Question about Bushnell Powerview 13-1632 \ 1633 (16x32) Binocular
Bushnell 16x32 dropped in saltwater, now moister on the inside and foggy lens how can I take it apart and what should I use to clean?
How to clean the lens on the headlight on a 2002 chevrolet
the lens is the outside piece that the wind hits when driving. you don't have to remove anything to get to them. what exactly do you mean by lens.
Aug 12, 2015 | 2002 Chevrolet Impala
How to get my single image back?
Although It may not appear to have prisms because of the sleek barrels, they do infact have roof prisms in them. Most likely one of the prisms is out of position. Bushnell typically has a great warranty so contacting them to have them repair it would be my recommendation. Here is there service group link: Bushnell Repair Services. If you need additional guidance do not hesitate to contact the folks at RCS Optics
May 09, 2015 | Bushnell Powerview 13-1632 \ 1633 (16x32)...
I have the quantaray lens ld 70-300mm. Was working fine until one day. When I look through it everything looks slightly foggy. Adjusting it doesn't help. Cleaned the outside lens. Would like to kn
Yes, the lens can be disassembled and cleaned. But before you think about doing so, think about this. Do you have a lens collimator and other equipment necessary to ensure proper alignment on reassembly? If you don't, please leave inside cleaning to a trained professional.
Dec 05, 2012 | Cameras
My Bushnell 16x32's have a haze in the lower sights. Brand new out of the package. Fixable on my part or take back to the store ? Thanks !!! Laura
It's your choice. It is very fixable normally but taking the lens scope off may ruin the warranty. It is usually moisture or improper handeling during assembly.
Aug 09, 2012 | Bushnell Powerview 13-1632 \ 1633 (16x32)...
Can not focus this unit. I cleaned the lenzes. Any ideas?
Hello, unscrew both the eye piece and the 50mm? front lens. Check the inside with q-tip for dust and dirty. Take a look see through the lenes, if foggy after ceaning. Take the lenes to camera shop for disassibly and cleaning. stewbison.
Aug 03, 2011 | Bushnell 26-4366 Monocular
Big lens on end of telescope is stained, can i takre it apart or get a new part. thank you.
If you can remove the lens you can clean it with alcohol (97% or better) and distilled water plus a drop of dish soap. (50% alcohol, 50% water) rinse with distilled water.
If that does not clean the lens, use pure acetone (not the perfumed, nail polish remover) Again, rinse with distilled water.
Might as well try since this is not much of a telescope, more of a toy to discourage would be astronomers.
Oct 18, 2010 | Bushnell Deep Space 78-9512 (120 x 60mm)...
I bought a used Tasco Galaxsee 45-060525 for my next door neighbor's young boys who are home-schooled to study astronomy. The lens are all foggy/cloudy. Any suggestions?
Wish you DID NOT buy this scope. Tasco, Bushnell, are both what we call "department store" telescopes.
Also the mount is called an equatorial mount. It must be polar aligned in order to use it. Read my TIP on polar alignment on my profile page.
The eyepieces can be cleaned with any eyeglass cleaning kit or photographic lens cleaning kit from a camera store. Be gentle when cleaning.
Next time buy them a scope like this one called a Dobsonian mounted reflector.
http://www.telescope.com/control/product/~category_id=classicdobs/~pcategory=dobsonians/~product_id=08942
Read these two web sites:
http://www.texasastro.org/telescope.php
http://www.texasastro.org/mounts.php
Aug 31, 2010 | Tasco Galaxsee 45-060675 Telescope
Bosch & Lob elite ed foggy
Bushnell own bausch&lomb scopes and I have had good luck with there customer service. I would call them first .Just make sure you send a detailed letter with scope.Good luck
Feb 08, 2010 | Bausch and Lomb Bausch & Lomb Hunting...
Pieces of dirt/oil residue on INSIDE of viewing lens.
That is not oil.....its thermal burns. Thermal burns happen when the eyepiece cap is not used. Sunlight burns the surface of the LCD display. This is permanent damage. Cleaning will not fix this. The repair center can fix.
Sep 03, 2008 | Bushnell PinSeeker 1500 20-5103...
Water damege
That depens if the fog is inside or outside, outside it usually dries faster than inside. You are advised to let it dry at least another 24 hours , if the lens is still foggy after that , thab you must go to a repair shop to let it be cleaned.
May 05, 2008 | Kodak EasyShare C613 Digital Camera
Bushnell Powerview 13-1632 \ 1633 (16x32) Binocular Logo
Top Bushnell Optics Experts
George Merkley
George Merkley
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
