Question about Husqvarna Partner K650, K700, K750, K950, And K1250 Gas Fuel Cap
Kill switch hi my stop switch doesnt work on my partner k650, i think the cut off cable has come out but not sure where it goesback
2 Suggested Answers
  • 245 Answers
SOURCE: I have a husqvarna 36
Hi
Yeah,your switch has gone bad,and using the choke isn't how you want to kill it for too long.Fouled Plugs.Here's a link to the service manual pdf if you want to do it yourself. Shouldn't be too hard.
Please rate my post?
Bob
http://www.airtimeproducts.com.au/assets/docs/Husqvarna%20service%20Manual.pdf
Posted on Aug 13, 2010
When trying to start my Partner K650, I can only pull the starter cable a very short distance before it snatches back, it feels like too much compression. Any help or advice please. Many thanks, Bob
Hello Bob, I have a Partner K750. It has a compression release valve that screws into a threaded port on the cylinder jug. I push the blue button and pull the starter rope.
Mar 16, 2015 | Garden
How do I change cutting wheel on my Partner K650 Active Still Saw?
Forgive my ignorance, but I have never heard of a Still Saw. If you are referring to the Partner Petrol Power Cutter, here is a link to the workshop manual, which answers your question on page 79.
http://www.lacountyfirefighters.org/items/Partner_Workshop_manual.pdf
Cheers, Don.
Jul 07, 2014 | Saws
Buy new saw
What exactly is the problem? There should be a rubber "O" ring between the cap and tank. If you are using ethanol blended fuel, it may have dissolved, or turned to mush . In which case you should also check your fuel pick up line in the tank.
Nov 09, 2013 | Husqvarna Partner K650, K700, K750, K950,...
Looking for year made, of a partner cutoff saw k-700,serial number..3440420need it to order parts
The K700 active and active 11 had a t bar on the side of the blade guard which you pull up to adjust it, and the cutting arm and belt guard are held with 13mm nuts, the active 111 had a plastic bracket on the top of the blade guard which you push to move the guard, and the belt guard and arm are held on with 13mm bolts.
Jan 13, 2013 | Husqvarna Partner K650, K700, K750, K950,...
Partner k650 wont start when warm
This is a pretty common carb issue, the needle in the carb is leaking, if dirt has been throgh it then the needle seat will be worn, the only answer to this is a new carb unfortunatly.
Jul 08, 2012 | Husqvarna Partner K650, K700, K750, K950,...
I have a partner k700 was running fine ,and now no spark. any ideas
sounds like the coil went bad or the kill switch wire grounded out
Jun 03, 2012 | Husqvarna Partner K650, K700, K750, K950,...
No spark
Hi, first try a new sparkplug if still no spark the ignition module will need to be replaced, regards Phil.
Need a part for a k 1200 mark II Need to know where nearest dealer is for zip code 45631
You can use the Dealer locator on the Stihl USA website. It will direct you to the dealer that is closest to your zipcode. I have posted the link HERE.
Oct 18, 2010 | Stihl Cutquik Saw Partner K650 K700...
I have a partner k1250 cut off saw and there is no spark going to the spark plug. The switch is on, and I put a new spark plug in. Do you think it might be the coil. Rich
first make sure the switch is good and the wires are not grounding anywhere this is cheper fix then a coil when the switch is bad
start simple and work up
good luck
pat
Sep 17, 2010 | Husqvarna Partner K1250 Cutoff Saw Air...
Husqvarna Partner K650, K700, K750, K950, And K1250 Gas Fuel Cap Logo
71 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
