Question about Vehicle Parts & Accessories
My e brake in my 2004 Tahoe, keeps disconnecting. How do I fix it?
  • 53 Answers
Grease the parts of the release lever and make sure it moves smoothly. This will insure the spring can put enough pressure on the locking pin and hold the brake securely. If greasing doesn't work then I'd replace the spring.
Posted on Jul 11, 2013
How can I realse emergency brake if cable cutting for tahoe 2009
With an assistant, release the parking brake cable tension by pulling straight back on the intermediate cable at the cable-to-cable union until the parking brake control sector (of the brake pedal) rotates to a stop. then insert a 4mm retainer pin in the parking brake control pedal to keep it from retracting on you.
Disconnect the cable running from the brake pedal to the cable-to-cable union underneath the car.
Then replace the damaged or severed cable that controls either the left or right rear parking brake shoes.
Feb 13, 2017 | 2009 Chevrolet Tahoe
2004 chevy tahoe instrument cluster (parking brake & abs lights don't come on at all. There are no codes either. Are there specific fuses associated with these bulbs in the instrument cluster?
Hello the Chevy and the GMC are bad for the resistors breaking of the dash easy fix, but they are also bad for the pin bulbs burning out. So if you know anyone that can solder this is a cheap fix can get the bulbs on ebay but personally find someone that can do a good job and go with led bulbs they will last longer and better, but with all the issues i see you may want to look into a new cluster
Dec 05, 2016 | 2004 Chevrolet Tahoe
How do you change the third brake light on a 2004 chevrolet tahoe?
That light is one piece assy. The LED bulbs are not replaceable. Remove two screws from bottom of light assy, then unplug wiring connection. It is expensive from dealer. Shop around. Online auto parts stores can be cheaper.
May 18, 2010 | 2004 Chevrolet Tahoe
How do you adjust the emergency brake on 2004 tahoe
under truck around drivers side door area by frame rail will see a cable that is a 1 into 2 with an adjustable tension slide thats e-brake cables
Mar 04, 2010 | 2004 Chevrolet Tahoe
Started my 2003 Chevrolet Tahoe this afternoon and the battery started flashing, dash said battery not charging, then brakes started messing up (felt like they were puslating)..dash then read battery not...
check ue alternator to see if its charging ur battery to check this start car and disconnect pos cable from battery if it shuts off its ur alternator
Feb 27, 2010 | 2003 Chevrolet Tahoe
My 2004 chevy tahoe makes a squeaking noise while driving and now there's brake dust forming on the rims.
If the squeeking is happening over bumps, and is not related to breaking, it could be a bearing in the steering linkage. My tahoe is doing the same thing, and my local garage says it is only a dealer fix. That is why I am searching this site now, is to find out if anyone else is complaining about this. I was told that GM is fully aware of this problem.
Apr 16, 2009 | 2004 Chevrolet Tahoe
All brake lights went out on 2004 Chevy Tahoe
the most common cause of this is either a sticking 4 way flasher switch or the turn signal switch itself.
Apr 07, 2009 | 2004 Chevrolet Tahoe
2001 Chevy Tahoe with ABS & Brake light on.
I hope you have the problem fixed by now, but, it is the ABS control under the truck. You need to go under the hood and open the fuse box and disconnect the 60 amp fuse for the ABS, this will turn it off before it burns up. This however will also cause the traction assist off light to stay lit all the time. To the fix the problem you can pay tons of money ($700 or so) to have the dealership install a ABS control and the problem will happen again over time. Or, remove it yourself, go on ebay and ship it off to a guy who repairs them for about $150 and you will never have the problem again. Also, if you wrap your cable ends with plastic and protect them good, you can still drive you truck while the part is being worked on. It takes about a week.
Nov 12, 2008 | 2001 Chevrolet Tahoe
Vehicle Parts & Accessories Logo
37 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
