Question about Whirlpool RBD305PDS Electric Double Oven
How do you remove a Whirlpool double wall oven when the upper door will not open?
catriver
  • 878 Answers
SOURCE: Whirlpool Double over
big dib, the TC0, ( thermal cut out) probably has opened. This is non resetable. To get at it you have to pull the oven out to a point where you can get at the back. Then you have to remove the oven back panel and there is the TCO. Part number 4450249. You can verify this by ohming out the TC0, if it shows open (no continuity) it's bad. I have done a number of these and it takes two people to repair it safely. Kill the breaker when going in there. Catriver..post back.
Posted on Dec 30, 2006
SOURCE: Whirlpool Double Oven RBD305PDB7 - Upper Oven Won't Heat
I have the single oven of this style and I had to replace the thermocouple (part number 4450934) on the back of the oven three times (used the cleaning cycle three times). After using the cleaning cycle, the oven would not heat so each time I had to pull the oven out from the wall to access the back so I could change the part. Once a new part was put on the back of the oven, it worked fine. To pull the oven out, open the oven door and look down by the doors hinges. On each side you will see a screw that's holding the side molding on. Remove the screws and then the molding. That will give you access to the screws that hold the oven into the framing around the oven. Remove the screws and then you can pull the oven out to access the back to change the thermocouple. The oven is heavy so you may want some help to get out. It is not a one man job, maybe a one man and wife job. It is heavy. I hope this helps. Better late than never.
Posted on Nov 24, 2008
SOURCE: whirlpool rbd275pdb double wall oven died during self clean
The first time we used our Whirlpool oven the same thing happened - no power and yet the circuit breaker was not blown. I called Whirlpool, and they sent out a technician to check it out as it was still under warranty. He said the temperature was off (too hot) by 20F - he adjusted. He also replaced the blower. What he did not tell me was that the thermal fuse had blown, and he replaced it - this was the REAL cause for the failure. I got the impression that he did not want to let me in on the secret. He did not note on the paperwork that he replaced the thermal fuse. Last week I decided to run the oven through the self-cleaning cycle (the oven is now 8-1/2 yrs old) - I don't believe that we cleaned the oven but a couple of times since the first time that it was "repaired." I used the default 3-1/2 hour setting. Everything appeared to be fine - the oven went through the cleaning cycle with no apparent problems. The display now read "cool down" - I went to bed thinking everything was okay. I got up the next morning only to find out that the power was out. I called Whirlpool and demanded that they repair the unit again as they clearly never fixed it correctly in the first place. They offered me 15% off on a new oven - WHOOPEE! I asked to speak with the supervisor - he did not budge either. I was upset, and I told him that I would NEVER purchase a Whirlpool appliance again! I decided to tear into the oven to see if I could detect anything wrong. I pulled out the front panel - everything looked okay. I then noticed the "thermal fuse" - I did not know what it was called at the time, but it looked familiar. I checked voltage on either side of the fuse and found the voltage to be zero on the downstream side of the fuse. I pulled it out and read the information on the device: Microtemp 110C. I called a local appliance repair shop - they told me that it would cost $50 to purchase a new fuse! I told them that seemed very high. I ended up stopping at Radio Shack. They have thermal fuses in various temperature and voltage ranges. I got a 144C 10A fuse and carefully soldered the connectors to it and replaced the protective plastic sleeve. I actually bypassed the thermal fuse in order to use the oven before I found the replacement fuse. While it is a good idea to have a protection device for the slim chance that an oven may malfunction by overheating, it is not a necessity for the functionality of the oven. Hopefully, the thermal fuse will not fail during my next attempt to self-clean the oven. I do have a concern about the 10 amp rating, but I'm sure that it will work fine.
Posted on Apr 15, 2009
  • 17 Answers
SOURCE: Whirlpool double oven - model RBD305PD82
Please take a look at the diagram if you think you want to do that.
if you still want to do it and need more details to disassemble feel free to email me. nguyen@ite.net
Posted on Jun 09, 2009
SOURCE: how to remove the control panel on Whirlpool double oven Model RBD305PDS14
Emge & Associates is investigating gas and electric ovens manufactured by Whirlpool, including such popular brands as Whirlpool, Jenn-Air, KitchenAid and Maytag.
The firm is investigating reports that the electronic control panel on certain models is subject to failure after a limited number of uses of the appliance’s “self-cleaning” setting. While most foods are cooked at temperatures reaching 375 degrees, the “self-cleaning” setting raises the interior oven temperature to 1,400 degrees. Due to defects in the design and or manufacturing, the electronics contained on many ranges are damaged by extremely high heat. Repairs to damaged control panels typically cost in excess of $300 per replacement.
If you have experienced failure of the control panel in your range after using the “self-cleaning” setting, you can join this investigation by contacting Emge & Associates at (800) 629-3409 or (619) 618-2974.
Posted on Dec 19, 2009
How do I replace the handle on the upper oven door of whirlpool double wall oven
Remove the inner glass and it will expose the two screws you need to remove to replace the handle.
Oct 15, 2014 | Ovens
Control board is blank - door is locked
The cavity thermal fuse has blown if this happen during a self clean the TOD for the upper or lower oven has blown
Jul 31, 2014 | Whirlpool RBD245PRS 24" Double Electric...
Replace light in KEMC378KSS microwave
The oven lights are 12-volt, 5-watt maximum halogen bulbs. They
will come on when the oven door is opened. On double oven
models, both upper and lower lights will come on when either
door is opened. The oven lights will not work during the Self-
Cleaning cycle. When the oven door is closed, press OVEN
LIGHT to turn them on or off.
To Replace:
Before replacing, make sure the oven is off and cool.
1. Disconnect power.
2. Remove glass light cover by grasping the front edge and
pulling away from oven
3. Remove bulb from socket.
4. Replace bulb, replace bulb cover by snapping back into wall.
5. Reconnect power.
Feb 04, 2013 | KitchenAid KEMC378KSS Electric Double Oven
Double oven no model number Whirlpool 14 years old Door is locked after self clean and display is blank
Your oven has resetable high limit thermostat that tripped off on the self clean cycle,im not sure if you have free standing,or a wall oven if freestanding the t-stat is on back panel if wall oven its behind control panel on upper oven and for lower oven its behind the grill between bottom of upper oven and top of lower oven. In either case it has a small red button that can be pushed in to reset it
Hope this helps and if it does please give me 4 thumbs up
Gene
Jul 28, 2011 | Whirlpool Ovens
I have a Whirlpool double oven GMC305PRS01 when you turn on the oven it appears to me making all the right move IE it goes into pre heat and starts counting down but the elements are not getting hot.
Member Discussion on Whirlpool GMC305PRS01 Microwave Oven
Whirlpool Wall oven/microwave combo unit Door message
Does anyone know where the 15 amp fuse is? I replaced the 20amp fuse and it worked for a minute or two and then I opened the door and I blew my circuit breaker. I reset my circuit breaker, replaced the 20 amp fuse and now all I get is the Door message. I also noticed that it fused the outside switch on the right side of the door so I had to open the switch up and un-fuse it. This is for a whirlpool GMC305PRS01 Wall Oven/microwave combo unit.
Also if anyone could tell me the correct position the wire is supposed to be hooked up on the switches? I had someone help me take the switch out and they unhooked the wires and now we aren't sure how they are supposed to be hooked up. My light on the microwave doesn't work either. Is it possible the bulb blew when the fuse blew?
Nov 22, 2010 | Whirlpool GMC305PRS Stainless Steel...
Repalce a broken door hinge on upper oven
you must remove side panel . if wall oven slide out on a table strong enough to support is during service . mm
Jul 16, 2010 | GE Profile JTP56 Electric Double Oven
Cleaned bottom oven. Top oven door won't open
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Apr 11, 2010 | Maytag Appliances 27" Electric Double Wall...
Jenn-air JJW9630CAS - double wall oven -door won't close, even after hinges replaced
On my double oven the bottom door was not closing by at least 21/2 inches the upper door would allow the light to stay on . Upon close examination this problem appeared to be the door was too low which did not allow the gasket to seat in the oven cavity, holding the door open. new hinges and receptors did not resolve this condition.This is how I corrected this condition. 1 open the doors one at a time and lock the hinges.2 remove the doors from the receptors (be careful they are heavy) and set aside. 3 remove mounting screws holding oven in cabinet. 4 slide oven forward enough to hold onto receptor sockets on left and right sides lower and upper 5 remove receptor sockets by removing the screws in front of oven(be careful to hold on to the receptor so it doesnt fall behind oven into cabinet)7 with a center punch punch a start point 1/8 inch above the existing screw holes and drill appropriate size hole for screw THE HOLES MUST MATCH UPPER AND LOWER RECEPTOR OR THE SCREWS ON THE LOWER DOOR WILL SCRATCH THE UPPER DOOR .8 attach receptors to oven in new holes 9 slide oven back into cabinet and replace screws removed in step three 10 attach doors into receptors and push locks forward into receptor cavity attach lower door first and check for operation then upper door open slowly and check enough clearance exists for the screws on the lower door miss the upper door . If more clearance is needed elongate the holes drilled earlier(repeat steps 1 through 5) and slide receptor up on upper door. NOTE The receptors are not in a sealed space in the oven cavity and are not exposed to any heat. Periodically check the screws for tightness. After performing this procedure Both doors close all the way and the light is no longer a problem Now 20 minutes cook time MEANS 20 MINUTES COOK TIME.
HOPE THIS RESOLVES YOUR PROBLEM !!!!!
Nov 06, 2008 | Ovens
Aug 23, 2008 | Whirlpool RBS305PD Electric Single Oven
Very Old Whirlpool "Wall of Fire" Gas OVen
what you have to do is get a couple of nails pull the hinge on the door down far enough to insert the nails in the holes and let it rest against the door this will hold the door at the proper angle to engage the hooks inside the hinge slots on the body of the range grasp the door on each side and insert the hinges in each side to engage the hooks then open the door all the way and remove the nails
Aug 22, 2008 | Whirlpool RBS275PD Electric Single Oven
Whirlpool RBD305PDS Electric Double Oven Logo
54 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
