 hp engine
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,069 Answers
The timing is set by the magneto sitting on the Shaft that is fixed by a Keyway. If the timing is off it is because you broke the key. Did you hit something that made the mower stop?
Posted on Jul 15, 2013
How to set timing
have to pull the cover and flywheel..
May 06, 2015 | 13 HP Engine GX390 OHV Horizontal Shaft
How to reset the timing on a 6.5 HP honda
The engine timing is set by a flywheel key. Remove cover and flywheel and check the key and keyway for damage. If damaged replace
Jul 22, 2014 | Honda GX200-RH2 22mm Shaft 2 to 1 Gear...
How do I set the timing on my Honda 7.5 hp 4 stroke outboard
if you havent moved the ignition plate etc then remove cam belt and put top piston to tdc and the cam pully to tdc ( mark on head ) refit belt and rotate engine by hand to check nothing catching then try !
Mar 07, 2014 | Boating
Timming light on 2008 hilux
please post year, make and model of car clearly (Honda Hilux?)
and a full question, extinguish what.
post engine type. if it is one of 30 honda engines, state the
exact engine, if in fact engine related,
here is an example of good post
USA car: yes, post country, !!
My 2008 Honda passport, with
i want to set timing on the spark.
i look in alldata.com and it says, (why?)
answer: on V6
These engines are equipped with a Distributorless Ignition System (DIS). No adjustment is possible.
2 engines here/
2.6L 120 hp (89 kW) I4
3.2L 175 hp (130 kW) V6
Dec 03, 2013 | 2001 Honda Passport
How to check timing on small honda engine
when you take the engine apart, look on both gears there is an impression, like a dot. put the two dots together that is your timing.
Sep 19, 2010 | Global Industrial Water Pump 2 Inch...
I have a 5.5 hp gx 160 honda engine. i had to replace the pull rope & now it will not recoil after starting. what did i miss?
re -do it and make sure it's on properly , do not let it snap back hard...that will screw it up every time. Pull it and slowly let it slide beck in. hope that helps
Sep 18, 2010 | Honda 8 HP Engine
Clone honda 6.5HP engine
hi
valve clearance(cold0
intake 0.005to0.007inch
exhaust0.007to0.009inch
byesavumihai71
Sep 12, 2009 | Electrical Supplies
What is the rpm of a honda 8 hp engine
full throttle it is 4500-5500 RPM
May 19, 2009 | Honda 8 HP Engine
Honda 5.5 hp air comp. no spark wont run
Most honda engines have an oil sensor that prevents the engine from starting if the oil level is low or oil is dirty. Test coil by disconnecting oil sensor wire. With sensor disconnected coil should fire. If still no fire, check kill wire for short. If still no spark, coil may need to be replaced. enjoy
Nov 28, 2008 | Honda Quincy 17 - Gallon Air Compressor...
Garden Logo
61 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
