Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
97 chevt 1500 with a 5.7 ...no fire from coil
Sporadic fire from coil,
    Top Expert:
  • Chevrolet Master
  • 21,873 Answers
Do you have constant power going to the coil, and a ground signal from the computer ?
Posted on Jul 11, 2013
97 350 vortec will not get fire
My bet is your crankshaft positioning sensor.
Aug 10, 2014 | 1995-1997 Chevy 1500 Truck Ignition...
What would cause a 97 chevy 1500 with a 4.3L not to have spark coming out of the distributor any ideas
Don't know if this will help you or not. But we found out with our 97 Silverado, that almost everything electrical went through the ignition switch. You might investigate an ignition problem.
May 27, 2014 | 1997 Chevrolet K1500
Not getting fire out of the oil
97.
no spark from main coil.
that means blown fuses.
or bad ignitor.
the tests are here (form URL your self)
alldata dot com
Oct 12, 2013 | 1997 Dodge Ram 1500 Club Cab
I need a diagram of a 97 dodge 1500 distributor cap??
Not sure of your engine size so please pick the appicable diagram:
2.5L Engine Firing Order: 1-3-4-2 Distributor Rotation: Clockwise
3.9L Engine Firing Order: 1-6-5-4-3-2 Distributor Rotation: Clockwise
5.2L and 5.9L Engines Firing Order: 1-8-4-3-6-5-7-2 Distributor rotation: Clockwise
Nov 20, 2010 | 1997 Dodge Ram 1500 Club Cab
Looking for firing and coil order 2004 hemi 5.7
For ALL 2004 Dodge RAM (1500, 2500, and 3500) (2WD and 4WD) 5.7L V8 Hemi:
.........Firing Order:
Coil...1-8-4-3-6-5-7-2
Plug..6-5-7-2-1-8-4-3
This should have been located at the top of the your Intake Manifold.
Let me know if this helped...
Apr 15, 2010 | 1998 Dodge Ram 1500 4WD
Have problem with 97 dodge ram 5.9L no fire from ignition coil 12 v aparent on 2 wire connector at times depending on where it stops after turning engine over . nothig while its turning over
You may have a short in the wiring going to your ignition coil. If there is a broken wire, it may show current if it vibrates into the right position when the motor is shut off. If I'm correct, the ignition coils should always have current (with the key in the ON possition) with the actual ignition controlled by the crankshaft sensor, and possibly other sensors depending on the vehicles design. If all of your other coils have a 12v current, then I would start looking for a loose connection, or broken wire to that coil.
Aug 31, 2009 | 1997 Dodge Ram 1500 Club Cab
97 silverado won't start
Sounds like you need to get the Starter Solinoid Replaced. Just for Kicks make sure that you check EVERY Fuse and Relay in Both the Fuse Panel inside the Cab and the One Under the Hood.
Jan 11, 2009 | 1999 Chevrolet Silverado 1500
Need firing order on a 1996 dodge ram v8
The order should be stamped on your intake manifold right under the air cleaner.
My '97 1500, 5.2, 318 firing order is 1-8-4-3-6-5-7-2
Hope this helps
Sep 17, 2008 | 1996 Dodge Ram 1500 Club Cab
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
35 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
