Question about Vehicle Parts & Accessories
Driver side window will not go down all other window work check fuses all are okay could it be the swich
  • Vehicle Part... Master
  • 5,316 Answers
Most likely the switch. Has to be the switch, a loose connection between switch and motor, or the motor itself. I would take off the door panel and hot wire the motor just to check if motor or switch is bad.
Set a spare battery by the door, and run jumper wires from battery to the motor connectors. If nothing happens- no noise or movement-then reverse leads to the motor. If still nothing, the window motor is bad.
Posted on Jul 11, 2013
2005 chevy tahoe driver power seats and passenger windows don't work
Try checking fuses first of course then n2 the swich check terminalz plugged n2 switch then if u dnt have power either a relay o switch itself . .. .
Oct 28, 2012 | 2005 Chevrolet Chevrolet Tahoe Z71
Driver side power window stuck in down position - Nissan Quest 2001
I HAD THE SAME PROBLEM DIAGNOSE MOTOR OR SWICH MOSTLY BAD SWICH ,BUY ON LINE EASY TO CHANGE
Jun 03, 2012 | 2001 Nissan Quest
Similar electrical issues with driver's side door controls. Power locks, power window, and power mirror on driver's side are not functioning. I can manually unlock the door, but the buttons on...
CHECK FUSES FOR POWER WINDOW,CHECK FUSE FOR POWER MIRROR AND CHECK FUSE FOR POWER DOOR LOCK.IF FUSE OKAY DOOR CONTROL MODULE FAULTY ITSELF.
Sep 11, 2011 | 2004 Saab 9-3
WINDOWS AND LOCKS AREN'T WORKING ON PASSSENGER SIDE OF 1996 JEEP CHEROKEE LIMTED 8 CYLINDER
you have to tropleshoot the problem first check your swechs,driver and the passenger side when you do that if not working,check,the motor in side the door and make up-and dwon the window if that motor is working check the passenger side swich,it is the swich or moter
Sep 22, 2010 | 1996 Jeep Grand Cherokee
MY 2006 DOdge ram Thunder Road's windows dont work. They used to work i bought the truck new. All of a sudden all the windows from every control dont roll down their own windows as well as the driver side...
your truck also has power relays working with the fuses. each door has its on circuit except the main controller in drivers side door. if u cannot control anything from drivers side then look at the relays for possible cause to your problem.
Apr 22, 2010 | 2006 Dodge Ram
I have a 2003 eurovan and the drivers side power
checking fuses is the first step in any electrical problem.if they are all good does the driver side swich still operate the other windows?if no bad swich if yes start looking at the window motor
Feb 20, 2010 | 2003 Volkswagen Eurovan
The driver side power window on a 1998 Olds Aurora won't go down
the problems is most likely right on the switch i had the same problem with my 97 i went to the wrecker bought all the swiches and the door lights from a wreck the swiches failing is common along with the door lights falling apart at cold temps. hope this helps
Jan 02, 2009 | 1998 Oldsmobile Aurora
2004 Jeep Grand Cherokee driver side power windows do not work
I had the same problem with now power to windows, mirrors and seat. The common soulution is the orange and or black wire in the boot have broken between the door and post.
Nov 25, 2008 | 2004 Jeep Grand Cherokee
Vehicle Parts & Accessories Logo
71 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
