Kenmore model 110.46747 801 I have water filling the drum after machine is off
Drummernick
  • 440 Answers
SOURCE: Washing machine fills with water overnight or when not in use Kenmore calypso
fill area has crack or leaking in repair that in valve
Posted on Feb 04, 2008
AlmostBob
  • 550 Answers
SOURCE: Kenmore 90 series washing machine
Follow all jsrocks tests,
but Before replacing the pressure switch there are more tests of function
Blow any water out of the air tube, it should be empty when the washer is empty, water remaining in the tube messes up the pressure sensing(usually makes water level lower so doubt this is the fault)
Kenmore pressure switches are adjustable, the adjustment is hidden.
An internal spring stretches over time and does not react properly.
to test whether just the adjustment is required,
  1. remove the water level knob from the front side of console
  2. depress the lock tab at the right side of water level sensor body where it contacts the back side of the console and rotate counter clockwise 45degrees
  3. withdraw water level sensor body
  4. adjacent to shaft for the knob is 1/8inch bolt head, turn clockwise to raise, counter clockwise to lower water level.
  5. washer can be operated with the console open and the level body removed
  6. test, adjust, test adjust.
  7. if no effect replace water level sensor body
Posted on Jun 04, 2008
  • 1462 Answers
SOURCE: Hotpoint Washing Machine Model # VBXR1060T4WB Filling Problem
problem could be the pressure stat which is a switch which detects water level or the pipe leading up to this switch or the air chamber the pipe goes to.
take top off. locate the pressure switch - has a small diameter pipe going to it. remove pipe and fit a similiar one. put on fill and pressurise this pipe by mouth and water fill should stop. if it doesn't, then switch is faulty.
if this is ok, examine carefully the small diameter pipe for splits and blockage. also check the air chamber for build up of gunge
Posted on Nov 16, 2008
SOURCE: Drum will not spin
I unplugged the machine for 1 hour and the computer reset, and it is working fine
Posted on Jan 05, 2009
  • 1937 Answers
SOURCE: kenmore washer model 111 24622300 fills with water
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Posted on Jun 06, 2010
I have an old Lady Kenmore washing machine that for the past couple of months now will not dispense water into the drum for a washing cycle. I have to manually fill up the tub with water and when the
You will need to replace the "water inlet valve". Se if you can get a part number off the valve. I will need that number or the complete model number to point you to the correct part.
Nov 27, 2012 | Washing Machines
KENMORE W10318791
That's not a good model number. If you can get that off the machine I'll be able to help out
Jun 17, 2012 | Kenmore Washing Machines
Kenmore washer model #110.28882790 is very slow to fill with water. We've checked and cleaned the hose filters. Is there some kind of water sensor? Or hidden filters?
Remove the water line from the INLET valve and start the machine , if there is no proper flow of water then the inlet vavle is not working to open , the filter on the vavle is clogged or the inlet filter is blocked. Also check the voltage on the inlet valve to make sure that the controller unit is outputting correct voltage.
If not replace filter , valve to ensure that the drum get best flow for filling.
Aug 22, 2011 | Kenmore Washing Machines
Water leaks into drum and machine intermittantly
The mixing value is leaking. I ordered a new one and will replace it.
Dec 20, 2009 | Kenmore Washing Machines
Washer stops after fill
You should control the pressure switch on the machine. It is a circular object on the top of the machine, and it is connected to the drum with a thin hose. Remove the hose from drum and blow the the hose, you shuld hear 2 or 3 ticking sound from the switch. If you can not hear, change it with a new one. Also clean the thin hose, it can be blocked by detergent.
May 28, 2009 | Kenmore Washing Machines
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Drum filling with water after cycle is done
replace bad fill valve its bleeding throw under top left rear easy
Nov 13, 2008 | Kenmore Elite 45986 Front Load Washer
Washing machine overflowing
I'd have a look at your water level detector to start with. Usually a narrow bore hose running from near the bottom of the drum to a pressure switch somewhere near the top of the machine. Most common problem is that the hose gets blocked with gunk. With the machine off and drained, try removing the hose and giving both it and the barb on the drum that it came from a good clean through. A.
Jul 17, 2007 | Kenmore 22442 Top Load Washer
Washing Machines Logo
49 people viewed this question
Top Washing Machines Experts
