Question about Garden
Carburetor diagrams nikki 698305 - Garden
3 Suggested Answers
  • 216 Answers
SOURCE: I need a diagram of
Well the best diagram I could find you is located here I believe the springs you are looking for are labeled 634 and 634A. Your choke valves and shafts are 141 and 141A.
The diagram doesn't really show an exploded view of the carb, but from what I can tell the choke assemblies should be fairly easy to find (you'll see the valves when you look into the carb's holes). From what i can see it looks like the springs are on the bottom of the choke shafts.
You can also reference here for ordering individual parts if necessary. Make sure (as I'm sure you know) to spray the whole thing down really well with carburetor cleaner to try to unstick the choke if possible.
Just to verify, I got the make/model of your engine from a few websites, but this information is about a Briggs & Stratton model 280H07-0166-E1 engine. Double check your engine's model number to make sure they match, and if not let me know and I can try to see if there's the same type of information about your model number.
Posted on Jun 29, 2011
  • 640 Answers
SOURCE: I need a diagram for
You can get a breakdown of the carburetor on a parts website like partstree.com by entering the model number off the engine, and picking the appropriate type number, and selecting the carburetor and you will get an illustrated parts diagram which includes and exploded view of the carburetor.
I hope this helps you out.
Posted on Aug 23, 2011
Need assembly diagram for nikki Carb 79778
You will find a lot of pictures and diagrams
nikki Carb 79778 Google Search
Mar 31, 2016 | Garden
John Deere L111 from 2004 surges in idle. Have replaced plugs, fuel/oil filters, fuel pump. Still does it.
Cleaning the carburetor is a good starting point. There is two versions the Briggs that were used on this mower. One had a single barrel and the other had a two barrel version. Both were Nikki carburetor that main jets that are held in place by tiny o-ring that shrink causing the jets to leak extra fuel causing surging.
Aug 11, 2014 | Garden
LA110 only runs with choke
Most likely the Nikki carburetor needing a good ultrasonic cleaning and a carburetor repair installed. It would be best for regular lawnmower repair shop to do this as the Nikki can a pain to get the parts replaced correctly and even the new gaskets can leak sometimes.
Oct 21, 2013 | John Deere Garden
How do you tell the difference between a Walbro &Nikki carburetor
you should look them up on the web or look at the difference in the rebuild kits for then
Sep 12, 2013 | Garden
Flooded carburetor
remove the needle and seat assy and clean out material that stops the needle from doing the job. Check the condition of the needle and replace if necessary. Ensure seat is tight and the float level is adjusted properly.
Apr 28, 2013 | Troy Bilt 175HP Manual 42" Riding Mower
What direction float assembly fits into carb.
it goes with the needle valve sitting into the little step on the float
Mar 24, 2012 | Briggs Stratton IC Horizontal OHV Engine ...
I need a diagram for a nikki 498888n carburetor. It goes on a B & S 14.5 h.p. It checks 50 psi pressure
Aug 23, 2011 | Garden
Briggs and straton 205412-0187e1 runs on full choke only rebuilt carburetor due to surging now it only runs on full choke
This engine came with 2 different carbs. Walbro and Nikki. The Nikki carb has a very fussy float plate! I fight them often! Usually there is a problem with the odd gasket that lifts the flat plastic plate and causes a very low fuel float level in the carb so the only way it stay running is to have the choke on. The main fuel jet on both carbs is up inside the threaded area of the bowl nut. When the main fuel jet clogs...and it only takes a speck of something you also get the symptom of having to use the choke to keep it running.
http://www.partstree.com/parts/dispdiagimg.php?src=r&ilFN=D%3A%5CEMPARTweb_52%5CCatalog+Data%5CEMP_IMG%5CBRG%5Cimages%5C6359%5C0004.TIF&ilSC=10&ilIV=0&ilBR=0&ilIF=G&ilRE=8&ilSH=0&ilEG=0&ilRO=0&ilSC=24
Main fuel jet is item 117 Nikki or Screwed into item 142 Walbro of the of the above link depending on which carb you have.
The plate I am talking about on the Nikki carb is item 135. The fussy gasket is 137A.
THE threaded area is where all the main fuel supply is drawn from the float bowl. All that must be free of obstructions. Until this is clear and orifices / jets are not obstructed; your going to be running on choke....
Thanks for choosing FixYa,
Kelly
Aug 20, 2011 | Briggs & Stratton Power Products 5,550...
Its a briiggs and stratton 16.5 hp model #313777 0112-E1. I'm gettin gas in my oil and am pretty sure float is sunk and it won't start at the moment. The carb bowl spins clockwise and counterclockwise but...
You need to determine if you have a Nikki or Walbro carb. The Nikki bowl is held on by two phillips head screws and the Walbro bowl is secured by either a single bowl nut or a anti-backfire soleniod (two wires going to it). Your problem is probably the seat in the carburetor. We see very few float problems since most of them are plastic.
If you have a Walbro with the anti-backfire solenoid you will need to get a slim 1/2 open end wrenc the access the "flats" on the solenoid to unscrew it.
The brass seat is replaceable in the Walbro along with the needle. If it's a Nikki, you may need to replace the carburetor.
Hope this helps
Feb 14, 2011 | Garden
Garden Logo
77 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
