Question about Cell Phones
Airforce WAP-35DIH A/C unit not working
Hi all, I have the above unit but on trying it for the first time this year I am met with a flashing red light and the word STOP flashing on the LED panel. Any ideas?? I can't find the manual to check for the fault details. Paul
I had the same problem, i just fixed mine. it's easy. unplug it first and give it a moment to discharge the capacitors so you dont get a shock..
1. remove the back cover by unscrewing and pulling it up and out. it may take some wiggling.
2. unscrew and remove the front cover - screws are at the top inside the back of the unit
3. face the front of the unit. in the bottom left corner is a silver tube held in place by 2 screws. remove the bottom screw and slide the silver tube out to the left so its dangling on its wires.
4. beneath the silver unit is a panel held by 1 screw. unscrew it. the panel is long and flat...coax it out of the front of the machine from underneath everything it sits on. dont disconnect the wires tho. the panel is long, you can push from the back of the machine as well as pull from the front. wriggle it out.
5. a piece of rectangular polystyrene will come with it . this is the float. on top of the long panel is a (reddish) switch. as the water rises, the polystyrene floats up and pushes on the switch.
6. clean off the polystyrene and the water tray beneath it, check that the flap flaps freely.
7. carefully (live wires around!) plug in the air con and check that with the flap dropped down (not pushed up) the aircon unit works.
8 if so, hooray, reassemble everything. job done.
Posted on Jul 01, 2015
4 Suggested Answers
  • 3 Answers
SOURCE: Blackberry Bold Won't turn on red LED light flashes
The four flashes may actually be a "2+2", indicating that there is no software installed on the device.
Posted on Nov 17, 2009
  • 6 Answers
SOURCE: my blackberry curve red LED
f you set Repeat Notification to NONE in your Profiles, you won't get the LED flashing. Do that for EACH message type in your active profile, as well as in and out of holster settings.
The Messages > Options > General Options > Display New Message Indicator setting refers to the "star" that appears on the folder when new mail arrives.
Posted on Mar 11, 2011
SOURCE: Posts: 2 Need help
i cant send text message
Posted on Jun 20, 2011
Airforce climate control wap-35dih instructions
Try Googling (airforce)(wap-35dih)(manual) without parens.
Jan 23, 2014 | Heating & Cooling
Air conditioner airforce wap 358db
Red light flashes when turn on and says stop
Jan 20, 2013 | Cell Phones
I need an instruction manual for an Airforce WAP 298DB humidifier?
Did you find a manual for this please let me know I've just bought one to and need a manual if you did could you photocopy it and send to my email pleaseeeeeeee it's t.tat55@yahoo.com ty sooooooooooo much
Aug 31, 2010 | Heating & Cooling
Hi I have a hobart airforce 250ci 2 and a half year old lightly used plasma and the power doesn't come on
Check your ground and make sure the ground is clean, if not sand it slightly where it's shinny then try tighten the ground clamp and tighten the ground clamp on the machine itself. Be sure the breaker is not tripped for the machine in the main electrical panel as well check that the electrical cord has not worn down from use, you may have to replace the electrical connector if it is badly worn. you can buy at any hardware store, you will want to buy a 15 amp male connector. If this does not sole your problem please let me now for more help. also be sure air is working for the machine.
Aug 07, 2010 | Hobart Airforce 250ci Plasma Cutter 12...
My Hobart 250 airforce doesn't start
On the main circuit board for the power supply, there is usually a thermal fuse installed, its a sealed unit and is not servicible, look for a black epoxied case,approx 3/8x3/4 long, with 2 leads coming out of it. Inside is a set of bi-metal contact points which serves as an over voltage/over current protection. These contacts deform/corode over time and it sounds like there not contacting properly. As soon as you try to load the machine, the current passing through this high resistance heats these contacts up, and shuts off power to the unit. I am not familiar with the guts of a hypertherm, but have extensive experiance repairing inverter based plasma cutting equipment, and i have encountered this before. I assume hypertherm must have some equivelent to this thermal switch inside the power supply.....Good luck..
Dec 29, 2009 | Miller Hobart AirForce 250A Plasma Cutter ...
I have an Airforce BQDD122FW Dessicant Dehumidifier. When I bought it last year it worked OK. I have started using it again this year and although the motor appears to run normally it no longer collects...
Hi There, you have faulty heater inside. They are all the same Delonghi, meaco, Logik, ecoair .Airforce
I have done 100s now. If you good you can just twist the wire in the heater and will go again without any problems.
Its just basic steel wire twisted like a spring.
anyon eneeds help sam on 07590 057545
Oct 24, 2009 | Dehumidifiers
42" Panasonic plasma has no picture, but power light is flashing
I think accroding to your model number this unit is plasma.
I need to know red light how many times flashing and correct model number
Sep 18, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Red x on my tomtom go one
Tomtom GO 910 GPS Receiver flashing white X in a red circle
I discovered that there was a file on the 910 called CLMDATA which was corrupt. When I deleted this in Windows explorer, the unit started up and worked OK. This file is recreated when the unit starts up
Oct 28, 2007 | Tomtom GO 910 GPS Receiver
Cell Phones Logo
116 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
