Question about Toshiba FD 9859 Cordless Phone
User manual Battery wont charge to answeror dial phone
Where can I get a telephone manual for Panasonic KX-TG2205W
Hope this helps
Panasonic Telephone KX-TG2205W User Guide ' ManualsOnline.com
www.manualsonline.com > ... > Communications Panasonic > Panasonic Telephone
2.4GHz Digital Cordless Phone. Model No. KX-TG2205W. Pulse-or-tone dialing capability. OperatingInstructions. Charge the battery for about 15 hours before ...
Apr 02, 2017 | Panasonic Lands Phones
Have a telstra 9150 and won't charge
Try posting in the Cordless Phone category. Try the user manual: http://www.telstrahomephones.com.au/userguides.php
Dec 26, 2012 | Computers & Internet
I purchased an extra handset to a AT&T uniden E2125 system. The phone instructs me to place new handset on main base to register handset. It has registered and now it reads, handset #5. When I try...
I've pulled up the user manual for your phone. Thank you for providing the phone make and model first, and the complete description of your issue!
The manual says the battery should be charged for 15 hours before first use.
You may be set to pulse dialing , even though the factory default is for tone dialing. If you push the 7 key, you would hear 7 pulses or clicks in succession. The dial tone will be gone once a pulse has been received. And you say there are clicks heard and no dial tone.
You can set Handset settings (Page 12 in the PDF copy) and customize how your phone works.
Hit MENU and use the up-arrow and down-arrow keys to scroll to the desired feature., this time called DIAL TYPE, then his SELECT. Looks like the sixth menu entry from the top after LANGUAGE.
It should read:
DIAL TYPE
TONE
If it says something else, perhaps PULSE, use those arrow keys again to change the Dial Type to Tone. Then use OFF to back out of the selection and again to clear the menu.
Attached is the link to the manual. Click the button on the screen to "Open as PDF" and you can open it in your PDF reader software or save it to your device for offline reading.
http://phone.manualsonline.com/manuals/mfg/att/e2125.html
Jan 07, 2018 | AT&T E2125 (650530003738) Cordless Phone
The phone lights up when put to charge also the red light on the base,, but when the phone line is connected it wont work ..What do u think is the problem?
The battery in the handset could be bad . First I would test that the base unit is recieving dial tone by pressing speaker button on base unit. If there is dial tone then problem is in handset or in base unit communication to handset. Try resetting power to base unit. Check manual for any re-initialization procedure. If the base unit is not receiving dial tone then I would test that the phone line is delivering dial tone to the base unit by connecting a known good phone to the line cord. If the dial tone is not present , problem could be in line cord from outlet, outlet, building wiring, or service provider.
Dec 08, 2010 | Uniden Cordless Phone
Wont connect
replace battery
Mar 14, 2009 | Lands Phones
I am having problem with my cordless phone.
Another tip is to remove the battery from the handset for at least 5 seconds. You might want to get a voltage meter and check the voltage on that new battery - maybe it isn't charging properly.
Mar 13, 2009 | Uniden Cordless Phone
My battery went dead this morning i charged it this evening and it is just showing a battery and timer wont switch on or charge??
from what I hear, you have either fully charged your battery or your battery is pretty much completely dead.
your options:
1. If it's completely dead and won't hold a charge it's time to purchase another battery, this happens from time to time so don't freak out about it.
2. If it's fully charged, try taking the battery completely out of the phone, and re-inserting it after a few minutes, sometimes cell phones need to be reset.
3. ensure that your charger is working properly, if its not getting juice to it neither is your phone.
4. try to dial your number just to see what happens to the phone.
5. if someone else u know has a charger like yours try to borrow theirs to charge your phone possibly ruling out a bad charger
Nov 13, 2008 | Samsung Cell Phones
Siemens sl30 phone wont charge. Just blinks the last part of the battery. When I turn on the speakerphone to dial the phone dies and shuts off. when regular dialing can hear crackling static
I have similar problem with my gigaset 4000 micro, i bought 600mah NiMh bettery and when I start charging it charges cca 3 min and displays that battery is full and it doesnt charge it any more. I can speak max 12 minutes and phone starts beeping that battery is empty. What should i do to make phone to charge this battery properly.
Aug 08, 2008 | Siemens Lands Phones
Have ONE phone - ONE base station - still says "PLEASE REGISTER"
With the 6.0 gig set, the phones in the box are already registered. The manual tells us how to de-register and register. You might want to consult that part of the manual.
Dec 29, 2007 | GE 25932 Cordless Phone
2003 Phone- no dial tone GE CORDLESS 900MHz
I am having the same problem with general electric model 27939ge3-a . I am very displeased with the GE website(s) as it is difficult to manuveur around to find any user manuals.
Next time I purchase a phone, I will check the manufacturer's help support first.
As to a solution. I may try purchasing a new battery. Perhaps it is a power issue
Oct 30, 2007 | Uniden Cordless Phone
Toshiba FD 9859 Cordless Phone Logo
Top Toshiba Lands Phones Experts
Oloyede Monsuru
JP Services
JP Services
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
