Question about Dryers
Dayton 3k771g spec - Dryers
Looking for a parts list for a Dayton 3Z372b electric hoist.
Dayton Hoist Parts - Ace Industries, Inc.
https://www.aceindustries.com/m-53-dayton-hoist-parts.aspx
Dayton Hoist Parts Online. Certified OEM DaytonParts in Stock Helpful Diagrams to Find Parts Fast. ...Dayton Electric Chain Hoist Parts. Basic Hoist(Figure 12) ...
[PDF]Dayton® Electric Chain Hoists - Ace Industries, Inc.
www.aceindustries.com/pdfs/Dayton/DaytonElectricChain-JLCManual.pdf
Dayton electric chain hoists are rugged, portablehoists that provide quick, precise ... Other features that ensure the safe operation of Dayton electricchain hoists.
Dayton Hoists Online - Ace Industries, Inc.
www.aceindustries.com/m-52-dayton.aspx
Coffing hoists and the Grainger Dayton electric hoists are the same identical units. The only
Apr 19, 2016 | Dayton Heating & Cooling
I am looking for a multi function relay similar to the Dayton (1)6A855 but with a 240vac input not 120vac input. Can you assist please. Regards Bruce Peters
1) Dayton 6A855 time delay pin timer
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=dayton+6A855&op=search&Ntt=dayton+6A855&N=0&sst=subset
Grainger owns Dayton, so you might want to contact Grainger
http://www.grainger.com/Grainger/static/help_contactus.html
1-888-361-8649
2) Time delay timers at Grainger:
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=dayton+timer&op=search&Ntt=dayton+timer&N=0&sst=subset
3) Grainger shows time-delay 8-pin 120 or 240V
http://www.grainger.com/Grainger/DAYTON-Relay-1EJN7?Pid=search
Grainger shows 11-pin 120 or 240V
http://www.grainger.com/Grainger/DAYTON-Relay-1EJN6?Pid=search
Searching for "11 pin 240Volt delay timer" turned up results:
4) Following pdf shows knob-adjustable 240V delay-on pin timer
https://www.relayspec.com/specs/020050/T1Series.pdf
5) Signaline has delay timers (800) 862-2875
6) SSAC
http://www.ssac.com/standard/ff-tdr1.htm
7) Another pdf with 240V delay pin timers
http://www.askco.com/pdfs/tdd_tud_data.pdf
8) Not wanting to say what already know, but each 240V circuit is made from two out-of-phase 120V lines. Any 240Volt Load can be turned OFF by turning off one of the 120V lines. In this way, the Dayton 120V timer can be used to control 240V load.
Also the 120V Dayton can operate 120V double-pole contactor, and then the contactor controls 240V Load.
http://waterheatertimer.org/How-to-wire-Dayton-Off-Delay-Timer.html#contactor
Apr 04, 2011 | Amperite Dayton Solid State Timer On Delay...
I had a 242-5D on a 120 horizontal driven by a 5 hp Dayton motor. I changed to a 2475N7.5 on a 80 gal vertical with a bad motor. I want to reuse the Dayton 5 hp motor. What can I expect?
Im not sure if iv;e got this straightYou had a 242running on 120 v driven by 5 hp dayton motor You have a new 80 gal tank with a bad 7.5 v motor and want to put the 5 v motor on it What was the size of the old tank if it was 60 or more you should be ok the 5 hp will have to work harder as long as you can make it fit you may want to consider droping down the blow out valve presssre spec 10 to 15 lbs depending on the size of the old tank
Nov 21, 2010 | Ingersoll Rand - Rand Type - 30...
Jamo Cornet 90IV
not sure what size you need but dayton audio subs are pretty killer check them our parts express usa, i a have a set of realistic mach ones with one of my drivers blown i did some searching and found parts express, due to rave reviews and the specs on what i look for in subs dayton is the way to go,happy hunting-z
Jan 10, 2009 | Jamo A4SUB Car Speaker
Capacitor
Here is a link to a distributor with fan specs : http://www.grainger.com/Grainger/wwg/productIndex.shtml?search_type=keyword&QueryString=3C325B&operator=refineSearchResults&originalValue=Dayton+Fans&searchIndexId=1&typeOf=
I do not know which specific motor is used on that fan ( that fan has been discontinued) however you can check out this link http://www.emotorpro.com/index.asp?PageAction=VIEWCATS&Category=280
and have a representative that sells Dayton products answer your question... Hope this helps you...
Sep 09, 2008 | Dayton Permanent Split Capacitor Motor Fan
Dryers Logo
20 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
