Question about Smeg Ovens
HOw to get oven off "A"
We have a reasonably old SMEG oven which has decided to come up with an "A" in the display and stop working. WE have trying the traditional way of pushing button 6 (cancel), have tried switching it of and back on. Have also tried pushing every button combination known to man - no success it will not revert back to the clock. Very frustrating as it is totally unusable. What do you suggest we try Anneke Wright jandawright@xtra.co.nz
SOURCE: smeg oven SA392EB cannot reset clock
Turn off at mains, turn on again. 0:00 will flash press the manual op key ( on mine button on right) use +/- keys to set the time. Don't use buttons with wavy lines as they are for setting auto cooking time.
Posted on Dec 08, 2008
SOURCE: magic chef electric oven...went to
How do I replace the oven heating element in a Magic Chef oven?
Posted on Dec 31, 2008
kachbibi1
  • 979 Answers
SOURCE: smeg oven not working. only clock and thermostat light working
It sounds like you have either one of the following things that need attention. First, turn off both breakers to the oven and then back on. Next check the wiring from the receptacle to the back of the oven. Next, check your internal fuses. Most ovens have them. Last, check the wiring to the elements and control switches. Somewhere you have a wire burned off the terminals or control switch. That smell you referred to is probably one of the wires that may be burned.
Posted on Feb 11, 2009
SOURCE: Oven Door Lock
We have a Jenn-Aire self cleaning oven. The cleaning latch would only open if BOTH knobs for the cleaned oven are set to cleaning. Then the latch opened right away.
Posted on Apr 01, 2009
localwonder
  • 6784 Answers
SOURCE: F8 Displayed
F1 Electronic oven control failure Replace electronic oven control (also called EOC or clock).
Posted on Apr 02, 2009
Has anyone got a successful recipe for a sponge made in a new Smeg oven. Had no trouble with my old Smeg but new one doesn't seem to produce the same standard of product with the same recipe
Dunno, if I had a sponge in MY smeg oven i'd try to cook it at 400 degrees for at least 5 hours then bury it in the backyard!
Then I'd be sure it was dead.
...JP
Mar 16, 2015 | Smeg Ovens
Smeg SD012 top oven failed
Is the clock set to auto and not manual? Is the clock display flashing? If so then set to manual, this should do the trick
Jan 17, 2014 | Smeg Ovens
Smeg oven stopped working
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Jan 27, 2012 | Smeg Ovens
Smeg SE290x-5 oven stopped working
Replace igniter if gas .or if elect replace element
Nov 09, 2011 | Smeg Ovens
SMEG SA708 oven's symbols have rubbed off.
The oven symbols have rubbed off my electrolux oven. It's not even 3 years old. Please can you help?
Jul 26, 2009 | Smeg S1100MFX5 Electric Single Oven
Oven will not switch on
If there is an A only on the clock(no other digits) your clock has failed. Either replace , or can be bypassed. Oven won't work without clock set.
Dec 14, 2008 | Smeg SE250XUK Stainless Steel Electric...
SMEG SUK62 MFX
check stat is not open circuit and check selector switch not damaged
Oct 18, 2008 | Smeg SE250XUK Stainless Steel Electric...
Oven smoking
I am pretty sure this is just the steam escaping. Smeg ovens seal so evenly that the steam stays in the oven.
Nov 12, 2007 | Smeg SE399X/5 Stainless Steel Electric...
Smeg oven diplaying an "A" in display
I have had the same problem today - trying to change to day light saving time - can you help me too if you find out.
Sep 25, 2007 | Smeg SE399X/5 Stainless Steel Electric...
Ovens Logo
Top Smeg Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
