Question about Daewoo DLT22W4T 22 in. LCD TV
Firmware upgrade for daewoo lcd tv chassis sl-602m/p
Only red led light, panel off & remote control not function..
3 Suggested Answers
  • 55 Answers
SOURCE: Daewoo DSL-17DW3 NO RESONSE at all, remote nor manual
There is a problem with these, common to many other badly designed TVs. They get too hot for the capacitors which dry out and cause all sorts of probs.
Posted on Sep 12, 2009
  • 55 Answers
SOURCE: My Daewoo LCD TV (DLT-32C3FTB) will not come off standby.
Common problem on power supply board, replace dried out electrolytic capacitors
Posted on Oct 06, 2009
Why does it have six red blinking lights?
Hi Tim
In my opinion
No... the LED's are doing their job
Error reporting
Modern TV's are computers and try to indicate where a problem exists.
Does it need a Firmware upgrade?
Red green or orange lights are on or blinking on the TV
Sep 22, 2015 | Sony KDL-50R550A 50" LED TV 1920x1080, 240...
The remote won't work
Is its a Sharp Remote? or a Generic
A) Check Batteries
B) If a sharp aquos remote there is a function button on the right top side - insure that TV is selected. TV led will light
C) On left side there is a red TV power button press and insure the red led on the remote lights.
D) IF Tv does not turn on then you may have a problem with
the sensor inside the tv.
Only real way of verifying it is not The Remote sensor is by trying another remote. If you have a Cable or Universal follow the instructions for a Sharp TV and try that. If it works problem is with the Sharp Remote if it doesnt its your remote sensor inside the tv.
Hope this helps.
Aug 02, 2013 | Sharp LC-26DV24U 26 in. LCD HDTV/DVD Combo
I need file for upgrade firmware daewoo lcd tv 32" chassis sl-602m/p
Please check the site linked here. It has details you want to know. It is very difficult to include all details here by this window, as it has illustrations with descriptions. Check the site with patience. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by type in the model name to your set in its search box, or view it in Timeslide option.
Jul 11, 2013 | Daewoo DLT22W4T 22 in. LCD TV
Need a code for a tevion lcd 32081D to activate sky remote
Hello
Check these codes.
Tevion
TV66SIL
065
Tevion
1530, 3731VT, MD3731VT
696
Sky+ Remote Control Unit Programming Procedure Follow the steps below
1. Select any channel on the TV.
2. Point your Sky+ remote control away from the TV and press the tv button.
3. Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5. Point the Sky+ remote control at the TV and try the volume button.
* If this works try the other TV functions.
* If these work then the correct code has been selected.
* It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button
OK.
Oct 16, 2011 | Televison & Video
I successfully installed firmware update, and the controls worked, but the next morning, the controls didn't work at all, and the tv is dead.
Tv still have power LED light indication,tv still have power wright?Yes.Tries tv unplug,replug it back like an hour later.For the tv resetting itself back to factory setting.See if ur tv take in and reboot up with the new upgraded firmware.
Feb 26, 2011 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Trying to find out how tostart automatic code seach for tv so I can set the code and use the remote for my old daewoo tv
Try Aim tOn the remote control, press TV once. Press and hold SET until the LED (red light) blinks twice, then release SET. Enter 9 - 9 - 1.
Aim the remote control at the TV and slowly alternate between pressing POWER and TV. Stop when the TV turns off (after pressing POWER).
Feb 19, 2011 | One For All URC4220 Remote Control
I have a Harmony 700 remote and a device VCR/DVD functions were activated to this remote.I have however deactivated this device from my TV settings.So I want to delete every functions from the...
if you want to delete all functions and then update with your new settings, please see below
1. Log into the Logitech Harmony Remote Software on your computer
2. Click on the Downloads button at the top-right corner of your screen
3. Click on the Firmware button. Follow the onscreen instructions to upgrade the firmware on your Harmony remote
4. Once the firmware upgrade is complete, click on the Update Remote button
5. Test your remote.
Jan 05, 2010 | Logitech Harmony 700 LCD Remote Control
Hi, I need the codes for connecting the One For All Big Easy URC-4330B03 to a Daewoo TV. Can you help?
Daewoo TV codes for a URC-4330 are:
0451, 1661, 0092, 0672, 0623
If these don't work for your model, you'll need to run through the auto code search function.
1. On the remote control, press TV once.
2. Press and hold SET until the LED
3. Enter 9 - 9 - 1.The LED will
blink twice.
4. Aim the remote control at the the
the TV turns off.
5. To lock in the code, press and hold
SET until the LED blinks twice, then
release SET.
Oct 13, 2009 | One For All URC-4330 Remote Control
Apr 22, 2009 | Daewoo DLP3212 32 in. LCD Television
Daewoo DLP2612
cant get sky + to control this tv set
Mar 06, 2009 | Daewoo DLP2612 26 in. LCD Television
Daewoo DLT22W4T 22 in. LCD TV Logo
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
