Wilson Jones laminator LP35HS
Our laminator is jammed, how does it open
2 Suggested Answers
  • 3 Answers
SOURCE: Paper Jam in Wilson Jones 1500. Reverse doesn't
You should probably unplug it. Two screws in back and under. Slide front cover back an inch.Disconnect cable and clean unit with vacuum.
You can hand cycle it in both directions to loosen up the blades.
Posted on Apr 18, 2011
My 17 year old Wilson Jones 1153 Model shredder can't be left plugged in-It drains the electrical circuits and turns our heater off. Other than that,it works great.Is this worth repairing-Suggestions?
Just take it apart and unplug the switch that is keeping it on. take pictures when you pull apart the cases. sometimes some of the screws are under labels. Should be no more than five screws. Paper has an oily presence and causes these type of failures.
Apr 18, 2017 | Wilson Jones Office Equipment & Supplies
Our Wilson Jones 2000 shredder is jammed. I put too many papers in it at once, didn't realize they were folded on the bottom. How do I clear the jam?
Try reversing it. If that fails, get access to the shredding mechanism (with power off) and pick the paper out piece by piece and bit by bit.
Oct 21, 2016 | Shredder Office Equipment & Supplies
User Guide for the machine
i need clubpenguin unused membership
May 01, 2013 | Wilson Jones CB256 Comb Binding Machine
Card Jam Error 112 & 245
please calibrate the Lam Film sensor.error 245 is lam sync error please check Lam power/connections and restart the Printer.
Oct 02, 2012 | Fargo HDP5000-LC ID Card Printer...
How do open and close Wilson Jones 365-49 Large Handing Post Binder
Open the binder flat, press the top right stick thing (sorry, don't know a better word for it), and press it to your right. Lift the metal (right side) up and out. To put back in, just place in the papers, and then take the right metal strip of three prongs, and snap it back into place. Hope this makes sense.
Apr 05, 2012 | Wilson Jones 365-49 Large Hanging Post...
Shredder is Wilson Jones 130 auto. I believe staff shredded to many sheets at one time. No no lights no power forwards or backwards. Is there a reset or fuse, can't find one
Oddly, my Wilson Jones 130 auto just did exactly the same thing. I'm the only one that uses it (that I know of) and one day it worked, the next it didn't. There is no paper stuck in it. There are no power lights, nothing works. Does anyone know the location of a reset button or something?
Jun 21, 2011 | Office Equipment & Supplies
I have a scotch brand laminator tl901- it is jammed...and making a clicking noise...is there a way to open the system and try to unjam it?
First, make sure that the unit is unplugged and has sufficient time to cool off. Then remove six screws on the bottom of the laminator. The screw driver shaft must be thin enough to fit into the holes where the screws are located. Two are very easy to find -- one on each side in deep holes. The other four are hidden under small black rubber disks that the laminator rests on. peel up the rubber disks and remove the rest of the screws. At this point it is easy to remove the cover and remove the jam. To replace the cover you must use a thin tool to pull back the release level so it will fit into its opening in the cover. Replace the six screws and you should be able to ready to laminate again.
Jul 10, 2010 | Office Equipment & Supplies
Paper Jam in Wilson Jones 1500. Reverse doesn't clear it. Is the plastic cover where the paper is fed removable?
Aug 12, 2009 | Office Equipment & Supplies
205 people viewed this question
jasbo
jasbo
