Aopen mx4sg n
I have power connectivity prbolems plz help
    Problem Solver:
  • 12 Answers
What is your problem? What kind of computer?
Posted on Jul 11, 2013
MX4SG-4D2
There will be a screw or two on the side of your case. Follow these simple steps.
Shut down computer.
Disconnect all wires from tower and move it to a place, such as a table. where you can do the work.
Using a phillips head screwdriver remove the screw(s) holding the case together on the side that is removable (usually the left side)
Look inside the case, you will see a slot that matches your graphics card. It is called a PCI-E slot, look it up if you are unsure of what one looks like.
Remove the metal tab that is blocking the hole in front of the slot, and slightly to the side. It will either pull out or be held in by a small screw (save the screw if it is there).
Gently, but firmly, line up the graphics card's pci-e connector with the slot in the motherboard. It will require a firm, but gentle nudge to snap into place. Don't force it and make sure you are lined up. If it's seated correctly the metal slot on the front will line up with the metal tab you just removed. If you have a graphics card installed already, remove it.
Reinstall the side of the case. Connect all wires, but this time connect your monitor's connection (either DVI (white), VGA(blue) or HDMI (black and gold) to the graphic's cards video port. Power on the computer.
Here the steps can vary. If you didn't remove a graphics card earlier you need to disable the onboard graphics. I would need to know the manufacturer of your motherboard to give instructions on how to do it.
Insert the disk that came with your graphics card and install the software included with it.
Play games.
Jan 08, 2014 | AOpen Computers & Internet
What's the compatibel RAM for Aopen s661FXm us rev 2.2 plz !!
Use one of the memery site like Memory dot com. Enter your make and model. Some even have a small agent (software) that loads and tells you exacly what you need.
Dec 24, 2012 | AOpen s661FXm Prescott Motherboard
I want to know the right ram for Aopen s661FXm us rev 2.2 plz !!
Hello you can download info here:
http://global.aopen.com/products_detail.aspx?auno=1301
Your mainboard use DDR ram max memory size 2 gb.
The drivers (if needed) can be downloaded here:
http://global.aopen.com/products_download.aspx?sDropDownProd=52
Good luck
Turn computer on, monitor doesn't activate, bios doesn't run.
Did you connect the P4 connection with out it you will just get lights and fans...
If your hard drive is not spinning up you missed the P4 connection its near your PCI slots.
Good Luck
Aug 15, 2009 | AOpen AX4B-533 Motherboard
Confiuration of motherboard
You can download the manual from here.... select Motherboard in the left Box... Your model # in the second...and Manual in the third...
http://download.aopen.com.tw/Default.aspx
May 26, 2009 | AOpen Computers & Internet
Find maximum processor size for aopen ax34-u motherboard
u wont be able to install a cpu much faster than 1ghz without flashing the bios.....
if you do not know how to do this then plz do not attempt it as if it geos wrong or you have a power surge then the mobo will be NFG.......
Feb 24, 2009 | AOpen AX34-U Motherboard
Is it dead or can i bring it back to life
http://download.aopen.com.tw/...ALL INFO MANUALS AND DRIVERS FOR YOUR BOARD CAN BE FOUND HERE.RICHARDM69
Dec 09, 2008 | AOpen s661FXm-7S Motherboard
Sound
For the sound driver of an AOpen MX4SG 4DL, pls try here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 29, 2008 | MSI P4MAM-L (MS-6787) 400/533 MHZ FSB...
Manual
ftp://ftp.aopen.com/pub/manual/mb/mx4bs/mx4bs-ol-e.pdf here is the manual that you needs i found it on the www.aopen.com website it says for the front panel switches attach the power led,empi,speakers,power and reset switch connectors to corresponding pins. If you enable suspend mode item in bios setup the acpi and power led will keep flashing while the system is in suspend mode locate the power switch cable from your atx housing. It is a 2 pin female connector from the housing front panel. Plug this connector to the soft connector marked spwr there is a diagram to show you how to hook it up if you need anymore hesitate plz give me a shout and i willl be able to assist you more
Sep 10, 2007 | AOpen (MX4SGI4DN2PRE) Motherboard
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
