Question about Exercise & Fitness
Belt ajustment ac 3.0 98 ply. voy.
Belt keeps coming off adjuster pully looks to be out of line
    Top Expert:
  • 12,223 Answers
Please see the video and fix it. God bless you
Posted on Jul 12, 2013
How to reroute the drivibg belt or fan belt
Hi,just inline the crankshaft to the top dead centre marks,then check that the camshaft marks line up,if they dont line up then turn the crankshaft pully again untill the camshaft marks line up,slacken the timeing belt pully adjuster take belt off and replace with new one,tighten the pully adjuster back up,now put a spanner on the crakshaft pully and turn clockwise untill the top dead centre marks and the camshaft marks inline if they dont then slacken the ajusting pully inline marks again and try again,if marks do inline ok then you are ready to start the car.
hope this helps good luck.
Feb 25, 2015 | Cars & Trucks
I need to install the belt back, I am working to install the water pump
Make Sure Your Adjusting is loose and your Belt correcly sitting on the Sleave From the Bottom of the Cranck Pully I See So Many People Re-ajust belt then When Star Engine Belt Broke ...So That Why I insist Sorry For That ... Then check all pully for belt sitting
Slowly Adjust Belt Till it Safe ..Then Turn Engine by Putting A extension Rachet then turn Main Crank Shaft Slowly Complite turn If the belt stay on correcly ..Then Start engine then stop Check again For Belt Position if it Ok ..Your car it fix ... Good Luck
Oct 07, 2010 | 2003 Toyota Camry
Install ac belt--how to ajust tension pully
What engine?
It should have an automatic tensioner for the serpentine belt. If the tensioner does not automatically rotate and take up the slack in the belt than it is bad and needs to be replaced.
Sep 26, 2010 | 1999 Plymouth Voyager
Where is the fuel filter on a 95 ply voy. located
driver side engine compartment. sometime its under the car driver side frame.
Aug 24, 2009 | 2005 Dodge Caravan
TRYING TO FIN THE .. AJUSTED PULLY FOR THE FAN BELT.. SHOLD I LOSEIN UP THE ALTERNATER .. OR THERE IS SOMEITHING ELS THAT I NEED TO LOSIN UP.. IVE BEEN LOOK FOR THE ADJUSTED PULLY I CAN'T FIND IT .. HELP ...
there is a tensioner pulley is that what your talking about
https://static.am-autoparts.com/item/9427378be1.jpg
this is what it should look like you will need to put your ratchet in the square hole and that will allow you to take the belt off and on...
good luck
Aug 23, 2009 | 1988 Dodge Caravan
2003 chryler concord ltd 3.5l engine ac belt replaced
Sounds like the tensioner bearing is frozen, not turning at all. You need to remove the belt and see if it spins.
Aug 14, 2009 | 2002 Dodge Intrepid
How do you check the idler pully to stop squealing?
NO ADJUSTMENT IS PROVIDED FOR, THE BLET NOISE MAY BE DUE TO A DEFECTIVE IDLER
Jun 20, 2009 | 2003 Toyota Camry
Serpintine belt fell off 2002 dodge caravan tensionator moves freely and waterpump pully has no play in it
dodge and ply. all had this problem tensioner will tilt out under load and belt comes off happens more so when raining they make a kit to repair updated tensioner with a lip on pulley and grooves and a belt with ribs on both sides to keep it in line it is expensive i have replaced belt and tensioner but weld a ring around pulley as a guide to keep it from coming off or find a smooth pulley thats the same size with a lip on it
Apr 22, 2009 | Dodge Caravan Cars & Trucks
Exercise & Fitness Logo
24 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
